Fusable link
JOHN TIPTON
PostPosted: Thu May 08, 2014 3:09 am    Post subject: Fusable link Reply with quote
Hi Guys (Bob)
I see that Z11 is using a fuse block as opposed the CBs (no problem there), can you tell me why the feed to the 5a CB has a fuse able link, why not use a fuse in the distribution fuse block
Best regards
JOHN TIPTON
PostPosted: Thu May 08, 2014 3:12 am    Post subject: Re: Fusable link Reply with quote
Ps: the 5amp CB did relate to the alternator feed circuit
PostPosted: Thu May 08, 2014 4:40 am    Post subject: Fusable link Reply with quote
At 06:09 AM 5/8/2014, you wrote:
--> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi Guys (Bob)
Best regards
The length of wire from fuse block feeder terminal
out to the circuit breaker is an EXTENSION of the
bus. In larger aircraft the bus feeders will sometimes
be protected by a VERY robust fusible device like
the ANN/ANL series of "current limiters" . . .
http://tinyurl.com/lrjm5y3
http://tinyurl.com/k7o3l3q
Note that these devices, while 'rated' at some
value like 100A, they will CARRY 2x their
rated current almost indefinitely. At the
same time, when subjected to a hard fault
of 5 to 10x rated current, they open in tens
of milliseconds.
Legacy design goals for aircraft suggest that
this extension of the bus up to your panel
mounted circuit breaker needs a 'current limiter'
but not like the devices cited above. It's
much smaller and designed to protect the longer
run of wire to the breaker. Protection with
a response many times longer than the breaker
it feeds.
This question came up on the List a few years
ago . . .
Q: Drawing Z24 shows how to add an OV protection module for an internally regulated power
supply. It requires the use of a 5A circuit breaker and also of a fuselink attached to the main
connection of the main bus. The question: Can we replace the fuselink by using one of the
outputs on the main bus protected by a larger fuse (say 15amps)? I would like for sure the
breaker to let go before the fuse.
A: Some 5A breakers will open a 15A fuse. Fuses are MUCH faster than breakers. This is
why I prefer the fusible link
The risks of positioning fuses upstream of breakers
is illustrated in the accident case I chronicled
here
http://tinyurl.com/msfmldj
and demonstrated here
http://tinyurl.com/ppdv5fg
The automotive world has used fusible links
in this capacity for decades and they've
served well in the capacity of mini-limiters.
Bob . . . [quote][b]
JOHN TIPTON
PostPosted: Thu May 08, 2014 10:21 am    Post subject: Re: Fusable link Reply with quote
So a ANL current limiter off the main battery protecting the whole system would not be a bad idea ?
PostPosted: Thu May 08, 2014 4:36 pm    Post subject: Fusable link Reply with quote
Not a bad idea . . . but not a good one either. Current
limiters have value for fault isolation in complex bus
structures . . . which are generally not found in Part
23 airplanes.
The fat wires between battery, main bus and starter
terminal are usually of such robustness that any
fault to ground would be more likely to burn a hole
in fault location as opposed to opening any limiter
in the path.
Single light TC aircraft have never been fitted with
such protection that I know of.
jluckey(at)pacbell.net
PostPosted: Thu May 08, 2014 7:17 pm    Post subject: Fusable link Reply with quote
Sent: Thursday, May 8, 2014 5:32 PM
Subject: Re: Re: Fusable link
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
<jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
23 airplanes.
in the path.
Not sure what that means... ???
If it is "robust" wouldn't it carry enough current to blow the limiter?
Are you suggesting that "welding/burning" aluminum does not draw a lot of current?
Have you ever tested that hypothesis?
Even if some of the above is true, a current limiter still could provide some protection
from a "hard" fault, could it not?
-Jeff
lectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElec --> h &nbsphref="http://www.matronics.com/contribution" =======
PostPosted: Fri May 09, 2014 2:18 am    Post subject: Fusable link Reply with quote
lot of current?
Actually, it doesn't. Recall the anecdote about
the C90 parting and elevator control cable with
a soft fault to a wire. A 40A breaker didn't trip
nor was the wire itself seriously damaged.
http://tinyurl.com/n3dqkb2
Define 'hard' fault . . . and hypothesize how
one comes into existence.
What kind of circuit closure has to happen to
carry hundreds of amps of current? Consider
how a contactor is built specific to
that goal. Now, how does such a connection
happen along the pathway for a fat wire as
it travels about the airplane?
The #1 failure in wires is simple disconnect.
#2 is insulation failure by virtue of mechanical
intrusion . . . abrasion or sharp edge cutting
due to poor support combined with vibration.
What is the quality of first contact? It's tentative,
low force, high resistance event that produces
some arcing but is generally far short of that
required to put the wire at risk or even open
it's upstream current limiter.
Then there's the probability: #1 failure
is rare, #2 several magnitudes more rare, and
if a composite airplane, a few magnitudes more
rare yet.
The few times I've seen the result of a battery
cable insulation chaffing and taking the conductor
to ground, the fault self cleared when the offending
aluminum burned away. When breakers open in
airplanes, the most likely cause is failure
in the powered device . . . not because of
compromised insulation in the wire-run.
If you want to put a current limiter in your
battery line, by all means. I'm only suggesting
that your airplane will be one of a very few
in a constellation of tens of thousands.
PostPosted: Fri May 09, 2014 7:55 am    Post subject: Fusable link Reply with quote
Sent: Friday, May 9, 2014 3:00 AM
lot of current?
Bob - I think you side stepped the question...
".. current limiter still could
from a "hard" fault, could it not? "
regardless of how the hard fault happens.
Let's consider the worst case scenario where
we have a crash and a hard-fault occurs.
  rare yet.
Bobric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Lista href="http://forums.matronics.com/" target="_blank">http://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
