		uvtreith(at)t-online.de Guest
				 Posted: Tue Apr 08, 2014 10:48 am    Post subject: Fuel Tank Space |
				Hi Family,
 We will change a Classic Monowheel into a Classic TriGear with toe brake system.
 Now my question: Is it possible and/or already done, using the empty space from the Tundra Wheel for an secondary fuel tank?
 Have a nice time and safe flights.
 Best Regards,
 Bruno Reith
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Apr 08, 2014 11:51 am    Post subject: Fuel Tank Space |
				Hi! Bruno,
 For my opinion I don’t think you could do with the additional weight in front of the wings plus the height at which the bottom of the tank would  deliver fuel into your main tank would be very critical . My 9 gallon Long range tank sits full width across the trike gear leg wells. It did siphon from there satisfactorily but I now have a transfer pump to be sure.
 I have used the wheel space for my fuel pumps and fuel manifold module .
 Bob Harrison G-PTAG
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTREITH
 Sent: 08 April 2014 19:48
 Subject: Fuel Tank Space
 Hi Family,
 Best Regards,
 Bruno Reith
   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  0123456789
		mike.davies210(at)gmail.c Guest
				 Posted: Tue Apr 08, 2014 11:53 am    Post subject: Fuel Tank Space |
				Yes
  Bob Hallam did this in G-CROB a Jabiru 3300 trigear . second filler is on stb side through the parcel tray and out below the screen. The  tank was made from fuel resistant resins/glass. On Apr 8, 2014 7:51 PM, "UVTREITH" <uvtreith(at)t-online.de (uvtreith(at)t-online.de)> wrote:[quote]
 Hi Family,
 Best Regards,
 Bruno Reith
 arget="_blank">http://www.matronics.com/Navigator?Europa-List
 tp://forums.matronics.com
		budyerly(at)msn.com Guest
				 Posted: Thu Apr 10, 2014 4:01 am    Post subject: Fuel Tank Space |
				Bruno,
  Not a bad idea.
  In my experience it is not practical.  Brakes take up a bit of room.  I remove the metal firewall and make a new one behind the nose gear leg and close the area and add an access panel, as has been posted before.  I also add my own park brake valve setup  seen at sun 'n fun. This leaves little space.  The CG is a bit far forward with fuel forward of your knees also.  In a runway departure the nose gear leg has sheared the bolts and entered into the well some six inches so that makes me less than keen on a tank  there.
  On a side note:
  Once my medical experiment is over, I am going to install an 8 gallon tank above the gear wells right against the tank bulkhead in 12AY.  It will be aluminum, use a pump, a proper vent, and fill through a proper cap moulded into the starboard door frame.
  My kids are moving just out of range.  But my bladder may not be large enough to warrant the tank.  But I'll build it anyway.  It measures about 6" x 8" x 36" nominally.  Volume is  about 1 cubic foot.  (I got the idea from auto racing tanks with foam  and bladders for safety.  They are a bit heavy but safe for inside the cockpit.)  It's anchored to the ply braces so it won't go anywhere.
  It will take up baggage room.
  Jerry Hope thought of a belly slipper tank.  Right on the CG.  We just didn't have time.
  Bud
  Sent from my Verizon Wireless 4G LTE DROID
  UVTREITH <uvtreith(at)t-online.de> wrote:
 Hi Family,
 Best Regards,
 Bruno Reith
  	  | Quote: | 	 		  http://www.matronics.com/Navigator?Europa-List
 onics.com
 ww.matronics.com/contribution
