racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Mon Jun 09, 2014 3:28 am Post subject: Re: Xtra Control Problems |
ANOTHER THOUGHT ON ALIGNMENT
When you get around to actually adjusting camber / toe, re-drilling holes, etc; please remember that WEIGHT makes a difference. If you make alignment corrections with wings off or folded, you may regret it.
Before making any corrections, you need the airplane assembled in normal flying configuration WITH PILOT IN SEAT. Get a helper to plant his but in the aircraft seat before you drill holes.
The added weight will make the gear legs want to spread – let them. With race cars, we use greased plates to let wheels move freely; but that’s overkill here. Just be aware and let the wheels move where they want to go before fixing alignment.
_________________ Jerry King |
byoungplumbing(at)gmail.c Guest
Posted: Mon Jun 09, 2014 6:15 am Post subject: Xtra Control Problems |
the use of grease plates is good for planes as well... I was amazed to see
how much movement I got in the gear with the use of grease plates.
boyd young
Jerry King
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
