Mike Whisky
Posted: Mon Apr 21, 2014 2:41 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
Hi
I have now 60h on my -10 and suffer of bad noise of my COMM 1 GNS430W.
It is constantly receiving loud noise only when the engine is running. Often it is ok on my home frequency 122.15 but permanently noise is present on 124.xxx frequencies.
The COMM 1 is connected to a belly mounted Comant C-122 antenna which is attached by screws and nut plates. The antenna came with a cork gasket which I used.
Here are my set of questions. The radio receives fine when engine is not running, so I guess that grounding of antenna or cabling should not be the cause of the issue. What could be the potential source of the noise? How can I identify it?
I took all electric circuits one by one off-line without success.
Any ideas are appreciated
Mike
_________________ RV-10 builder (flying)
#511 |
jmjones2000(at)mindspring Guest
Posted: Mon Apr 21, 2014 3:07 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
Sounds like it is a shielding issue. Make sure that you use shielded ground and antenna wires. The shield should be grounded on just one side, not both (either antenna side or radio side).
On Apr 21, 2014, at 2:41 AM, Mike Whisky <rv-10(at)wellenzohn.net> wrote:
Hi
Mike
RV-10 builder (flying, test phase)
#511
http://forums.matronics.com/viewtopic.php?p=422182#422182
rnewman(at)tcwtech.com Guest
Posted: Mon Apr 21, 2014 3:25 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
Mike. Have you tried pulling the field breaker on the alternator so you are running on battery power only? If so, then it would appear you are a problem with the magnetos generating noise. If the problem goes away when you turn off the alternator then we are chasing an issue with respect to the alternator and it's regulator.
One point if note, there are squelch setting deep in the set-up menu of the gns series. I remember making tweaks to it on my glastar many years ago. Now with respect to the rv-10, I have dual gns-430w, each with a belly mount c-122 antenna and I did use the cork gaskets. All works as advertised, I never have a communication issue with the radios on any frequency.
Bob Newman
N541RV
Tcwtech.com
| Quote: | On Apr 21, 2014, at 6:41 AM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
Hi
Mike
#511
Posted: Mon Apr 21, 2014 4:39 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
There are several issues that can cause the problem you describe. This last
week I fixed a similar problem on an RV-8A - an antenna connector on the
feed line was bad. A bad connector can still allow the radio to receive.
As you don't say this is a problem on Comm #2 and this problem just
appeared, below are some thoughts to isolate the root issue:
- swap Comm #1 and Comm #2 antennas to see if the problem moves. If so you
have either bad connectors, some other antenna feed line issue or a bad
antenna (not likely). I use an MFJ antenna analyzer to verify antenna
health.
- swap out your 430 with someone else's 430 - if the problem goes away the
issue is inside your 430. As Bob suggests this might be a simple squelch
setting.
If the above checks do not change the symptoms then start looking at the
things not checked. This would include tray connections and magneto control
cabling (must be shielded wire and grounded per standard magneto wiring
practice). If you did something right before this issue started, that would
also be a place to look.
Carl
Mike Whisky
Posted: Mon Apr 21, 2014 4:42 am Post subject: Re: How to eliminate noise on COMM 1 (GNS430W) |
| jmjones2000(at)mindspring wrote: | Sounds like it is a shielding issue. Make sure that you use shielded ground and antenna wires. The shield should be grounded on just one side, not both (either antenna side or radio side).
I am using RG-400 and BNC connectors. The shield is grounded on both ends. It's the first time I hear that it should be grounded only on one side! Can someone confirm.
Mike
| [/quote]
#511 |
flysrv10(at)gmail.com Guest
Posted: Mon Apr 21, 2014 6:37 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
The base of your antenna must have a good ground. I never use the cork gasket.
Also ALL ground connections on your radios must go to a separate ground bus, directly connected to the battery. No airframe grounding of any kind.
Do not archive.
Rob Kermanj
Hi
Mike
#511
Kellym
You are correct. Antenna cable is NOT one of the places that shielding
is terminated to ground at only one end.
There are opportunities for a bad shield connection with coax. An
earlier suggestion to swap antenna cables between Com 1 and Com 2 is a
good one to see if it is the cable(does problem move between coms or
not?). Likewise, if possible to either borrow another matching radio to
see if it does it also, or to put your radio in someone ele's plane to
see if the problem goes with the radio. All no/lo-cost tests.
Magnetos/electronic ignition and alternator system are two prime
candidates for noise generation. Easy to eliminate the alternator noise
by pulling field and main breakers.
