rwwende
Posted: Sun Jun 15, 2014 6:51 pm Post subject: Amps spike when transmitting on comm2 |
Any ideas what would cause my amp reading to spike when I transmit on my sl40. I have the vpx-pro and advance flight 4500. Every time I transmit on my comm 2 the reading spikes to 30 amps and I get the audible warning. This does not happen on comm 1, GNS 430w.
Posted: Sun Jun 15, 2014 7:12 pm Post subject: Amps spike when transmitting on comm2 |
I'd suspect a grounding problem .... either a floating ground or a
ground loop.
First I'd swap antennas at the radio to see if the problem is in the
coax and in particular the coax ground at the antenna, and second, I'd
ring out the ground connections to the SL40. If you have a comm panel
I'd check that as the third guess. Let us know what you find.
Linn
On 6/15/2014 10:51 PM, rwwende wrote:
http://forums.matronics.com/viewtopic.php?p=424908#424908
Checked by AVG - www.avg.com
rene(at)felker.com Guest
Posted: Sun Jun 15, 2014 7:55 pm Post subject: Amps spike when transmitting on comm2 |
I have a similar problem with my sl30. I talked to GRT and they recommended
that I put a balum on the wiring harness. It appeared to clear up the
problem and then it happened again the other day.
More testing is needed.
Rene'
N423CF
801-721-6080
rv10flyer
Posted: Sun Jun 15, 2014 7:56 pm Post subject: Re: Amps spike when transmitting on comm2 |
My SL-40 com 2 has similar issues(the only squawk in the plane since new). It is all wired/coaxed the same. I think the SL-40 puts out more power.
_________________ Wayne G. |
johngoodman
Posted: Mon Jun 16, 2014 5:26 am Post subject: Re: Amps spike when transmitting on comm2 |
| rwwende wrote: | | Any ideas what would cause my amp reading to spike when I transmit on my sl40. I have the vpx-pro and advance flight 4500. Every time I transmit on my comm 2 the reading spikes to 30 amps and I get the audible warning. This does not happen on comm 1, GNS 430w. |
My setup is similar to yours. I haven't noticed large spikes, but I have noticed that there is a different "quality" between Comm 1, and Comm 2. Most of my comm issues I've been able to trace to the audio panel, so I would certainly keep that in mind.
Mike Whisky
Posted: Mon Jun 16, 2014 6:17 am Post subject: Re: Amps spike when transmitting on comm2 |
John,
What did you do to the audio panel or what was the problem? I would not know how the audio panel could be involved in the problem.
Michael
_________________ RV-10 builder (flying)
#511 |
maca2790
Posted: Mon Jun 16, 2014 2:19 pm Post subject: Re: Amps spike when transmitting on comm2 |
| rene(at)felker.com wrote: | I have a similar problem with my sl30. I talked to GRT and they recommended
Rene'
N423CF
801-721-6080
What form did the Balun take Rene'?
I think checking the Grounds as others have suggested is a good point. Or swap the Radios and Coax around and see what happens. You could try bypassing the current sensor with a .01 uf Capacitor.
cheers
John MacCallum
Posted: Mon Jun 16, 2014 3:50 pm Post subject: Amps spike when transmitting on comm2 |
It was just a magnet that wraps around the harness. I bought several sizes
from the aviation department at Amazon and then used the one that fit. More
test are called for. I cannot test on the ground for the most part, only
happens in the air except when it doesn't...you know how that goes.
I have a hall effects sensor, where would the capacitor go?
I think I will try switching the antenna cables......
Rene' Felker
N423CF
801-721-6080
Posted: Mon Jun 16, 2014 4:19 pm Post subject: Amps spike when transmitting on comm2 |
Now I'm curious. would you post the part numbers for the hall effect
sensor and the magnet???
I'm used to seeing ferrite cores on cables to reduce noise, but never
magnets. Most hall effect sensors are a 'switch' that gives a 0V/+V
output and lack the processing circuits for an analog output.
Linn
Rene' Felker
N423CF
801-721-6080
Posted: Mon Jun 16, 2014 5:10 pm Post subject: Amps spike when transmitting on comm2 |
GRT CS-01 Current Sensor -- Current Sensor, +/- 100 AMP. Suitable for
aircraft
with 60 amp alternators.
It is a Ferrite Core....just clamped around the wire bundle.
Rene'
N423CF
801-721-6080
toaster73(at)embarqmail.c Guest
Posted: Mon Jun 16, 2014 5:34 pm Post subject: Amps spike when transmitting on comm2 |
I have a ferrite core around my fuel pressure wire because when I transmit
on the SL30 fuel pressure would go out of limits. The core knocked the
effect down enough to only a couple of pounds of pressure change. So not a
big deal now. More loops of wire through the core made for additional noise
ellimination (to a point).
-Chris
N9191AR
Posted: Mon Jun 16, 2014 5:54 pm Post subject: Amps spike when transmitting on comm2 |
You'll get minimal noise reduction with the ferrite core clamped around
the bundle. A toroidal ferrite core with the signal wires wrapped a
couple of turns would be better. I'm wondering if your antenna coax
runs near the wire that the HE is on. A bad antenna coax could be
coupling energy onto that cable and the HE is responding to it. It's a
WAG but possible.
Linn
aircraft
Rene'
N423CF
801-721-6080
johngoodman
Posted: Tue Jun 17, 2014 5:16 am Post subject: Re: Amps spike when transmitting on comm2 |
| Mike Whisky wrote: | John,
Michael |
Everything goes through my PMA9000EX. Which radio to transmit on, etc. It even records. There are split modes, swap modes, music, all kinds of junk. In short, there are a lot of wires, and a lot of things going on inside. Almost every comm issue I've had was solved by a quick "re-boot" of the audio panel.
rwwende
Posted: Sun Apr 19, 2015 4:11 pm Post subject: Re: Amps spike when transmitting on comm2 |
Well I think I finally found the cause of this problem. The sl40 comes with 12" pig tail coax attached to the tray. It has a nut type connector that pinches the shield to the connector, and it was loose. I tighten the nut and it solved the problem.
The actual amp draw indicated on the vpx-pro when transmitting ranged from 2.5 at the higher freqs, and 4.5 at the lower freqs, 123.x and below. The amp gauge on the EFIS only spiked when I transmitted on the lower freqs.
If you are having this issue, check the coax at the back of the tray.
