Chillyz
Posted: Mon Mar 31, 2014 2:50 pm Post subject: Heat Muff and Heat Box Install |
Currently working in the cockpit area. Has anyone installed a heat tri-box and heat muff from Aircraft Spruce? Wanted to bring some heat into the cockpit. I have the Rotax 912S installed. The diameter of the exh pipes are 1.25" but notice that the heat muff from A/S will only fit down to 1.75". I'm sure I can build up the gap with shim material. Any thoughts or ideas?
mjb777
Posted: Mon Mar 31, 2014 10:49 pm Post subject: Re: Heat Muff and Heat Box Install |
I strongly recommend that you contact Sonja Englert, caro-engineering(dot)com, and get details of her very simple, but apparently very effective, cabin heat setup.
It is very simple to build, and there is no headache with the very limited space available around the exhaust or in the cowls.
It doesn't take up any space in the engine compartment at all and will cost you a fraction!!
Matt.
_________________ Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer. |
