Essential Bus question
Goto page Previous  1, 2
Kellym
PostPosted: Fri Feb 07, 2014 6:33 pm    Post subject: Essential Bus question Reply with quote
Bill,
I don't know what was available when you designed your system. Grand
Rapids recommends http://www.tcwtech.com/IBBS.htm for backup battery,
and TCW says it is also suitable for backup of G430.
Dynon offers its own backup battery managed by the EFIS software to
takeover at 12.3 volts.
Garmin 650 and 750 know airways, unlike their older brethern.
I get the need for airways and not wanting to re-enter flight plan after
start, or wait to after start to do it with the price of gas.
There is also a voice activated add on for the 430 for data entry that
Knows airways.
What I "get" is the desire to keep electrical system as simple as
possible as the primary means to reduce failure points. If reboot
becomes a problem with my GTN 650, I will add a TCW unit. I'm just not a
fan of dual bus, dual alternator, dual battery systems, but we are OBAM
so we can make our own choices and argue with anyone who chooses
differently. Wink
Kelly
On 2/7/2014 3:30 PM, Bill Watson wrote:
<Mauledriver(at)nc.rr.com>
Sorry about adding to this rather old discussion but I've been away
for awhile.
I finished my RV10 in 2011 which means that I designed my electrical
system and panel around 2008 for a 2009-2010 build.
I have 3 GRT HX EFISs - 2 aimed at the pilot, 1 at the passenger. They
supply synthetic vision, moving map, weather, traffic and a complete
suite of engine stats. No light weight backup batteries can be
configured at the factory with these systems. These screens have no
integral on/off switch. I chose not to add any switches or operable
CBs. They come on with the master and will usually reboot when my
IO540 cold starts with a single, fresh PC 680 battery.
The GPS WAAS smarts for this system are supplied by a G430W.
I am a serious traveler with this machine and practically all flight
are on IFR plans. My normal routine for all flights is to file my
plan using Foreflight on an iPad. Whenever at an airport with
clearance delivery, or when departing into IMC conditions, I obtain my
clearance on the ground, before engine start, and enter it into my
iPad and then into my G430. Many times in congested areas, this entry
is followed by no small amount of study. As my aging mind continues
to fog over, I'm finding that the study time grows.
Here's the challenge on G430 based panels; it loses any entered flight
plan when powered off. An engine start that reboots my GRTs, reboots
my G430.
An acute challenge on 430 based panels when used for flights around
the Wash DC area or for flights along Florida's Atlantic coast is that
the G430 does not know what a Victor airway is. These are flights I
make regularly and clearances in these areas typically still include
Victor airways. So in the routine described above, entry into the
iPad generates the necessary waypoints to any Victor airways.
Accurate entry of these waypoints into the G430 is important and
there's no way I want to redo the work.
As Bob would put it, this is the 'kitchen sink' I choose to fly with.
I think it's fantastic and works very very well for me. It's now a
well grooved swing. The inability of some (e.g. Bob, not necessarily
you Kelly but I did choose to respond to your post) to 'get' this
requirement for this pilot, seems to me is just an inability to see
past old school experience or perhaps your current pleasure flying
routines.
I have a Z-14 with 2 batts, 2 alts, and 2 buses and I REALLY like it.
I bring up the 'kitchen sink' on one battery, get my clearances, enter
them into my systems, study my departure plan when doing complicated
airspace or low IMC departures and then bring up the 2nd battery bus,
cross link them and start my engine. Everything stays up. Before
takeoff I've learned, per Bob, to de-link the buses and off I go.
Per Bob, I've eliminated any semblance of an avionics bus, extra
switches or CBs. After a few operational adjustments and refinements
(Thanks Bob!), the 'overkill' of a Z-14 has given me exactly what I
think I need.
I need my avionics on before start and I have a big kitchen sink that
takes care of the dishes just like I want them done. So can we please
stop dismissing this approach to equipping and traveling in our very
fine OBAM aircraft within the user fee free ATC system we have? Some
of us do it every day because that's the way we choose to roll.
PS: I've been out of the loop island hopping the Bahamas. Recommend it
highly. What an adjustment flying VFR from place to place! However,
I still used the same procedures because that's what standard
procedures are for.
Bill "It's pretty darn good in the Bahamas" Watson
N215TG
On 2/2/2014 7:14 PM, Kelly McMullen wrote:
> <kellym(at)aviating.com>
> Virtually all glass have their own light weight backup batteries so
> do not have startup brown out issues unless no backup battery is
> installed.
