Posted: Mon Mar 17, 2014 8:41 am Post subject: EarthX lithium |
I just became aware of EarthX batteries based on
comments here on the list. I visited their website
and studied a variety of assertions and comparisons
designed to promote sales. At first blush, these
folks are hanging their marketing hats on the same
philosophy as other suppliers of lithium technologies.
See attached document . . .
The DEARTH of good engineering data for these
products makes it difficult if not impossible to
craft a well considered integration of the current
COTS (commericial off the shelf) offerings onto
airplanes.
I had to delay submission of the last of four
Kitplanes articles for a month . . . not because
theres a paucity of choices . . . but because the
folks selling them can't define performance in
rational numbers. Still digging . . .
 Download |
| Filename: |
FAQs_about_EarthX_Lithium_Batteries.pdf |
183.26 KB |
| Downloaded: |
1102 Time(s) |
Posted: Mon Mar 17, 2014 8:57 am Post subject: EarthX lithium |
Skip,
Had a reader recommend EarthX lithium batteries for airplanes.
Seems they're courting Van's and some other suppliers of
kit aircraft and parts.
Downloaded a page of their marketing pitch. I commented on
it and published it back to my forum.
I'm going to contact EarthX for more information on ENERGY
numbers and a functional description of their 'battery
management system'.
See attached . . .
 Download |
| Filename: |
183.26 KB |
| Downloaded: |
617 Time(s) |
rlborger(at)mac.com Guest
Posted: Mon Mar 17, 2014 9:46 am Post subject: EarthX lithium |
Bob N,
In your commentary on the FAQ. At the end there is a question about deeply discharging the battery. Your comment is “So if I go off and leave the master switch ON, odds are that by the time I get back to fly again, my battery is trash?
I can answer that in one word - YES. Your battery is trash.
If this battery is like the one I purchased to test, it does not have a “BMS” which auto-disconnects to protect cells from over-discharge.
I flew with this battery for several months and did some simple ground testing. Tested things like - How long would it last running all the electrics (EIS, EFIS, radio & transponder), how long just running the EIS, radio & transponder, how long just running the EIS & radio and how long just running the EIS & transponder? After each test I put the high-tech charger on and recharged with the cell balance in effect. I didn’t get to the last of the questions because after the EIS, radio & transponder test I managed to put the charger on but left the Master on as well. When I came back a couple days later to continue the testing the battery was fully discharged and would not accept recharging. It was trashed.
FYI, in testing the battery I found that it would run the whole electrical system about 5 minutes. It would run the EIS, radio & transponder about 7 minutes.
Overall, I was not impressed with the LiFePo battery. It was extremely light and it started my Rotax 914 quickly and easily. After starting the engine and flying for a while, it would be properly and fully charged when back on the ground. Unfortunately, from my limited testing, it didn’t have any real legs to run things on its own and it requires a lot of fancy, high-tech, gear to keep it happy. And take great care not discharge it fully.
Just my 2˘ from my very limited experience.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Mar 17, 2014, at 11:40 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
airplanes.
Bob . . . <FAQs about EarthX Lithium Batteries.pdf>
Posted: Mon Mar 17, 2014 10:18 am Post subject: EarthX lithium |
At 12:46 PM 3/17/2014, you wrote:
--> AeroElectric-List message posted by: Robert Borger <rlborger(at)mac.com>
Bob N,
Which part number of battery did you test?
Good data point . . .
From your limited observations, what would you estimate
the energy content to be for the model you tested? In
other words, what was the demand for the EIS, radio and
transponder? Apparently it would satisfactorily crank
an engine for some time.
I have emailed EarthX requesting the name and address
for an individual who can supply technical date in detail
sufficient to make good system integration choices.
Thanks for the data points!
Bob . . . [quote][b]
Posted: Mon Mar 17, 2014 11:02 am Post subject: EarthX lithium |
Bob N,
LiFePo battery - AeroVoltz 8 Cell Lithium Battery. http://aerovoltz.net/en/
The Sport EFIS consumes about 1 amp according to the documentation. I don’t have good numbers on the GRT EIS4000 but I would allow about 1 amp with all the sensors, back light, display, etc. I may be able to get a better number next trip to the hanger. The radio and transponder are MicroAir M760Q & T2000 SFL. From the documentation, I’d say they each use about 250-300ma with the backlight on and not transmitting.
