Cabin door safety latch
bob88
PostPosted: Sat Apr 19, 2014 11:44 am    Post subject: Cabin door safety latch Reply with quote
How do most builders feel about the necessity of installing the cabin door safety latch? How long ago did Vans come out with that, as a lot of the photos I see do not show that it has been installed.
Kellym
PostPosted: Sat Apr 19, 2014 1:12 pm    Post subject: Cabin door safety latch Reply with quote
It has been more than 2 years since Van's came out with the service
bulletin. The first 5 yrs or so they did nothing while a dozen or more
doors came off. IMHO, Van's service bulletin is almost as bad as the
problem. Sean Strasburg engineered a very elegant third latch, in the
same area, that operates with the door handle and is invissible from the
outside.
http://forums.matronics.com/viewtopic.php?p=422113#422113
Kelly McMullen
KCHD
rleffler
PostPosted: Sat Apr 19, 2014 2:06 pm    Post subject: Cabin door safety latch Reply with quote
I couldn't have said it better. Sean's latch works as advertised.
On Apr 19, 2014, at 5:07 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
cooprv7(at)yahoo.com
PostPosted: Sat Apr 19, 2014 2:46 pm    Post subject: Cabin door safety latch Reply with quote
Has anyone installed one of Sean’s systems after painting and putting in the interior? I need to do something like this but really don’t want undo more than necessary.
Marcus
rleffler
PostPosted: Sat Apr 19, 2014 3:34 pm    Post subject: Cabin door safety latch Reply with quote
If I remember correctly, Scott Schmidt installed the latch well after painting. I seem to recall that he documented the process either here or on VAF. You may want to search the archives.
Marcus
Bob Leffler
N410BL - Phase I
PostPosted: Sat Apr 19, 2014 4:29 pm    Post subject: Cabin door safety latch Reply with quote
Thanks, I found some good comments on a new install but still looking for the retrofit. Based on price more than anything, I’m tempted to go with the 90 degree retrofit and new guide pins. Any thoughts from folks on the 180 vs 90 degree setups?
Marcus
Marcus
sean(at)braunandco.com
PostPosted: Sat Apr 19, 2014 4:47 pm    Post subject: Cabin door safety latch Reply with quote
Marcus,
I can send the instructions to your email for the 180 retro and another
email with the 90. They are large files so let me know if you want them.
Around 6.5 mb each.
Also, feel free to call me if you want to chat about your installation.
801-580-3737.
Sean
timrvator(at)comcast.net
PostPosted: Sat Apr 19, 2014 4:50 pm    Post subject: Cabin door safety latch Reply with quote
I'm glad i installed it on my RV-10.
- It is very convenient for temporarily securing door in windy conditions (loading, preflight ).
- It practically guarantees the main latch pins engage properly by first assuring door leading & trailing edges are properly aligned w/ door frame.
Not sure how much it would help if main latch or pins actually failed in flight - have not seen any reports/data on this.
Tim Lewis
RV-10 N31TD 500 hrs
RV-6A N47TD 1100 hrs
A&P
Kellym
PostPosted: Sat Apr 19, 2014 5:05 pm    Post subject: Cabin door safety latch Reply with quote
http://tinyurl.com/ph4ucvb
Is some of Scott's pictures. At the time, his and Sean's plane were in
same hangar (may still be, don't know).
Sean is exceedingly helpful to get you through any head scratching episodes.
Kelly
> Thanks,
> Marcus
> Bob
> Sent from my iPad
Kelly McMullen
KCHD
PostPosted: Sat Apr 19, 2014 5:21 pm    Post subject: Cabin door safety latch Reply with quote
Excellent, thanks!
Marcus
Is some of Scott's pictures. At the time, his and Sean's plane were in same hangar (may still be, don't know).
Kelly
> Thanks,
> Marcus
> Bob
> Sent from my iPad
philperry9
PostPosted: Sat Apr 19, 2014 5:33 pm    Post subject: Cabin door safety latch Reply with quote
3 votes for Sean's solution. It's great.
