tonyrenshaw268(at)gmail.c Guest
Posted: Fri Feb 14, 2014 3:53 am Post subject: 914 battery location. |
Gidday,
In the process of deciding if my 914 powered conventional undercarriage Taildragger should or will need the battery to go down the back, beside the tail plane counterbalance containment tower. If not, I can use the mount that I have built back there for a Trigg transponder remote unit mount. Also, in the not too distant future if I decide on putting the battery back there, well I'll need to run big cabling too before my top goes on, hopefully mid year. Any thought much appreciated.
Tony Renshaw
Sydney Aussie
rparigoris
Posted: Fri Feb 14, 2014 8:35 am Post subject: Re: 914 battery location. |
Hi Tony
My XS mono has a 914. It also has a Airmaster CS prop and second B+C alternator.
On a mono ground handling is much improved if you are not near the forward CG.
I chose to put a Odyssey PC545 way aft mounted:
http://www.europaowners.org/main.php?g2_itemId=30710
with #4 copper clad aluminium wire.
I calculated and you save just about one pound using #4 copper clad aluminium over #4 copper.
One downside to aluminium clad wire is it work hardens very easy and the strands are larger than #4 tefzel wire. Thus bend it and it breaks a lot easier. Think gentle bends and good strain relief.
I also added weight to the front of my stabilators that will reduce load to the drive pins and weight required on the mass balance arm by ~ 15%. Thus 3 pounds of weight only cost me 2.2 pounds. This negates needing to add dead weight to the sternpost.
Ron Parigoris
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Fri Feb 14, 2014 9:23 am Post subject: 914 battery location. |
Hi Tony, do as much as you can before you glue the top on that's forward and
aft , I spent a month doing the interior fitting carpet, side panels etc and
putting the head lining in was an absolute bugger.
I have my battery fitted in the back under the luggage floor on starboard
side with Trigg transponder on the port. Access to both is important and
easy. I used 4 gauge wire to the firewall, and have no problems so far.
Best of luck
Richard
Posted: Fri Feb 14, 2014 12:33 pm Post subject: 914 battery location. |
Hi Richard,
Thanks for that. I have made a shelf for the battery under the Stbd floor stowage of the baggage bay, if I commit to it, but had not thought of needing access to the transponder unit so was going to keep it down the back with the antenna, and keep the high power cable run short between antenna and unit. Re the battery, it seems like I either consider a lead acid sealed cell battery like my Odyssey PC 680 at 7 kg on the pax footwell, or under baggage bay floor, or I could use a Lithium Polymer Haijiu at less tha 1 kg up front on the footwell. Because I have the 914 and electric fuel pumps, I could even have a dual battery setup at less than 2 kg! The Haijiu another builder has used to crank his 912 S for 4 years.
Tony Renshaw
Sydney Aussie
[quote] On 15 Feb 2014, at 4:22 am, "richard" <rcollings(at)talktalk.net> wrote:
Hi Tony, do as much as you can before you glue the top on that's forward and aft , I spent a month doing the interior fitting carpet, side panels etc and putting the head lining in was an absolute bugger.
I have my battery fitted in the back under the luggage floor on starboard side with Trigg transponder on the port. Access to both is important and easy. I used 4 gauge wire to the firewall, and have no problems so far.
Best of luck
Richard
Posted: Fri Feb 14, 2014 1:18 pm Post subject: 914 battery location. |
Tony, Although I agree entirely with doing as much as you
sensibly can before sticking the lid on, I would not
include battery fittings in this. It is more convenient by
far and saves a deal of weight if your battery can be
fitted forward (i.e. against the firewall above passenger
feet, where it needs only minimal strapping & structure to
fix it). The notion of delibrately looking to have an aft
C of G seems to me misguided - the further aft the more
readily a plane will spin. Where you need your C of G to
be is where any possible loading ofsmall pilot/big pilots;
full fuel/no fuel; full luggage/no luggage still leaves
within limits. I would advise leaving deciding on battery
location until you ve done a trial weighing with other key
components including paint completed. By all means work
out how you will run wiring and solidly fix battery in
either location, but do not commit. For what it is worth
my mono/914/Woodcomp wobbly prop has worked out extremely
well with a forward battery.
Regards, David Joyce, GXSDJ
On Sat, 15 Feb 2014 07:31:57 +1100
Hi Richard,
Tony Renshaw
Sydney Aussie
> Best of luck
> Richard
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sun Feb 16, 2014 7:54 am Post subject: Re: 914 battery location. |
Tony, I agree with David Joyce and furthermore while my aircraft was a mono-wheel for 16 years, I did temporarily move the battery from the engine bay to inside the rear fuselage. My old classic has the baggage bay bulkhead further forward.
I and three experienced friends who share my aircraft all agreed that having the C of G further aft was a mistake, because the tendency to swing off runway direction on landing was noticeably worse.
Having the original very direct steering tail-wheel under the fin gave us immediate feedback to directional control issues on the ground, which can be masked by the springy links in the more recently extended tail-wheel design.
I know this for sure because I did the first test flights for a friend's 914 mono-wheel aircraft and have flown it for several hours subsequently. Please take the advice to keep the C of G mid-range or a little forward. You won't risk it nosing over when applying the brake as long as you keep the stick fully back. The tail-planes are very powerful.
Posted: Sun Feb 16, 2014 3:03 pm Post subject: 914 battery location. |
Makes sense Tony,
but make sure you get the full 13deg. up elevator.
Graham
Sent: Sunday, 16 February 2014, 15:54
Subject: Re: 914 battery location.
--> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
http://forums.matronics.com/viewtopic.pmatronics.com/Navigator?Europa-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Posted: Mon Feb 17, 2014 1:29 am Post subject: 914 battery location. |
Tony, Have just got back from skiing to be able to lay
hands on my C of G data:
I adjusted my C of G to be at 59" AOD and that
allows any combination of pilot wt 120 to 400lbs/ Fuel 0
to 110 lbs/ baggage 0 to 80 lbs to give C o G within the
58 - 62.5" range. The precise calculations will depend on
your empty wt ( that is a heavy pilot will not shift the C
o G so far in a heavy plane). It means that I never have
to do any calculations of wt & balance and do not risk
flying out of safe balance range. So I would suggest 59"
is an ideal figure to aim at, and would be interested to
hear any contrary views.
Regards, David
On Sun, 16 Feb 2014 22:59:53 +0000 (GMT)
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
| Quote: | Makes sense Tony,
Graham
<jdmilbank(at)yahoo.co.uk>
further forward.
design.
are very powerful.
http://forums.matronics.co=
-Matt Dralle=========