The battery turned the 914 over very smartly. The engine is easy to start in any case so it wasn’t really working that hard. Three or 4 prop blades and it starts. That’s 2 or 3 rotations of the engine.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Mar 17, 2014, at 1:17 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
Bob N,
Posted: Tue Mar 18, 2014 2:31 am Post subject: EarthX lithium |
At 02:01 PM 3/17/2014, you wrote:
Bob N,
Okay, that's not an EarthX battery which
claims to have a battery management system
built in.
From the physical sizes of these batteries,
I suspect they are assembled from individual
cells not unlike the 26650 styles offered by
A123 and others.
http://tinyurl.com/ktyfbnp
These would be 'rated' at something on the
order of 2.3 to 2.5aH per cell. A 2-row,
8-cell assembly would offer a 12V battery
with a capacity on the order of 5aH. A number
which is inconsistent with your battery
only endurance experience.
Their 16-cell product would have a cell weight
of 75g x 16 or 1.2Kg. Their catalog weight for
the 16 cell product is 1.6Kg which leaves 0.4Kg
for enclosure . . . sounds about right. So
their 16-cell product would clock in with a 10aH
legacy rating and 1.2Kg x 125Wh/Kg or 150Wh
of total energy.
Given the relatively flat discharge curves of
lithium chemistries (low internal impedance) one
might estimate that 125Wh will be available at
a 10A discharge rate. So it seems that the 16-cell
device would run a 100W demand engine for 1.2 hours
when new and 1 hour at end of life.
Let's get some hard numbers on the current draw
for your experiments and see why you didn't get
better performance from your '5aH' product.
Aerovolts doesn't claim to offer an
internal BMS but they do offer the external
BMS charger with words like:
The Aerovoltz Battery Management System Balance Charger is the only charger on the market designed specifically to work with the Aerovoltz battery. The primary advantage to the Aerovoltz BMS Blance Charger is the balance charging function. The Balance mode balances the voltage of each cell or cell pack while charging. By balance charging your Aerovoltz Performance Battery you insure that the battery is operating at its maximum power. Periodic balance charging can also double the expected life of your battery. This charger is not required to operate your Battery, but it is highly recommended.
The only charger made to work with the Battery Management System.
Plugs directly into the batteries BMS port.
Able to balance charge all the cells individually for max power and durability.
Can double the expected life of the battery.
Has Charge, Fast Charge, Balance Charge, and Storage Charge Functions.
Available in 120V (US) and 240V (EUR).
The problem I have with these special chargers is
rooted in the fact that when we put an airplane away,
the battery is generally topped off . . .
It's my understanding that these super-smart chargers
work their magic while recharging a partially to
completely depleted battery. How then would such a
charger benefit the OBAM aircraft owner/operator?
. . . and DOUBLE the life of the battery? THAT'S
a VERY LONG POLE in the tent for cost-of-ownership
for a battery that is already VERY expensive compared
to the device it purports to replace.
Aerovolts also claims:
The 16 Cell has a massive 500PCA and 28 Pbeq AHs at only 3 lbs of weight. The 16 Cell is a direct replacement of the Yuasa YTX30L-BS, GYZ-20HL, and YTX24HL-BS.
The Yuasa YTX30L is a 22 pound, SVLA battery that would
clock in at about 24aH . . . I submit that while the 16-cell
Aerovolts product may CRANK like the Yuasa battery, it is
NOT A DIRECT REPLACEMENT when it comes to keeping the
fires lit up front . . . in fact, it's probably less than
half the capacity of the Yuasa battery.
[img]cid:.0[/img]
We'll keep asking questions . . .
74.58 KB |
8817 Time(s) |
stuart(at)stuarthutchison Guest
Posted: Wed Mar 19, 2014 11:21 pm Post subject: EarthX lithium |
G'day Bob N.
Your comments in the PDF file about battery Ah rating under different
operating conditions reminded me of an interesting annecdote.
About 10 years ago, Energiser began marketing a series of cheap (approx $20)
AA battery powered chargers for cell phones. They are a simple plastic case
(inc circuit) for two primary AA cells, plus a short adaptor cord option for
the various cell phone models. Turns out they come fitted with lithium
cells for good reason.
| Quote: | From spec data sheets at the time, the rating for a standard Energiser
alkaline AA cell was typically around 2700 mAh. The lithium cells were
about 3200 mAh, yet manufacturers quoted 5 to 7 times the endurance for
lithium cells in high power devices. This seemed counter-intuitive given a
similar mAh rating.