> I see very little value in being able to turn on GPS prior to start.
> While one needs engine instrumentation prior to and during start, one
> does not need avionics on.
> Of course newer avionics that allow faster input of flight plans than
> the 430 help, if that is the reason for turning on 430 before start.
Kelly McMullen
KCHD
jluckey(at)pacbell.net
PostPosted: Fri Feb 07, 2014 9:24 pm    Post subject: Essential Bus question Reply with quote
Sent: Friday, February 7, 2014 6:32 PM
Subject: Re: AeroElectric-List: Essential Bus question
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Bill,
I don't know what was available when you designed your system. Grand Rapids recommends http://www.tcwtech.com/IBBS.htm for backup battery, and TCW says it is also suitable for backup of G430.
Dynon offers its own backup battery managed by the EFIS software to takeover at 12.3 volts.
I get the need for airways and not wanting to re-enter flight plan after start, or wait to after start to do it with the price of gas.
There is also a voice activated add on for the 430 for data entry that Knows airways.
What I "get" is the desire to keep electrical system as simple as possible as the primary means to reduce failure points. If reboot becomes a problem with my GTN 650, I will add a TCW unit.
I'm just not a fan of dual bus, dual alternator, dual battery systems, but we are OBAM so we can make our own choices and argue with anyone who chooses differently. Wink
Exactly - That's why I drew the system that I posted about a week ago (see attached PDF). Single bus, single alternator, simpler...
--> AeroElectric-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Sorry about adding to this rather old discussion but I've been away for awhile.
I finished my RV10 in 2011 which means that I designed my electrical system and panel around 2008 for a 2009-2010 build.
I have 3 GRT HX EFISs - 2 aimed at the pilot, 1 at the passenger. They supply synthetic vision, moving map, weather, traffic and a complete suite of engine stats. No light weight backup batteries can be configured at the factory with these systems. These screens have no integral on/off switch. I chose not to add any switches or operable CBs. They come on with the master and will usually reboot when my IO540 cold starts with a single, fresh PC 680 battery.
I am a serious traveler with this machine and practically all flight are on IFR plans. My normal routine for all flights is to file my plan using Foreflight on an iPad. Whenever at an airport with clearance delivery, or when departing into IMC conditions, I obtain my clearance on the ground, before engine start, and enter it into my iPad and then into my G430. Many times in congested areas, this entry is followed by no small amount of study. As my aging mind continues to fog over, I'm finding that the study time grows.
Here's the challenge on G430 based panels; it loses any entered flight plan when powered off. An engine start that reboots my GRTs, reboots my G430.
An acute challenge on 430 based panels when used for flights around the Wash DC area or for flights along Florida's Atlantic coast is that the G430 does not know what a Victor airway is. These are flights I make regularly and clearances in these areas typically still include Victor airways. So in the routine described above, entry into the iPad generates the necessary waypoints to any Victor airways. Accurate entry of these waypoints into the G430 is important and there's no way I want to redo the work.
As Bob would put it, this is the 'kitchen sink' I choose to fly with. I think it's fantastic and works very very well for me. It's now a well grooved swing. The inability of some (e.g. Bob, not necessarily you Kelly but I did choose to respond to your post) to 'get' this requirement for this pilot, seems to me is just an inability to see past old school experience or perhaps your current pleasure flying routines.
I have a Z-14 with 2 batts, 2 alts, and 2 buses and I REALLY like it. I bring up the 'kitchen sink' on one battery, get my clearances, enter them into my systems, study my departure plan when doing complicated airspace or low IMC departures and then bring up the 2nd battery bus, cross link them and start my engine.  Everything stays up. Before takeoff I've learned, per Bob, to de-link the buses and off I go.
Per Bob, I've eliminated any semblance of an avionics bus, extra switches or CBs. After a few operational adjustments and refinements (Thanks Bob!), the 'overkill' of a Z-14 has given me exactly what I think I need.
I need my avionics on before start and I have a big kitchen sink that takes care of the dishes just like I want them done. So can we please stop dismissing this approach to equipping and traveling in our very fine OBAM aircraft  within the user fee free ATC system we have? Some of us do it every day because that's the way we choose to roll.
PS: I've been out of the loop island hopping the Bahamas. Recommend it highly.  What an adjustment flying VFR from place to place! However, I still used the same procedures because that's what standard procedures are for.
