				 Posted: Fri May 30, 2014 7:07 am    Post subject: antennas |
				I would be grateful if one of you experts in radio matters
 could tell me whether one can add a couple of metres of
 good quality coax cable to distance the stub antenna of a
 hand held Icom transceiver from the radio, positioning the
 stub aerial on top of the fuselage behind the pilot,
 without mucking up its function. I hasten to add that this
 is not for my Europa but for a Build a Plane project I am
 involved in which will rely on an Icom, but which picks up
 a load of ignition noise if positioned on the panel, just
 behind the engine.
 Regards, David Joyce, G-XSDJ
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rparigoris
				 Posted: Fri May 30, 2014 7:51 am    Post subject: Re: antennas |
				Hi David
 The rubber duckie antenna is not all that good of an antenna. I have fooled with extending mine aft on the Europa and reception on the ground and performance was poor at best, no worst than when it was directly on the unit.
 A better solution for me was AAE and Balsa. It ends up weighing under 4 oz. and works about 70% as well for both VOR and Communication.
 http://www.europaowners.org/main.php?g2_itemId=31216
 Ron Parigoris
		frans(at)privatepilots.nl Guest
				 Posted: Fri May 30, 2014 9:44 am    Post subject: antennas |
				-----BEGIN PGP SIGNED MESSAGE-----
 Hash: SHA1
 On 05/30/2014 05:06 PM, David Joyce wrote:
  	  | Quote: | 	 		   I would be grateful if one of you experts in radio matters could
  tell me whether one can add a couple of metres of good quality coax
  cable to distance the stub antenna of a hand held Icom transceiver
  from the radio, positioning the stub aerial on top of the fuselage
  behind the pilot, without mucking up its function.
 Yes you can do that, provided you create some artificial ground at the
 antenna connector (unless the airplane is made of metal). On the
 radio, the radio itself plus the person holding the radio are some
 kind of ground, but if you relocate the antenna you need something
 below the antenna to take over that function. (If you don't, the outer
 shield of the coax will take over that function, but this is probably
 not what you want).
 Note that the stub antenna of the hand held radio has less performance
 than a full quarter wave antenna. (Inside this stub antenna you will
 find a coil; it is still a quarter wave antenna but most of the length
 has been coiled up and doesn't radiate as much anymore.)
 Frans
 -----BEGIN PGP SIGNATURE-----
 Version: GnuPG v2.0.22 (GNU/Linux)
 iQIcBAEBAgAGBQJTiM8dAAoJEC+zXxqs0ZzVXs8QAJAIsCH7BC8PkH+OjdEWjDYn
 8Su9JXiGaGDCqYC5kMJCPUMEr2AQVLqCnGxdo9VMHa09LJj3Jsa+DtXxxWGbiJTn
 g6NMNyiPDeuVu1bweGaAu1gG63Vm9snyrWKGyyLNksezZUR29QGwp8xUlrNxdTLk
 ckKlunoF1xURZfV9GWaunGlxzbTDaMgPBpD/l6Td1cgoeDflVH2rQOiscHY3ZxBN
 mmFVlyZRoK46geUEesR2pKDAOELISvGeMA5LYktWa3sVgBBQWDOAxIJ7ktdzx2vY
 U4f+e7tWEA+4wBQedbqXVLIr/cIqKLua/mOXHoM8UykaJEYMnzIO7HCvldyu8HLm
 ZzoiHRmPnoPSdQT8k3hhfsjaCEfCFCd7pcZowtE2u0v1RzTEH1UtdlU2Gn7lVj6I
 qeKGGR/qwxrLUN7kMDxbQX9n8+Jfj/WfzKz0zgWIhd8kQ/0KTbvr15l9LnfRy5Qh
 n9DQRlsD75TuGyEMIVR4XRS8IbK4zH32pQ3IM7+IvmlSqk546CP9FNPurW7cM1WZ
 E23h42riyY1YS4SeNBcAfX0ixv/x2Yb8XkH2vYZlfhzuCiVnMBVOC6Vyh/D7Jry6
 FAnXhWGYpu31P5lYjfgZWuoTGErGUxXvz9XUgryHwbS3qbM0Ys4g7epsTWbSH7we
 CGTr9VsCBFndRVK1m4Td
 =/4la
 -----END PGP SIGNATURE-----
		europa-list(at)matronics. Guest
				 Posted: Fri May 30, 2014 1:03 pm    Post subject: antennas |
				I used a 4 or 5 foot extension intended for a GPS Antenna which ends up with with a window sucker plugged in to Icom one end and the Icom Antenna plugged in the window sucker end.  Works perfectly used as stand by com.
