dsingleton
Joined: 19 Feb 2014 Posts: 12 Location: Monrovia, Indiana
Posted: Sun Mar 02, 2014 9:50 am Post subject: Jacking up a Pulsar XP |
Any thoughts, ideas or procedures?
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
_________________ Dennis Singleton |
lwheat2083
Joined: 03 Jan 2014 Posts: 33 Location: Moses Lake, Washington
Posted: Sun Mar 02, 2014 10:52 am Post subject: Jacking up a Pulsar XP |
I have a Pulsar III and the way I do it to support the mid wing with a saw horse that is heavily padded. It is easy to lift one at a time with two people. Seems to work for me. Cheers, Larry
everettmcollier(at)yahoo. Guest
Posted: Sun Mar 02, 2014 12:16 pm Post subject: Jacking up a Pulsar XP |
It depends on why you are wanting to lift it up. If you just want to change a tire, a padded plywood plate under the wing spare or even a block of wood under the end of a main gear leg works. If you want to work on the gear itself, the original slings used in the build would be best.
Everett
Sent from my iPad.
mortweaver(at)sbcglobal.n Guest
Posted: Sun Mar 02, 2014 12:22 pm Post subject: Jacking up a Pulsar XP |
I jack up my XP using an approx. 30 inch length of 2X4 as a pry bar under a gear leg end. Upon lifting the gear leg, I then slip another wood block under the 2X4 end that is supporting the gear leg to hold the vertical position. If I want to go higher, then I lift the 2X4 end I am holding enough to slip a thin block of wood in place (build up the height of the fulcrum). I can then take it up higher as required...the 2X4 pry bar stays in place as one of the shims supporting the weight on the gear leg. It is quick with no other person needed.
Dave Weaver N912GR
To: pulsar-list(at)matronics.com
Sent: Sunday, March 2, 2014 9:50 AM
Subject: Pulsar-List: Jacking up a Pulsar XP
--> Pulsar-List message posted by: "dsingleton" <dsingleton(at)aol.com (dsingleton(at)aol.com)>
Dennis Singleton
http://forums.matronics.com/viewtopic.php?p=419643#419643http://www.matronics.com/Navigator?Pulsar-Li> [quote][b]
pulsar1(at)sbcglobal.net Guest
Posted: Sun Mar 02, 2014 2:04 pm Post subject: Jacking up a Pulsar XP |
My wheel pants cover the end of the gear leg so I made a two piece wood block with the center cut out that conforms to the gear leg cross section just above the bend that goes down to the axel mount. The blocks fit around the gear leg, one on top the other on the bottom. They are held together with two 3/8 inch bolt and wing nut, one in front and one in back, makes it easy to put on and tighten with no tools. I padded the inside of the cut out to protect the paint. The bottom piece is sanded flat, parallel to the ground. I use an inexpensive bottle jack under the bottom piece to jack the plane up. The blocks will work on either side since the shape is the same.
To: "pulsar-list(at)matronics.com" <pulsar-list(at)matronics.com>
Sent: Sunday, March 2, 2014 12:21 PM
Subject: Re: Jacking up a Pulsar XP
I jack up my XP using an approx. 30 inch length of 2X4 as a pry bar under a gear leg end. Upon lifting the gear leg, I then slip another wood block under the 2X4 end that is supporting the gear leg to hold the vertical position. If I want to go higher, then I lift the 2X4 end I am holding enough to slip a thin block of wood in place (build up the height of the fulcrum). I can then take it up higher as required....the 2X4 pry bar stays in place as one of the shims supporting the weight on the gear leg. It is quick with no other person needed.
Dave Weaver N912GR
Subject: Jacking up a Pulsar XP
Dennis Singleton
dsingleton
Posted: Sun Mar 02, 2014 2:55 pm Post subject: Re: Jacking up a Pulsar XP |
Thanks everyone. Found the 2x4 with a block worked well and I could do it myself. But I do believe I am going to make a 2 piece Jacking block as described.
kdpalmer(at)mweb.co.za Guest
Posted: Sun Mar 02, 2014 7:28 pm Post subject: Jacking up a Pulsar XP |
Try a home car trolley jack they go quiet low & jack one leg at a time