N215TG
> Virtually all glass have their own light weight backup batteries so do not have startup brown out issues unless no backup battery is installed.
> While one needs engine instrumentation prior to and during start, one does not need avionics on.
> Of course newer avionics that allow faster input of flight plans than the 430 help, if that is the reason for turning on 430 before start.
_-========================; http://forums.matronics.com</ -Mats.com/contribution" =======
PowDist01.pdf
 Filename:  PowDist01.pdf
 Filesize:  38.18 KB
 Downloaded:  316 Time(s)
PostPosted: Sat Feb 08, 2014 4:14 am    Post subject: Essential Bus question Reply with quote
I don't know if the TCW product was available when I was panel building in the 2008-2010 timeframe but I never saw or heard any recommendation from GRT about the TCW backup battery. They certainly were having "brown out issues" with the HXs because we found that they don't like to have their boot processes interrupted by loss of power incidents, which in my case became every single start in low temps. They should have bought TCW's unit and made it a recommended option but I think they were busy working on the newer EFISs. In fact, I recently added TCW's IPS (Power stabilizer) to my (3) units and the G430 and that did the trick without adding any additional batteries to maintain.
Kelly, I apologize for jumping on your post and accept your statement that you are not a fan of dual bus, dual alternator, dual battery systems (though you don't exactly explain why). The simplicity and symmetry of the Z-14 is what attracted me in the first place. I still have trouble wrapping my mind around the essential bus and how I would apply it to my 'kitchen sink' panel without having to add switches so I could perform triage on my triad of GRT EFISs. Or adding a little Dynon or something as a backup. Just what I needed was another brand of EFIS to learn to operate. To me, those approaches add operational complexity and additional failure points but I could be wrong.
But what got me is that you didn't express a distaste for the Z-14, which I accept. Instead your post inadvertently dismissed the very way I operate my aircraft by saying:
Virtually all glass have their own light weight backup batteries so do not have startup brown out issues unless no backup battery is installed. (not GRT HXs)
I see very little value in being able to turn on GPS prior to start. (I need the G430 prior to start, perhaps independent of the GPS. I need at least one EFIS to see my engine instruments. Having the Navworx ADSB up for weather is nice too so I can time my departure around those Gulf Coast thunder bumpers, but the G430 is the problem)
While one needs engine instrumentation prior to and during start, one does not need avionics on. (I do unless I want to switch out 1 or all of my 3 EFISs - talk about a additional points of failure on a critical instrument)
Of course newer avionics that allow faster input of flight plans than the 430 help, if that is the reason for turning on 430 before start. (It is but perhaps I should upgrade or at least get Siri (!!??) for my G430)
I guess you can see my feathers remain ruffled. Sorry for continuing the 'argument' but as you said we make our own choices and can argue with anyone who does differently.
Honestly Mr Nuckolls is the guy who puts my nose out of joint with the "kitchen sink" stuff. Just as Bob and this list has enabled me to design and build my dream traveling machine, I feel the need to defend all that has been enabled. Bob, I love you man! I value your advice, counsel and guidance above all others. This list and the people on it, especially folks like Kelly, are to die for. Just please stop calling my panel a "kitchen sink". I promise I'll upgrade it, pare it down and streamline it with some excess $$$$ the next time I see the opportunity to do it.
But I'll probably keep the Z-14 so when someone runs across the ramp to tell me I left my master on, I can shrug my shoulders and say "no problem, I've got a Z-14 and enough juice to run it for another 20 minutes and still start it up and get out of here". Not a requirement but I enjoy it nonetheless.
Thanks for letting me vent... feel free to return the favor. And thanks for taking the time to respond.
Bill "I REALLY like my panel" Watson
On 2/7/2014 9:32 PM, Kelly McMullen wrote:
[quote]--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
Bill,
What I "get" is the desire to keep electrical system as simple as possible as the primary means to reduce failure points. If reboot becomes a problem with my GTN 650, I will add a TCW unit. I'm just not a fan of dual bus, dual alternator, dual battery systems, but we are OBAM so we can make our own choices and argue with anyone who chooses differently. Wink
Kelly
--> AeroElectric-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com> (Mauledriver(at)nc.rr.com)
N215TG
Checked by AVG - www.avg.com
02/07/14
PostPosted: Sat Feb 08, 2014 9:06 am    Post subject: Essential Bus question Reply with quote
Did I use that term . . . can you cite the posting?
