docyukon(at)ptcnet.net Guest
Posted: Tue Apr 29, 2014 9:52 am Post subject: lm7321 substatute |
Bob Can you recomend a substatute for a lm7321 opamp, in a din package? The
sot23 package is just tooooooo small for me to work with. Thanks
Bill S.
Posted: Wed Apr 30, 2014 6:44 am Post subject: lm7321 substatute |
At 12:50 PM 4/29/2014, you wrote:
package? The sot23 package is just tooooooo small for me to work
with. Thanks Bill S.
What's the application? Can you share a schematic
along with a description of function? There are probably
100+ suitable substitutes with rare exception . . . I
don't want to offer substitute that stumbles over
an exception.
The LM7321 is a fine example of the current state
of op-amp art. Low voltage performance, rail-to-rail
input and outputs, lots of drive capability, etc.
http://tinyurl.com/otlg7je
However, depending on requirements for the circuit
you're crafting, you may NEED few if any of these
stellar features.
Posted: Wed Apr 30, 2014 7:28 am Post subject: lm7321 substatute |
At 10:59 AM 12/22/2011, you wrote:
Quote: | I am wanting to parllel two Ray Allen RP3 led position indicators useing
only one POS5 position sensor. RAC said that thay wont work just parelling
them and that I need to add another position sensor or a switch which I
would rather not do. Can anyone sudjest an electrical ckt. that would work
for this? Thanks Bill S.
You need a 'buffer-amplifier' between the position
feedback potentiometer and ONE of the two indicators.
The problem with paralleling the two indicators arises
from the fact that they're not a 'high impedance' voltmeter.
The system is calibrated for one pot driving one indicator.
Adding a second indicator doubles the load on the position
signal from the potentiometer.
The 'fix' is to convert one of the indicators into a
high-impedance voltmeter. You need an operational
amplifier with rail-to-rail inputs and outputs. A device
like the LM7321 would probably work.
http://search.digikey.com/us/en/products/LM7321MF%2FNOPB/LM7321MFCT-ND/1878646
Adding this device to the second indicator prevents
it from loading the potentiometer. You need to
fabricate something like this . . .
http://aeroelectric.com/Pictures/Schematics/Ray-Allen_Dual_Indicators.pdf
It could be fabricated on an etched circuit board
that would fit inside a d-sub connector back shell.
Quote: | >Bob Can you recomend a substatute for a lm7321 opamp, in a din package?
>The sot23 package is just tooooooo small for me to work with. Thanks
>Bill S.
an exception.
stellar features.
Checked by AVG - www.avg.com
Posted: Wed Apr 30, 2014 11:21 am Post subject: lm7321 substatute |
At 10:27 AM 4/30/2014, you wrote:
OOOPS! The 7321 was my selection . . . not sure
why I went with SOT23 only except that my head
was probably thinking about packaging in the
dsub housing . . .
Refresh my memory, we ARE talking about a 5v
system? This op amp would do the job
http://tinyurl.com/ol9jm4v
but it's limited to 7.5v max supply voltage.
It IS in stock at Digikey at 0.88 each.
Posted: Wed Apr 30, 2014 12:14 pm Post subject: lm7321 substatute |
The opamp should be rated at least 15v min.
Posted: Wed Apr 30, 2014 12:36 pm Post subject: lm7321 substatute |
At 03:13 PM 4/30/2014, you wrote:
Okay, this one should work
http://tinyurl.com/llsm37s
Let me know how this works for you . . . I'll
revise my document on the website. I could
also whack out a little ecb that would sit
between the solder-cups on a d-sub and make
it a whole lot easier to package . . .
Posted: Thu May 01, 2014 4:58 am Post subject: lm7321 substatute |
Have you ordered any op-amps yet? I've got
an order going into Digikey this weekend. I
could add some to the list if you're in no
hurry . . .
Eric M. Jones
Posted: Thu May 01, 2014 5:44 am Post subject: Re: lm7321 substatute |
Quote: | Bob Can you recomend a substatute for a lm7321 opamp, in a din package? The sot23 package is just tooooooo small for me to work with. Thanks Bill S. |
I want to propose another solution....c'mon bucky! The Swiss could build a watch between the legs of the SOT-23. I have circuits where the SOT-23 parts are the BIG ones.
Seriously, soldering tiny parts is a skill that is not hard to master, but you have to start with--ideally, a nice stereo lab microscope of modest power-- but any good magnifier that you don't have to hold with a hand will do. Then use a fine-tip soldering iron, fine tweezers and some fine-gauge solder.
This is ultimately pretty easy to do. Many electrowhizzies are not available in bigger packages. Everything is shrinking. To work on tiny stuff requires the right tools.
Good luck.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