On 4/21/2014 5:42 AM, Mike Whisky wrote:
> Mike
> On Apr 21, 2014, at 2:41 AM, Mike Whisky wrote:
>> Hi
>> Thanks
>> Mike
>> #511
#511
http://forums.matronics.com/viewtopic.php?p=422188#422188
KCHD |
Mike Whisky
Posted: Mon Apr 21, 2014 10:17 am Post subject: Re: How to eliminate noise on COMM 1 (GNS430W) |
I do have one common ground for everything at the firewall. It works fine for my COMM 2 (SL30). I will follow your advice and switch off field and then EI/Magneto. The ground of measuring connectivity of the antenna ground base against the structure has been positive. In order to switch antenna cable I need to make a male-male and one female-female coax as the connectors are just the other way around. But I do have now a pretty good idea to eliminate at least some potential sources. I'll keep you updated of the outcome.
Michael
#511 |
Kellym
Posted: Mon Apr 21, 2014 12:36 pm Post subject: How to eliminate noise on COMM 1 (GNS430W) |
The gasket is there to prevent moisture from getting to the connection
and inside the airframe. It does NOT inhibit grounding. If you don't use
the gasket then you need a good RTV or Proseal bead to seal the base of
the antenna from the weather.
Grounding happens between the attach screws and the riveted nutplates,
not from skin to antenna contact.
As long as a common ground point is used it does not matter whether
there is a wire conductor back to the battery or the airframe is used on
metal aircraft like the RV-10. Only things like intercoms, mike and
headset jacks need a floating ground to prevent ground loops.
On 4/21/2014 7:36 AM, Rob Kermanj wrote:
Do not archive.
Rob Kermanj
> Hi
> Thanks
> Mike
> #511
KCHD |
Mike Whisky
Posted: Wed Apr 30, 2014 12:56 pm Post subject: Re: How to eliminate noise on COMM 1 (GNS430W) |
Now this one is getting interesting.
I measured the RG-400 antenna cable and found on the antenna side that on the female BNC connector the shield and the center pin are somehow connected, which shouldn't be the case.
The weird thing however is, that if I measure the cable from the other side the shield and the center pin are not connected?! I tested this several times and measured connectivity of the shields on both sides which is positiv.
Does anyone have an idea what's going on?
Mike
#511 |
philperry9
Posted: Wed Apr 30, 2014 3:14 pm Post subject: How to eliminate noise on COMM 1 (GNS430W) |
Are you disconnecting it from the radio while you are checking continuity?
If it's connected to the radio, it will show a dead short when checked from the other end.
Phil
Mike
#511
http://forums.matronics.com/viewtopic.php?p=422616#422616
Mike Whisky
Posted: Thu May 01, 2014 10:38 am Post subject: Re: How to eliminate noise on COMM 1 (GNS430W) |
Yes it was disconnected.
#511 |
Posted: Thu May 01, 2014 11:25 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
If so, this pretty well narrows it down to a bad connector (braid sometimes
shorts, sometimes not). Try mechanically agitating (wiggling) the connector
at each end and see if you can make the short go away.
Carl
jdriggs49(at)msn.com Guest
Posted: Thu May 01, 2014 11:27 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
I get a lot of static on my Garmin 430 and on the SL-40 when the transmitting person keys their mike. Only then. Sometimes its so loud its hard to understand them. I've tried all kinds of squelch settings to no avail. Any ideas to help me??
aerosport1
Posted: Thu May 01, 2014 11:43 am Post subject: How to eliminate noise on COMM 1 (GNS430W) |
One thing to check is that your headset plugs are isolated from any metal that is conductive/aluminum or carbon fiber. I had the same
Problem and it was my rear head set jacks. The isolator washers were the problem. I would at least check all the headset jacks for proper
Isolation.
Geoff Combs
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Thursday, May 01, 2014 3:27 PM
Subject: RE: Re: How to eliminate noise on COMM 1 (GNS430W)
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Thu May 01, 2014 12:29 pm Post subject: How to eliminate noise on COMM 1 (GNS430W) |
I will do that. Thanks Geoff!!
Date: Fri, 2 May 2014 15:39:40 -0400
Isolation.
Geoff Combs
8
Mike Whisky
Posted: Mon Aug 25, 2014 12:53 pm Post subject: Re: How to eliminate noise on COMM 1 (GNS430W) |
I just wanted to give you an update on my noise issue. Following the advice on de-activating one system after the other I was able to narrow it down to the nav lights. Long story short Aeroleds did sent me new ones and the noise is gone. Great customer service!
Michael
#511 |
