fasilpereira
Posted: Thu May 29, 2014 5:58 am Post subject: Fuel Level Sender - Bob Reed |
Bob,
I noticed that you've cut the capacitive fuel level sender in order to install it on the wing due to cracks on the sender tubing after bending.
My sender was installed on the inboard wing rib, but on the upper part of the rib. Ted installed it bent up on the inboard part of the wing and pointing down toward the wing tip. This setup will not provide good measurements and I'm thinking on changing that.
To correct this issue I'm thinking on cutting the sender as you did, since there is not enough bendable lengh to bend the sensor down so that it touches the bottom of the wing skin.
Did you tested your setup? Did it worked properly? What is the brand and the model of your sender?
P.S.: I tried to see the pictures of your wing leak test but the link seem to be broken
_________________ Fabricio Pereira
Engineer / Pilot |
sstearns2(at)yahoo.com Guest
Posted: Thu May 29, 2014 8:06 am Post subject: Fuel Level Sender - Bob Reed |
I put the fuel senders in from the wingtip on both my TR-1 and the TR-4 project. You can custom order senders up to around 10 feet and it is not much extra. I put them in at an angle looking from the wing leading edge so they enter near the top of the wing root rib and the tip of the sender is just above the lower wing skin at or near the wing root rib. No need to bend the tube. The senders work great on my TR-1, very linear, and the senders are removable out of the wingtip. I used the newer princeton senders that just use a pipe theard fitting and a separate box for the electronics. I highly recommend it, much easier install. Also, the newer "glass" avionics needs the newer 0-5V output.
Cheers,
Scott
On Thursday, May 29, 2014 7:04 AM, fasilpereira <fasilpereira(at)hotmail.com> wrote:
--> KIS-List message posted by: "fasilpereira" <fasilpereira(at)hotmail.com (fasilpereira(at)hotmail.com)>
Bob,
Fabricio Pereira
Engineer / Pilot
http://forums.matronics.com/viewtopic.php?p=423962#423962
http://forums.matronics.cosp; -nics.com/contribution" target="_blank">http://www.matronics.com/contribut===============
fasilpereira
Posted: Thu May 29, 2014 8:35 am Post subject: Re: Fuel Level Sender - Bob Reed |
Thanks Scott!
That's probably the best way to go, but my wings are already closed and with the aluminum insert installed on the inboard rib.
I want to keep the rework to the minimum level in order to get it flying as soon as possible....
Best,
Fabricio
Engineer / Pilot |
gbrighton(at)skymesh.com. Guest
Posted: Sat May 31, 2014 4:19 am Post subject: Fuel Level Sender - Bob Reed |
G'Day Scott Ana All,
I have had a dead fuel gauge on one side since I purchased my TR1 ....
Traced the fault the the Head or the bent in Tank Tube ... It's the
early low vlt capacitance model .... With the bend the unit can't be
replaced normally .. So is a headache I haven't solved as yet .. The
other side works fine ..,
Scott,
Interested in ur Carbon Fibre project ... I have a Quickie TRI
gear ... That I'm looking at using to rebuild into a light weight
version ... , wondering if u have added Lightening Protection or not ..
If so how ..., and are u doing Hand Lay ups .. Or using prepreg material
or or ..?
Cheers
Graham
n 30.05.2014 02:06, Scott Stearns wrote:
| Quote: | I put the fuel senders in from the wingtip on both my TR-1 and the
it
I
output.
Cheers,
Scott
<fasilpereira(at)hotmail.com [1]>
Bob,
to
bending.
part
seem to be broken
Fabricio Pereira
Engineer / Pilot
http://forums.matronics.com/viewtopic.php?p=423962#423962 [2]
Links:
[1] mailto:fasilpereira(at)hotmail.com
[2] http://forums.matronics.com/viewtopic.php?p=423962#423962
Posted: Sat May 31, 2014 5:04 pm Post subject: Fuel Level Sender - Bob Reed |
Hi Graham,
The carbon parts in my TR-1 and in the TR-4 were all done with prepreg in Rich's shop years ago.
I have never understood the embedded mesh lightning protection. It seems like the mesh would just vaporize and cause a large delamination to me, but maybe there is more to it than I understand. I think that advantage of being able to put all the antennas inside a fiberglass structure outweigh whatever benefit comes with conductive mesh. For what it is worth, in 11,000 hours of flying all over the US in lots of crappy weather I have had one lightning strike.
Cheers,
Scott
I have had a dead fuel gauge on one side since I purchased my TR1 .... Traced the fault the the Head or the bent in Tank Tube ... It's the early low vlt capacitance model .... With the bend the unit can't be
replaced normally .. So is a headache I haven't solved as yet .. The other side works fine ..,
Scott,
Interested in ur Carbon Fibre project ... I have a Quickie TRI gear ... That I'm looking at using to rebuild into a light weight version ... , wondering if u have added Lightening Protection or not .. If so how ..., and are u doing Hand Lay ups .. Or using prepreg material or or ..?
Cheers
Graham
> output.
> Cheers,
> Scott
> Bob,
> bending.
> seem to be broken
> Fabricio Pereira
> Engineer / Pilot
> Links:
