ed(at)muellerartcover.com Guest
Posted: Thu Jun 22, 2006 5:18 pm Post subject: Inventory |
Got my QB fuse and QB wings delivered. Trying to do the inventory and
wondering how others stored the parts for the future. Like when I need
the F-10105 how do I remember what it looks like and where did I put it.
I have some dedicated shelving and was thinking of organizing by
function, but there are a lot of functions. Any ideas?
Ed Mueller
#40525
ed at muellerartcover.com
VHMUM(at)bigpond.com Guest
Posted: Thu Jun 22, 2006 5:28 pm Post subject: Inventory |
Ed sort the bags out by numbers as you will use them all the time so have
them in the same room. The fuse box (small ) you will be into as well. The
rest is just common sense that suits your location.
Kind regards Chris
LarryRosen
Posted: Thu Jun 22, 2006 5:56 pm Post subject: Inventory |
I also mark the bags to describe the contents. All the small parts get
stored in boxes and the bigger ones on shelves.
Chris , Susie Darcy wrote:
<VHMUM(at)bigpond.com>
have them in the same room. The fuse box (small ) you will be into as
well. The rest is just common sense that suits your location.
Kind regards Chris
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
rvbuilder(at)sausen.net Guest
Posted: Thu Jun 22, 2006 6:15 pm Post subject: Inventory |
I used a combination of 3 small loose parts cabinets and peg board to
organize the parts. Anything that didn't fit into those two categories
went onto a shelf. Here is the inventory sections of my log:
http://www.mykitlog.com/users/category.php?user=msausen&project=22&categ
ory=619
Michael Sausen
-10 #352 Fuselage
Tim(at)MyRV10.com Guest
Posted: Thu Jun 22, 2006 6:27 pm Post subject: Inventory |
Ed,
What worked for me is this:
All the big parts went on shelves or stayed in the shipping boxes piled
in a storeroom.
The baggies with plain old standard hardware all eventually got dumped
into 3 sets of those multi-tray organizers. I originally was keeping
all the hardware in the bags, but after a while I decided that I
should just order some of every size nut and screw that was commonly
used, and keep a good supply of parts. That helped a lot in the
end.
The rest of the baggies all got sorted by number, in order, and I bought
a bunch of plastic storage boxes and set them all in there in order, so
I could quickly find the number range of baggie that I needed.
I left labels on the parts as long as I could, or marked them with
a sharpie if I pulled the plastic or label.
Ed wrote:
Ed Mueller
#40525
