		bob88
				 Posted: Mon Jun 23, 2014 8:32 pm    Post subject: Paint Question |
				I plan to defer painting until I have flown a bit, and then have it done professionally. The question is whether to put a coat of UV SmoothPrime on the fiberglass parts as temporary protection. Will a professional paint shop have a problem with this when the time comes for the final paint job?
				 Posted: Tue Jun 24, 2014 4:20 am    Post subject: Paint Question |
				That should not be a problem. Filling the pinholes before flying would assure that oil and stuff doesn't get trapped in the pinholes.
 Jesse Saint
 I-TEC, Inc.
 jesse(at)itecusa.org
 www.itecusa.org
 www.mavericklsa.com
 C: 352-427-0285
 O: 352-465-4545
 F: 815-377-3694
  	  | Quote: | 	 		   On Jun 24, 2014, at 12:32 AM, "bob88" <marty.crooks(at)comcast.net> wrote:
  http://forums.matronics.com/viewtopic.php?p=425349#425349
		cooprv7(at)yahoo.com Guest
				 Posted: Tue Jun 24, 2014 4:37 am    Post subject: Paint Question |
				That’s what I did, no problems whatsoever.  Looks a lot nicer too!
 Marcus
 40286
				 Posted: Tue Jun 24, 2014 4:52 am    Post subject: Paint Question |
				A Lancair 4 builder at the airpark used SmoothPrime for protection during
 construction.  He would do all the body work, then coat/sand the SmoothPrime
 until satisfied.  The last step was to add another coat of SmoothPrime on
 top but then not sand it.  The final sanding would then be just before
 paint.
 If you are going to fly before paint then recommend you do all the
 SmoothPrime/sand applications you want but the last step would be to use an
 epoxy primer on top.  What I learned with SmoothPrime on my plane is it
 takes several days for this water based product to really cure - and then
 never wet sand it.  SmoothPrime is not designed to withstand the elements.
 For the next airplane I'll most likely not use SmoothPrime.  Instead I'll
 use PPG filler primers (K36 and K38) after surface prep.
 Carl
