		rvdave
				 Posted: Thu Apr 24, 2014 6:58 pm    Post subject: Fuel lines |
				Just received and installed the Vans recommended fuel line from firewall to fuel pump and have a concern.  First it fits a little tight and seems a little short but maybe clocking the fitting will cure that; 2)  am concerned about the aluminum firewall thru fitting holding up through engine vibration and may change that to steel; 3) if the line is adel clamped to the engine mount will that eliminate concern about vibration to the fitting?
  _________________ Dave Ford
Cadillac, MI |
				 Posted: Thu Apr 24, 2014 7:40 pm    Post subject: Fuel lines |
				Stock setup has worked for 1,300+ hours here.
 Jesse Saint
 I-TEC, Inc.
 jesse(at)itecusa.org
 www.itecusa.org
 www.mavericklsa.com
 C: 352-427-0285
 O: 352-465-4545
 F: 815-377-3694
  	  | Quote: | 	 		   On Apr 24, 2014, at 10:58 PM, "rvdave" <rv610dave(at)gmail.com> wrote:
  Dave Ford
  RV6 flying
  RV10 building
  Cadillac, MI
  http://forums.matronics.com/viewtopic.php?p=422349#422349
		rleffler
				 Posted: Thu Apr 24, 2014 8:44 pm    Post subject: Fuel lines |
				1.   I went with TSflightline for all fuel lines for and aft of the firewall, so I can't speak to the length of Vans cable.
 2. I replaced with steel fittings.   Anplumbing.com
 3. Shouldn't be an issue.   I don't recall if I secured that line with an adel clamp or not.   Just make sure that the line has some slack if you use an adel clamp.
  Dave Ford
  RV6 flying
  RV10 building
  Cadillac, MI
  _________________ Bob Leffler
N410BL - Phase I
