Z13/8 Main Alternator.
MikeDunlop
PostPosted: Wed Apr 09, 2014 6:44 am    Post subject: Z13/8 Main Alternator. Reply with quote
I'm finishing off my electrical system in a Long-EZ that includes the SD-8, exactly as per the Z13/8 and have to make a final choice of the main alternator.
For cost and availability locally I've decided to go with either a Lucas 60amp or 70amp. The advice I'm seeking is regarding the regulator, these units have an internal regulator, so do I keep the internal regulator? (remember the Z13/8 has the OV protection between the regulator and the bus) or do I do a conversion to use a B&C external regulator (I have a spare one I could use).
I've read many, many threads on OV and runaway alternators etc. and am not too sure if using the internal regulator in the Z13/8 architecture will give me complete protection.
Mike Dunlop (UK)
Bill Allen
PostPosted: Wed Apr 09, 2014 9:30 am    Post subject: Z13/8 Main Alternator. Reply with quote
Hi Mike,
So you're nearly finished? Will you be flying this year?
If you come past in May/June Gary Hertzler will be here again for more Ez talk :^)
Bill
On 9 April 2014 15:44, MikeDunlop <mdunlop001(at)aol.com (mdunlop001(at)aol.com)> wrote:
[quote]--> AeroElectric-List message posted by: "MikeDunlop" <mdunlop001(at)aol.com (mdunlop001(at)aol.com)>
Mike Dunlop (UK)
http://forums.matronics.com/viewtopic.php?p=421821#421821
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
PostPosted: Wed Apr 09, 2014 12:15 pm    Post subject: Z13/8 Main Alternator. Reply with quote
Alternators with built in regulators . . . as a GENERAL
rule, DO NOT feature ov protection consistent
with legacy design goals. One exception I'm aware of
is PlanePower who appears to be using a customized
built-in regulator with crowbar ov protection and
positive crew-controlled power to the field.
At the time of this writing, it's the ONLY alternator
offering that conforms to the legacy alternator control/
ov protection philosophy.
I'm not sure if I understand your question . . . The
SD-8 should be installed as shown in the drawing.
Further, its ov protection, control and regulation
is entirely independent of any choices you make for
a main alternator.
If you're contemplating an over-the-counter automotive
alternator with built in regulator . . . it will
PROBABLY perform as advertised. But it will not conform
to the design goals adopted by all TC aircraft and the
majority of OBAM aircraft.
If you have a B&C alternator controller laying around,
it's generally not difficult to modify any stock automotive
machine to accept EXTERNAL power, regulation, and protection.
If you're not up to the task of doing the mod, a local
alternator repair shop may be willing/able to do it
for you.
MikeDunlop
PostPosted: Wed Apr 09, 2014 12:22 pm    Post subject: Re: Z13/8 Main Alternator. Reply with quote
Bill,
Nice to hear from you again, I've called by your hangar a few times but missed you.
Yes I'm hoping to get things wrapped up soon and start the testing phase.
I will definitely like to meet Gary again and talk EZ, I picked up some very useful information last time that made me change the cowling air intake design and the prop attachment method.
Mike
MikeDunlop
PostPosted: Wed Apr 09, 2014 12:31 pm    Post subject: Re: Z13/8 Main Alternator. Reply with quote
Bob,
Thanks very much for the information. I will modify the alternator and use the B&C regulator.
The SD-8 is installed exactly as per Z13/8, totally independent of the main alternator.
Mike (UK)
Bill Allen
PostPosted: Thu Apr 10, 2014 10:07 am    Post subject: Z13/8 Main Alternator. Reply with quote
Yes, I was away Jan/Feb.
I'll be back here much more after Easter as Gary will be here then, so May/June would be a good time - call or text me?
Bill
On 9 April 2014 21:22, MikeDunlop <mdunlop001(at)aol.com (mdunlop001(at)aol.com)> wrote:
[quote] --> AeroElectric-List message posted by: "MikeDunlop" <mdunlop001(at)aol.com (mdunlop001(at)aol.com)>
Bill,
Mike
http://forums.matronics.com/viewtopic.php?p=421841#421841
le, List Admin.
