Special Coax Connectors: Apollo Nav/Coms...
Dragoon6
PostPosted: Tue May 06, 2014 8:12 pm    Post subject: Special Coax Connectors: Apollo Nav/Coms... Reply with quote
Hello,
I am looking for some (apparently) special coax connectors for my Apollo (now Garmin) nav/coms. The old connectors are made by Delta Electronics Manufacturing Corp., part number 4205018N995-000, and are slip-on on one side with a metal flare to help guide the radio coax connector into place, then a center-wire solder and twist-on shielding connection the other end. There are two rectangular flanges for mounting to the nav/com tray.
I am told that these are standard for the older Apollo radios but they are somewhat difficult to come by. If anyone is selling any or knows of anyone who has any, i would appreciate it.
These connectors float on the tray, which also helps for easy alignment when sliding the radio into the tray. I just need new connectors so I can switch to my RG400 coax from the RG58. Let's see if I can add some photos.
 Filesize:  392.11 KB
 Viewed:  4664 Time(s)
 Filesize:  369.33 KB
 Filesize:  373.25 KB
 Filesize:  383.44 KB
Travis
Kellym
PostPosted: Tue May 06, 2014 8:32 pm    Post subject: Special Coax Connectors: Apollo Nav/Coms... Reply with quote
Why go to all the bother of upgrading to RG400 for nav/coms?? They are
in the 108-137MHz range, where there is not much performance difference
between the RRG-58 and RG-400. Properly installed RG58 with decent
antennas can give over 100nm range. How much more do you need??
On 5/6/2014 9:12 PM, Dragoon6 wrote:
Hello,
Travis
http://forums.matronics.com/viewtopic.php?p=422941#422941
http://forums.matronics.com//files/img_20140504_094054_732.jpg
http://forums.matronics.com//files/img_20140504_094042_166.jpg
http://forums.matronics.com//files/img_20140504_094028_185.jpg
http://forums.matronics.com//files/img_20140504_094003_108.jpg
Kelly McMullen
KCHD
stein(at)steinair.com
PostPosted: Wed May 07, 2014 6:49 am    Post subject: Special Coax Connectors: Apollo Nav/Coms... Reply with quote
Quick hint...you can use the same connector! That said, if you'd like new
connectors we keep them in stock....
Stein
