		| Author | Message |
		| armywrights(at)adelphia.n Guest
				|  Posted: Sat Jan 14, 2006 9:59 pm    Post subject: Posted 9 Jan 06 |   |
				| VAN’S AIRCRAFT, INC.
14401 NE Keil  Road, Aurora, Oregon,  USA 97002
 PHONE 503-678-6545 • FAX 503-678-6560 • www.vansaircraft.com • info(at)vansaircraft.com
 Service letter: January 9, 2006
 Subject: Main Gear Axle Nuts
 Affected Models: ONLY RV-10 main gear axle nuts
 It has come the attention of Van’s Aircraft that some of the main gear axle nuts
 supplied in finish kits for the RV-10 since November of 2005 have threads that
 are not cut deep enough to allow for their use.
 • If you have axle nuts that will not readily screw onto the main gear axles,
 please contact Van’s Aircraft for replacement units.
 Rob
 #392
 Deburring Tailcone (any hints in this step?)
 | |  |  | - The Matronics RV10-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV10-List
		| Back to top |  |
		| sfdarton(at)yahoo.com Guest
				|  Posted: Sun Jan 15, 2006 12:36 pm    Post subject: Posted 9 Jan 06 |   |
				| Rob,
 Try a Cogsdill burraway. You can find them
 consistently on E-bay. Be forewarned you may have to
 tinker with the adjustment  especially with the #40.
 However once it is set I rarely need to readjust (only
 if I have changed to deburring a different thickness
 of material).
 Some people really like them and others do not. I
 personally would consider this an essential tool
 because it cuts the deburring time by 2/3. Most of the
 used tools you find on E-bay are surplus from Boeing.
 here is an example of such an item:
 http://cgi.ebay.com/aircraft-tool-Cogsdill-Burraway-Hole-Deburr-Tool_W0QQitemZ7580217685QQcategoryZ109559QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
 I do not know this lister and cannot give any
 recomendation other than you will use the two smallest
 sizes frequently and the next two sizes occaisionally.
 Steve 40212 wings
 --- "Robert G. Wright" <armywrights(at)adelphia.net>
 wrote:
  	  | Quote: |  	  | VAN'S AIRCRAFT, INC.
 PHONE 503-678-6545 * FAX 503-678-6560 *
 www.vansaircraft.com *
 It has come the attention of Van's Aircraft that
 nuts
 that
 * If you have axle nuts that will not readily screw
 onto the main gear
 axles,
 please contact Van's Aircraft for replacement units.
 Rob
 #392
 Do You Yahoo!?
 Tired of spam?  Yahoo! Mail has the best spam protection around
 http://mail.yahoo.com
		| Back to top |  |
		| jdalton77(at)comcast.net Guest
				|  Posted: Sun Jan 15, 2006 12:47 pm    Post subject: Posted 9 Jan 06 |   |
				| I found a set on eBay for $20.  Have not tried them yet.
 TAIL KIT IS AT THE SHIPPING DEPOT!!!!  Unfortunately, they're closed until
 Tuesday
		| Back to top |  |
				|  Posted: Sun Jan 15, 2006 1:33 pm    Post subject: Posted 9 Jan 06 |   |
				| Jeff,
 Many people have complained that the #40 cuts too
 aggressively. Be sure to adjust the tension spring so
 there is just enough pressure to return the blade
 after you depress it with your finger. Second, use a
 cordless drill so it is not turning too fast. Watch it
 turn 1 1/2 to 2 revolutions on the top side and then
 spend the same amount of time on the back side, you
 will get the "rhythm". Test it, practice and adjust it
 on some scrap material.
 Good luck
 Steve 40210
 yet.
 Tuesday
		| Back to top |  |
