Doug-Missouri
Posted: Wed Mar 26, 2014 1:59 pm Post subject: Local MKIII Owners Southeastern Missouri |
I am a new MKIII owner and looking for tips and tricks especially for the cage of the plane. Currently the plane is apart and before I recover the cage I would like to look at others that have been built hopefully locally for any and all ideas. Gas tank, storage, seats.......ect. So if anyone happens to know of a MKIII close to the boot heel of Missouri or would like to offer advice please do so.
I am new to the forum as of today and this is also my first post.
Doug
rickofudall
Posted: Wed Mar 26, 2014 2:45 pm Post subject: Local MKIII Owners Southeastern Missouri |
Doug, Do not fail to cover the wing to wing frame directly under the engine. I had a plane in the shop that the original builder had omitted this. Covering it DOUBLED the climb rate of the aircraft.
Rick Girard
On Wed, Mar 26, 2014 at 4:59 PM, Doug-Missouri <cincro(at)yahoo.com (cincro(at)yahoo.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Doug-Missouri" <cincro(at)yahoo.com (cincro(at)yahoo.com)>
Doug
http://forums.matronics.com/viewtopic.php?p=421088#421088
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
gajindra(at)sbcglobal.net Guest
Posted: Wed Mar 26, 2014 3:10 pm Post subject: Local MKIII Owners Southeastern Missouri |
Check out Moeller below deck fuel tanks for boats. Sure looks like there is a big selection and one could fit in before covering. Increase in fuel capacity would sure be nice for longer trips. It's the one change I wish I would have made.
Gary Jindra
Mark 3 Rotax 912 80 hp. 190 hours
Sent: Wednesday, March 26, 2014 5:59 PM
Subject: Local MKIII Owners Southeastern Missouri
Doug
--> http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Doug-Missouri
Posted: Wed Mar 26, 2014 4:59 pm Post subject: Re: Local MKIII Owners Southeastern Missouri |
Thank you both very much those tips are exactly what I need to know!
Thank you!
Posted: Wed Mar 26, 2014 5:11 pm Post subject: Local MKIII Owners Southeastern Missouri |
Pull up the Matronic Archives. You can dig around in there and find a lot
of Kolb stuff.
http://www.matronics.com/search
Thank you!
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Thu Mar 27, 2014 4:30 am Post subject: Re: Local MKIII Owners Southeastern Missouri |
You will find lots of good ideas in the archives. Here are some things that have worked very well for me.
http://www.bcchapel.org/pages/0003/kolb.htm
I need to do some updating - redid the doors this winter, changed the switch panel, new landing gear, etc, so need to take some pictures and do some updates to this page.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Thu Mar 27, 2014 1:01 pm Post subject: Re: Local MKIII Owners Southeastern Missouri |
Doug,
I have a Mark III X-tra that your welcome to check out if you wish. It would be somewhat of a drive for you as it's in a hanger in Branson West (not Branson).
Rex
Doug-Missouri
Posted: Thu Mar 27, 2014 4:21 pm Post subject: Re: Local MKIII Owners Southeastern Missouri |
Thank you Richard, I have actually been to your Web page several times and like all the info you have placed there!
Rex, That is quite a drive from Poplar Bluff I was told today that a MKIII classic is in Jonesboro so I may look at it while attending an EAA meeting. With any luck we may be able to fly and see you some day!