I'm sorry if you've found my contributions trying . . .
but my friend . . . it's my job.
I'll tell you a story . . .
About 30 years ago I was enjoying attendance at one
of Wichita's signature community events every fall;
the annual chili cook-off. These were (and I think
still are) vigorously contested events. The winners
are chosen by counting the chill beans in a jar
on the table at their cook-site in the park.
Everyone who buys a ticket for the event is given
a little bowl, an official tasting spoon and access
to all the crackers they want. They also receive 10
beans to be dropped in what ever combination they
choose into the contestant's jars as a means of
voting by the tasting public.
The caveat was that the top three winners had to
post their recipes. I think the idea was that whoever
won the coveted slots next year were thus encouraged
not to have an identical or even largely similar
recipe.
I recall one winner's posting having probably the
most complex recipe for ingredients I had ever seen
. . . particularly in the range and ratio of spices.
I asked the chef how he arrived at the necessity/
value for the ingredients. I don't recall his answer
except that it wasn't very satisfying. I then
hypothesized about his perceived ability to sample
his work from two pots except that one ingredient
would be eliminated from one of the pots. Did he
think he could separate the altered batch from
the golden batch. He allowed as how he could.
I wish I had copied down the recipe. Needless to say
his assertion was the source of no small degree
of skepticism. I think it was Thomas Paine who
extolled the virtues of simplicity as being less
likely to become disordered and more easily set
right if it should become disordered.
I view my best contribution to the List in the
role not unlike that of my most cherished bosses
over the years who were also fond of Mr. Paine's
sentiments.
The simplest, lightest, least expensive solution
to meeting design goals was the watchword. I can't
tell you how many design reviews presented my
work in front of a half dozen or more of my peers
who were well armed with questions that produced
some combination of three answers (1) the feature
doesn't work, (2) the feature is unnecessary or (3)
there's too many parts that drive up cost of
ownership and dilutes value. All of the critics
were armed with the customer's specification
document.
Those were never an activity to be feared or
distrusted. What ever came out of the meeting was
either 'golden' or blessed with suggestions
for useful change.
So yes, I may well give you a 'bad time' asking
for justification and foundation for use of a
particular part or architecture . . . with the
same spirit and intent which I enjoyed over the
years . . . a spirit and intent that persists to
this day.
Woke up this morning at 5:30 with an epiphany
on a design problem I've been stirring in my head
for a couple of weeks. I'm pretty sure my colleagues
will approve . . . kicked a bunch of parts off the
bill of materials (and a few hundred lines of code
off the DO178 barge). I'll go see if they can poke
any holes in it next week.
If getting you little bent is a risk, I'll accept
that. In the final analysis, what ever you decide
to do poses little risk. You could produce an
architecture that's simply pleasing to look at and
fun to talk about. Used to see lots of those systems
at OSH every year. Jim Bede's electrical honcho on
the BD10J tried to enlist my services on such a
project. Everything that happens to your design
based on input from myself or others probably
moves toward minimizing disorder and maximizing
utility. That's a good thing.
PostPosted: Sat Feb 08, 2014 3:25 pm    Post subject: Essential Bus question Reply with quote
On 2/8/2014 12:05 PM, Robert L. Nuckolls, III wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> (nuckolls.bob(at)aeroelectric.com)
Well here is the one I remember:
[b]Match:#6Message:#58841Date:Jul 08, 2013From:"Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>Subject:Re: Low voltage indicator with dual alternators
[/b](snip)
However, I normally start with the buses separated because if I go
parallel, the voltage drop causes my 3 MDFs to re-boot.
How much 'stuff' do you have to turn on before engine
start? On the Beech products we used to offer a mini-ebus
switch that would let you fire up a comm radio directly
from the battery. Your comm radio probably needs 0.2A receive,
and maybe 1.5A transmit. A long winded pre-flight activity
might need 1000 watt-seconds.
I'm thinking that the bus from which all your 'kitchen
sink' accessories is powered also powers the comm radio
and you have no way to power up the comm radio independently?
You might want to consider moving a comm radio to a
battery bus and adding . . .
I hesitate to point out that you use the term generally to describe electro-whiz intensive panels but no matter.
And I'm on this list because you do it so well. No harm, no foul Mr Nuckolls!
Kellym
PostPosted: Sat Feb 08, 2014 4:52 pm    Post subject: Essential Bus question Reply with quote
I don't know about a GNS-430, but the GTN-650 I have uses around 2.8
amps for the nav side and maybe .8 for the com side when in receive mode.