In practice, the lithium cells can deliver higher current without the
internal resistance soaring through the roof, so most of their energy is
delivered to the load rather than wasted as heat. It was easily proven by
replacing the AA lithium cells with alkaline cells. The alkaline cells
became too hot to touch and delivered about half a cell phone charge, while
the lithium cells delivered about 2.5 full charges. Conversely, using
lithium cells in a low power device such as a wall clock would offer a very
poor return on investment, given the lithium AA cells cost about 4 times the
price.
Cheers, Stu
Posted: Thu Mar 20, 2014 10:57 am Post subject: EarthX lithium |
| Quote: | . . . using lithium cells in a low power device such as a wall clock would offer a very
price. |
Yeah, your talking about these critters . . .
[img]cid:.0[/img]
They're in the Size 91 package (AA) but offer a lithium-Iron
couple that's in the same ballpark as the carbon-zinc and
zinc-manganese flashlight cells (1.5 volts).
If you compare E91 alkaline cell data
V http://tinyurl.com/nt2x8hd
with the L91 lithium-iron data
http://tinyurl.com/otkeubs
We see that both products are in the same ballpark
for contained energy but the L91 cell internal
resistance is about 1/2 that of the E91. So not
only do you get slightly more total energy, your
access to that energy at high discharge rates suffers
about 1/2 the losses in heat.
This 'lithium' product is a different animal from
the devices we're pondering as replacement for
engine-cranking/standby service. The boss-hogg
lithium cells are 3.3V couples and generally
much lower resistance still . . .
It's unfortunate that characteristic performance
of two cells are not presented in the same pews . . .
suffice it to say that the approx 1/2 internal
resistance will toss off less energy under high
demand loads.
On the Nickle-Metal Hydride side of the house
one may acquire 1.2V chemistry with very attractive
internal impedances . . .
http://tinyurl.com/nj5xx85
At 1.2V vs. 1.5 volts the contained energy
in watt-seconds suffers slightly but they'll
readily deliver their contents at high rates.
Down-side is that the self-discharge characteristics
of Ni-Mh compared to the Lithium-Iron or Zinc-Manganese
cells is pretty sad. Up-side is that you can readily
re-use these cells many times over and their
acquisition costs are nominal.
http://tinyurl.com/nklo97k
Your right, lithium-iron AA cells poor value compared
to other choices . . . unless your design goals
absolutely demand high rate discharge support
AND long shelf life.
Its all in the design goals . . .
49.2 KB |
8795 Time(s) |
Posted: Fri Apr 11, 2014 3:44 am Post subject: Re: EarthX lithium |
There was a recent comparison of a LiFePo battery versus Lead Acid and the test results posted in a graph on VansAirforce.
http://www.vansairforce.com/community/showthread.php?t=111788
It seems that the actual Amp Hour rating of the LiFePo is only half of the advertised rating. Even so, a 36 amp hour LiFePo provides almost the same endurance as a PC680 at less than half of the weight. The author intends to install the LiFePo in his RV-8A. It will be interesting to see if he is satisfied with this battery a few years from now.
Joe
_________________ Joe Gores |
Posted: Fri Apr 11, 2014 5:31 am Post subject: EarthX lithium |
At 06:45 AM 4/11/2014, you wrote:
few years from now.
I missed getting the 4th slot filled on time in
the series of articles on batteries for Kitplanes.
Spent an extra month attempting to engage a number
of suppliers/manufacturers in technical conversations
about their products.
Only one has been eagerly forthcoming (EarthX) and
one other begrudgingly offered tid-bits of the
requested data.
I've offered to work with EarthX to wordsmith
specification and sales literature that would
get them more than a casual glance and fewer
snickers from a TC airframer.
Part IV of the battery articles has been submitted
to Paul Dye. I've discovered a lot about the current
state of LiPo offerings but my inquiries have generated
more questions than answers!
As the thread cited above demonstrates, there's
a good bit yet to be learned about the lithium
battery industry. Encourage folks on the
VansAirForce-list to join us here on the AeroElectric-
List as well.
By the way, that PbEq (lead-acid equivalency) thingy
is pure marketing hype. It speaks to battery impedance
and ability to crank engines . . . says NOTHING about
energy available for battery-only ops.
