schmoboy
Posted: Fri Apr 18, 2014 4:56 am Post subject: AFS 4500 and VP-200 Fuel Qty |
For anyone else out there with a AFS4500 EE and VP-200 combination...
Engine data stream between my AFS4500 EE and the VP-200 is all good
except for fuel qty. For some reason the fuel qty on the VP-200 is
higher. I have 11.0 in Left and 9.0 in Right. The AFS4500 is
calibrated and reading correctly. The VP-200 shows 210 in Left and 190
in Right.
I have the AFS4500 serial out to the VP-200 set as Chelton. I've tried
both AFS3000/3500 and EIS/Chelton as the serial IN setting in the
VP-200. Same issue of in both cases. AFS outputs left tank in Aux 2
and right tank in Aux3 fields of the Chelton protocol. Those config
field in the VP-200 have them as Integer. I've also tried changing
those two to Decimal, which causes the qty to read 21 left and 19 right,
which is closer, but still not correct.
Anyone with an AFS4500EE and VP200 combo that has fuel qty working? If
so can you confirm the Serial Out protocol from the AFS4500 and the
Serial In Protocol on the VP-200 and the Aux fields at the at the bottom
of the Serial Data Association page?
-Sean #40303
Mike Whisky
Posted: Fri Apr 18, 2014 1:26 pm Post subject: Re: AFS 4500 and VP-200 Fuel Qty |
Hi Sean
I have the same combo and didn't notice any difference. However having said this my AF-4500 displays Fuel in Liters and the VP-200 in Gallons. I'll check next time I'm at my plane but that might be a while.
Mike
_________________ RV-10 builder (flying)
#511 |
johngoodman
Posted: Sat Apr 19, 2014 7:24 am Post subject: Re: AFS 4500 and VP-200 Fuel Qty |
Mine is a GRT with VP-200, and I had to put a resistor in-line to get the voltage correct. What is your EIS?
John
_________________ #40572 Phase One complete in 2011 |
schmoboy
Posted: Sat Apr 19, 2014 10:23 am Post subject: AFS 4500 and VP-200 Fuel Qty |
The AFS 4500 EE is an EFIS/Engine monitor combo, so it provides data to
the VP-200 using AVTN/Chelton protocol over serial.
Odd part is that everything but the fuel qty is correct. Had first
engine start today and all the other instrumentation on the VP-200
matched the AFS 4500.
| Quote: | johngoodman <mailto:johngoodman(at)earthlink.net>
April 19, 2014 at 10:24 AM
John
http://forums.matronics.com/viewtopic.php?p=422103#422103
schmoboy
