		| Author | Message |
		| wdaniell.longport(at)gmai Guest
				|  Posted: Tue Jun 24, 2014 8:46 am    Post subject: My ailerons wont go down |   |
				| I am rigging everything prior to closing
I made some templates 23.5 up and 20 down for use on the underside mindful or buds strictures to measure at the hinge
 I have followed the procedure on the book (i think).
  	  | Quote: |  	  | 1. Check that the short aileron link-rod is adjusted such that when the bellcrank W13 is against its stop, the aileron has moved 23.5º up.
 2. With the aileron at neutral, adjust the length of the lateral push-rod so that the quick-connect bellcrank W16 is at 90º to a line between both spar bushes.
 3. Adjust the tie-rod between both cranks CS08 so that both control columns are parallel.
 4. Adjust the short outer push-rods between the CS08’s and the CS15 bellcranks so that the latter are vertical when the control columns are vertical.
 When the wings are rigged the aileron movement should be 23.5º up and 20º down with full lateral control column movement and both ailerons should be in their neutral positions together when the
 My ailerons go up the required 23.5 deg against both stops but they don't go down the required 20 deg...not even close I would guess that they are about 15-17 down
 I have taken it to bits and put it together fiddled around but Im stumped.  What I am I doing wrong?
 Might it be that the control columns should not be parallell in this case due to variation in the build....Â
 thanks
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Tue Jun 24, 2014 9:33 am    Post subject: My ailerons wont go down |   |
				| William, I don't know the answer, but if you haven't got
one I would strongly advise getting or borrowing a Smart
 Tool so that you can easily and very accurately measure
 angles. It does occur to me to wonder whether you are
 measuring your up and down angles off the same surface
 (i.e. Are you measuring the neutral angle of say the upper
 surface, then measuring the up and down angles of the
 upper surface, rather than the up angle of the upper
 surface and the down angle of the lower surface) Regards,
 David Joyce, G-XSDJ
 On Tue, 24 Jun 2014 11:44:48 -0500
 William Daniell <wdaniell.longport(at)gmail.com> wrote:
  	  | Quote: |  	  | I am rigging everything prior to closing
 underside mindful
 *1. Check that the short aileron link-rod is adjusted
 such that when the
 bellcrank W13 is against its **stop, the aileron has
 moved 23.5º up.*
 *2. With the aileron at neutral, adjust the length of
 so that the quick-connect **bellcrank W16 is at 90º to a
 line between both
 spar bushes.*
 *3. Adjust the tie-rod between both cranks CS08 so that
 both control
 columns are parallel.*
 *4. Adjust the short outer push-rods between the CS08’s
 and the CS15
 bellcranks so that the latter are **vertical when the
 control columns are
 vertical.*
 *When the wings are rigged the aileron movement should
 be 23.5º up and 20º
 down with full lateral **control column movement and
 be in their neutral positions together when the*
 *control columns are vertical.*
 guess that they are
 about 15-17 down
 thanks
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
		| Back to top |  |
		| JonathanMilbank
				|  Posted: Tue Jun 24, 2014 10:22 am    Post subject: Re: My ailerons wont go down |   |
				| You're quite sure that the aileron mass balances aren't touching the wing upper surfaces inside the recesses? I have the old foam-filled wings and maybe such a phenomenon isn't likely with the newer factory-made wings.
 I sure struggled with shaving bits of lead and adjusting the aileron mass balance arm attachments until I could barely reach the down limit.
 Then of course there's the problem which could arise if the aileron quick connector pivots in the fuselage and on the spars don't align.
 I ended the long struggle to rig the ailerons correctly with only just getting sufficient up and down deflection, but with a tiny amount of reflex when both ailerons are ostensibly in the neutral position.
		| Back to top |  |
				|  Posted: Tue Jun 24, 2014 10:52 am    Post subject: My ailerons wont go down |   |
				| Thanks...all good suggestions however sadly its not mass balance arms I checked by shining a light through the mass balance boxes....not even close to the skin
Will On 24 Jun 2014 13:30, "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)> wrote:[quote] --> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
 http://forums.matronics.com/viewtopic.php?p=425376#425376
 st" target="_blank">http://www.matronics.com/Navigator?Europa-List
 MS -
 e -
          -Matt Dralle, List Admin.
		| Back to top |  |
		| Richard Wheelwright
				|  Posted: Tue Jun 24, 2014 11:27 am    Post subject: My ailerons wont go down |   |
				| Could it be the stop in the opposite wing stoping it going down far enough? It it is you must set the quick connect at the wing root exactly vertical to the two holes in the spars. And also the quick connect in the fuselage exactly vertical to each other. This is your starting point.