 Dave
  	  | Quote: | 	 		   On 30 May 2014, at 18:47, "Frans Veldman" <frans(at)privatepilots.nl> wrote:
  Hash: SHA1
  not what you want).
  Frans
  =/4la
				 Posted: Sat May 31, 2014 4:07 pm    Post subject: antennas |
				I put a full wave loop antenna in to run a hand held scanner in mine a/c works a LOT better than the stubby antenna
 Get excellent reception afis, ground and atc at the nearest airport about 40km away, I get nothing with the stubby antenna
 Its on about 4m of coax to get to the loop
 craig
				 Posted: Sun Jun 01, 2014 12:38 am    Post subject: antennas |
				Craig, That sounds very interesting. Can you explain how
 you did it, please? David Joyce, G- XSDJ
 On Sun, 1 Jun 2014 09:34:30 +1000
   "craig" <craigb(at)onthenet.com.au> wrote:
 antenna
 stubby antenna
  craig
 Un/Subscription,
 Forums!
 Admin.
		budyerly(at)msn.com Guest
				 Posted: Sun Jun 01, 2014 6:05 am    Post subject: antennas |
				Craig and others.
 My Sportys SP400 with ear piece hooked to my headset works great at low
 altitude line of sight with the rubber duckie.
 For long range communications using a handheld radio in our IFR aircraft we
 use an Advanced Aircraft Electronics carbon fiber antenna ($120 US). Just
 add a coax to the passenger headrest and you have an easy to grab and use
 handheld antenna that is clear and able to go line of sight over 50 nm.
 VOR/Localizer operations work very well, but I wouldn't fly an approach on
 it.
 In other aircraft, the ELT becomes a pain to make a ground plane for, then
 make a mount for the whip antenna, then secure it, etc.  I now use the AAE
 antenna for that also.  In one aircraft, the customer asked me to put his
 ELT coax into the headrest and break the coax there for his handheld, just
 in case he needs his handheld.  Not recommended, but it works.
 The antenna is added just behind the bulkhead (basically aligned on an angle
 with the bulkhead) curving along the fuselage.  Works great even up to a 45
 degree angle.  VHF NAV antennas work very well centered on the top inside of
 the fuselage bent around the bulkhead.  I prefer to install them just behind
 the doors as the curve is wider, and the reception on VOR/Localizer/GS with
 a splitter is excellent.
 Of course you can save some money and build an antenna, but to me, in 30
 minutes, I'm done.  Hooked up but held up until the flox cures.  ( I use
 super glue to tack the antenna in place until the flox dries.)  It takes
 longer to undo the D panel, and put in my belly board to slide in the rear
 than it takes to put the antenna in. (Don't forget to block the tail up in a
 trigear!)   If you made your conduits large enough for upgrades, you have no
 problem.  If you didn't, run the coax through the tunnel, along the front of
 the tank and up into the headrest.  Secure it well as you are near cables
 and flight controls.  Great annual project.
 Just my thoughts.
 Bud Yerly
 Sent: Saturday, May 31, 2014 7:34 PM
 To: <europa-list(at)matronics.com>
 Subject: RE: antennas
  craig
		mau11(at)orange.fr Guest
				 Posted: Sun Jun 01, 2014 7:17 pm    Post subject: antennas |
				Hi Ron,
 Do you have exact drawing and size of your antenna available?
 Many thanks
 Michel AUVRAY
 Builder 145 - 550 hours fly
 On 30/05/2014 17:51, rparigoris wrote:
  Hi David
  Ron Parigoris
  http://forums.matronics.com/viewtopic.php?p=424Hi Ron,
		rparigoris
