uuccio(at)gmail.com Guest
Posted: Tue Apr 29, 2014 5:42 pm Post subject: Battery and master contactor - ok to mount horizontally? |
Quick question about Battery and contactor installation position:
I am moving my battery aft and am planning to make an installation similar to the example on Bob's website at http://www.aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
Except that instead of having the (SVLA) battery upright I want it on its side. Is that ok? And is it ok to mount the master and starter contactors horizontally (I'm planning to use rivnuts and bolt them to a horizontal sheet of stainless steel) instead of using L-shaped tabs to mount them vertically as in the picture?
jluckey(at)pacbell.net Guest
Posted: Tue Apr 29, 2014 8:45 pm Post subject: Battery and master contactor - ok to mount horizontally? |
Mounting the battery on its side and the contactors horizontally is just fine. It won't affect the operation of either device.
To: aeroelectric-list <aeroelectric-list(at)matronics.com>
Sent: Tuesday, April 29, 2014 6:41 PM
Subject: AeroElectric-List: Battery and master contactor - ok to mount horizontally?
--> AeroElectric-List message posted by: Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)>
Except that instead of having the (SVLA) battery upright I want it on its side. Is that ok? And is it ok to mount the master and starter contactors horizontally (I'm planning to use rivnuts and bolt them to a horizontal sheet of stainless steel) instead of using L-shctric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectrp; --> http:========================
Posted: Wed Apr 30, 2014 2:19 am Post subject: Battery and master contactor - ok to mount horizontally? |
Thank you Jeff!
On Apr 30, 2014, at 6:44, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
[quote]Mounting the battery on its side and the contactors horizontally is just fine. It won't affect the operation of either device.
From: Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)>
To: aeroelectric-list <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
Subject: Battery and master contactor - ok to mount horizontally?
"3D"courier" new,courier"="">[url=3D"http://www.matronics.com/Navigator?AeroElectric-List"]http://www.matronics.com/Navigator?AeroElectric-List[/url]
//forums.matronics.com
airelectricjim
Joined: 09 Jan 2009 Posts: 11 Location: Augusta GA USA
Posted: Wed Apr 30, 2014 8:55 am Post subject: Re: Battery and master contactor - ok to mount horizontally? |
Hi, Jeff,
A word of caution for rivnuts: Be sure that you use rivnuts that are HARDER than the substrate, in your case stainless steel. Rivnuts have a bad habit of loosening in their holes, making the bolt nigh onto impossible to unscrew. Don't ask me how I know!
This might be even worse if you use aluminum rivnuts, as there will be corrosion between the metals, which will act as a lubricant.
Jim
