kelmonroe(at)comcast.net Guest
Posted: Tue Mar 18, 2014 2:00 pm Post subject: Coil lead and Air Speed Indicator conversion. |
I am in need of the high tension lead wire from the starting coil to the left mag on my CJ. The engine I removed was converted to auto plugs and the wire was removed.
I also need a shop to send the air speed indicator out to, to be refaced to knots. Any help would be appreciated. Thanks Kelley
Posted: Tue Mar 18, 2014 2:17 pm Post subject: Coil lead and Air Speed Indicator conversion. |
Kelley,
Here's a link where you can purchase the 7mm wire you need for the starting coil.
http://www.mfgsupply.com/24-8775.html
As far as refacing the airspeed indicator, there are many instrument shops in the Wichita, KS area that may be able to do that for you. Just Google up "instrument repair shops" and give one a call.
Dennis
To: Yak-list(at)matronics.com
Sent: Tuesday, March 18, 2014 5:00 PM
Subject: Coil lead and Air Speed Indicator conversion.
[quote]http://www.matronics.com/Navigator?Yak-Li="nofollow" target="_blank" href="http://www.matronics.com/contributi==
Posted: Tue Mar 18, 2014 3:25 pm Post subject: Coil lead and Air Speed Indicator conversion. |
I also need the shielding with the nuts to attach to the coil and the mag.
Posted: Wed Mar 19, 2014 5:20 am Post subject: Coil lead and Air Speed Indicator conversion. |
Try Doug Sapp. That I can't help you with.
| Quote: | A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1 | On 3/18/2014 6:24 PM, Kelley Monroe wrote:
[quote] I also need the shielding with the nuts to attach to the coil and the mag.