My Dynon Skyview screens use about 3 amps each. My SL-30 is under 2 amps
in receive mode for com and nav together. So the governing draw will be
how much current the EFIS needs and how much the certified GPS needs.
It seems odd that a certified GPS doesn't let you program and save a
flight plan in non-volatile
memory as most portable GPS units allow. If it doesn't, then an
isolated backup battery powering just the essential items would seem to
be required.
My antique Northstar M3 GPS allows storing flight plans as long as the
soldered in keep alive battery is good. (no longer is).
*Match:* */#6/*
*Message:* */#58841/*
*Date:* */Jul 08, 2013/*
*From:* */"Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>/*
*Subject:* /*Re: Low voltage indicator with dual alternators
<http://www.matronics.com/searching/getmsg_script.cgi?INDEX=115279638?KEYS=kitchen_sink?LISTNAME=AeroElectric?HITNUMBER=6?SERIAL=15121118825?SHOWBUTTONS=NO>*/
*(snip)
go >parallel, the voltage drop causes my 3 MDFs to re-boot. How
much 'stuff' do you have to turn on before engine start? On the
Beech products we used to offer a mini-ebus switch that would let
you fire up a comm radio directly from the battery. Your comm
radio probably needs 0.2A receive, and maybe 1.5A transmit. A long
winded pre-flight activity might need 1000 watt-seconds. I'm
thinking that the bus from which all your 'kitchen sink'
accessories is powered also powers the comm radio and you have no
way to power up the comm radio independently? You might want to
consider moving a comm radio to a battery bus and adding . . .
*I hesitate to point out that you use the term generally to describe
Nuckolls!
Kelly McMullen
KCHD
tim2542(at)sbcglobal.net
PostPosted: Sat Feb 08, 2014 6:00 pm    Post subject: Essential Bus question Reply with quote
The 430w will allow storing a limited number of flight plans, IIRC 10, but if not using it again I hesitate to replace one of the ones I do use frequently with one I won't use again.
On Feb 8, 2014, at 4:51 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I don't know about a GNS-430, but the GTN-650 I have uses around 2.8 amps for the nav side and maybe .8 for the com side when in receive mode.
My Dynon Skyview screens use about 3 amps each. My SL-30 is under 2 amps in receive mode for com and nav together. So the governing draw will be how much current the EFIS needs and how much the certified GPS needs.
It seems odd that a certified GPS doesn't let you program and save a flight plan in non-volatile
memory as most portable GPS units allow. If it doesn't, then an isolated backup battery powering just the essential items would seem to be required.
My antique Northstar M3 GPS allows storing flight plans as long as the soldered in keep alive battery is good. (no longer is).
> *Match:* */#6/*
> *Subject:* /*Re: Low voltage indicator with dual alternators <http://www.matronics.com/searching/getmsg_script.cgi?INDEX=115279638?KEYS=kitchen_sink?LISTNAME=AeroElectric?HITNUMBER=6?SERIAL=15121118825?SHOWBUTTONS=NO>*/
> *(snip)
> consider moving a comm radio to a battery bus and adding . . . *I hesitate to point out that you use the term generally to describe electro-whiz intensive panels but no matter.
PostPosted: Sun Feb 09, 2014 4:49 am    Post subject: Essential Bus question Reply with quote
.. And it's kind of awkward to store, retrieve and managed stored plans on them. I tried doing that to get around the problems I was having but I kept screwing the button pushing up. Now I don't use the feature at all.
I'm thinking that the GNS-430 is getting a bit long in the tooth and
clearly doesn't have some features that one would want though I'm happy
that it doesn't have an internal battery. I had an old Becker comm
radio with an internal battery for saved frequency storage and all it
means is that periodic shop service is required. G430s will be laying
around some panels for a very long time....
To the G430s credit, it doesn't consume a lot of power and is tolerant
of low voltage during starts and such. It takes a lot to get it to
re-boot. I used 2.1 amps for planning purposes with 6.0 amps when
transmitting.
But my 3 EFIS screens were power hogs. I assumed 4.5 amps in aggregate
plus 1 amp for the dual AHRS. I chose to have them come on with the
master and not have a separate switch or switches.
Bill "thanks to Bob and the list the panel works as desired now" Watson
>> *Match:* */#6/*
>> *(snip)
Page 2 of 2
