Linear Actuator Position
1james.baldwin(at)gmail.c
PostPosted: Mon Feb 24, 2014 6:55 pm    Post subject: Linear Actuator Position Reply with quote
Hey Electronic Guys --
Does anybody have a schematic for a simple circuit to show the position of the wiper on a 10k potentiometer?  The leads are at each end of the resistor and one additional one for the wiper.  I was thinking of a few LEDs that would light up depending on position of the wiper.  Or maybe something that would light up when the actuator was centered.  I also have a GRT EFIS if that could be used instead if anyone knows how.  Thank you for the help.
bakerocb
PostPosted: Tue Feb 25, 2014 5:22 am    Post subject: Linear Actuator Position Reply with quote
2/25/2014
Hello James Baldwin, Are you expecting this simple circuit to also include how to create an indicator or display? There are already indicators in existence that require only simple wire connections.
1) See here:
http://www.firgelli.com/Uploads/Pos%20datasheet.pdf
at this home page:
http://www.firgelli.com/products.php
2) See here:
http://www.rayallencompany.com/products/indsens.html
with this wiring instruction:
http://www.rayallencompany.com/RACmedia/instructionsRP3.pdf
at this home page:
http://www.rayallencompany.com/products/servos.html
I think that any ohm differences between your actuator and the indicators can either be rather easily overcome with help from some electrical guru or just ignored with the indicator still working effectively.
OC
PS: What linear actuator are you using and for what purpose? I have a few spare actuators that may be of help.
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Time: 06:55:51 PM PST US
Subject: AeroElectric-List: Linear Actuator Position
for the help.
kuffel(at)cyberport.net
PostPosted: Tue Feb 25, 2014 1:33 pm    Post subject: Linear Actuator Position Reply with quote
James,
<< schematic for a simple circuit to show the position of the wiper on a 10k potentiometer >>
At $20, the 10 segment Firgelli indicator mentioned by Owen Baker is hard to beat. It appears to be "smart" in the sense it measures absolute voltage, not voltage relative to the buss value. This means the 10k potentiometer needs to be fed with a constant voltage such as provided by an LM7805 IC regulator.
If you insist on building a simpler display the attached 5-level indicator uses less than $5 in parts.
Tom
5WayComparator.pdf
 Filename:  5WayComparator.pdf
 Filesize:  27.92 KB
 Downloaded:  502 Time(s)
samdenson
PostPosted: Sat Jun 13, 2015 12:19 pm    Post subject: Re: Linear Actuator Position Reply with quote
here 2 good companies where you can try to search actuators you need 1) http://www.progressiveautomations.com/linear-actuators 2) http://importer.ec21.com/24v_linear_actuator.html. I perfer PA company because of quality, but some my friends like import. As for last one - Ive bought just 1 from them. Works good.