 Richard
 On 24 Jun 2014, at 19:50, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
  	  | Quote: |  	  | --> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
 MS -
 e -
 Richard Wheelwright
 G-IRPW
 First Flight 24th July 2013
		| Back to top |  |
		| budyerly(at)msn.com Guest
				|  Posted: Tue Jun 24, 2014 1:57 pm    Post subject: My ailerons wont go down |   |
				| William,
Look at the attached.  Contains quite a bit of info on rigging the ailerons
		| Back to top |  |
				|  Posted: Tue Jun 24, 2014 2:25 pm    Post subject: My ailerons wont go down |   |
				| David
Yes the thought ocurred to me and it could be that this is the root of the problem.  I made two templates and following buds instructions measured at the hinge both for up and down ie using the lower surface of the wing compared to the lower surface of the aileron.   So yes I am measuring both up and down from the same place...the inboard hinge mid point.
 Is this correct?
 Will On 24 Jun 2014 12:43, "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:[quote] --> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
 William, I don't know the answer, but if you haven't got one I would strongly advise getting or borrowing a Smart Tool so that you can easily and very accurately measure angles. It does occur to me to wonder whether you are measuring your up and down angles off the same surface (i.e. Are you measuring the neutral angle of say the upper surface, then measuring the up and down angles of the upper surface, rather than the up angle of the upper surface and the down angle of the lower surface) Regards, David Joyce, G-XSDJ
 *1. Check that the short aileron link-rod is adjusted such that when the
 bellcrank W13 is against its **stop, the aileron has moved 23.5º up.*
 *2. With the aileron at neutral, adjust the length of the lateral push-rod
 so that the quick-connect **bellcrank W16 is at 90º to a line between both
 spar bushes.*
 *3. Adjust the tie-rod between both cranks CS08 so that both control
 *4. Adjust the short outer push-rods between the CS08’s and the CS15
 bellcranks so that the latter are **vertical when the control columns are
 vertical.*
 *When the wings are rigged the aileron movement should be 23.5º up and 20º
 down with full lateral **control column movement and both ailerons should
 about 15-17 down
 thanks
 Will
 William Daniell
 LONGPORT
 [url=tel:%2B57%20310%20295%200744]+57 310 295 0744[/url]
 MS -
 e -
		| Back to top |  |
				|  Posted: Tue Jun 24, 2014 3:56 pm    Post subject: My ailerons wont go down |   |
				| mmm yes did all that right...I think.    I put the spar pins and put straight edge between them in and then used an set square to ensure QD face 90deg to straight edge
 Obviously I am doing something wrong....but I can figure out what.
 I mean I set the up stop to 23.5 degrees
 i made the wing QD vertical to a line between the spar pins
 I made the control columns vertical and parallel
 Set the the fuze QD vertical
 and the result is ....It's driving me mad because I cant see the error.
 Am I measuring the deflection wrong by using a template of  24% degree relative to the lower wing skin on the aileron hinge?....Or measuring the down deflection in the same way using a 20 deg template?
 I read Bud's instructions and I understand that in practice the up deflection should be 1 degree less than the 23.5deg of the manual... I will try that for a start and then start adjusting the short link rods of the fuselage to get more down throw
 thanks for you help
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Tue, Jun 24, 2014 at 2:26 PM, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk (rpwheelwright(at)yahoo.co.uk)> wrote:
 [quote] Could it be the stop in the opposite wing stoping it going down far enough? It it is you must set the quick connect at the wing root exactly vertical to the two holes in the spars. And also the quick connect in the fuselage exactly vertical to each other. This is your starting point.   Â
 RegardsÂ
 Richard
  	  | Quote: |  	  | Thanks...all good suggestions however sadly its not mass balance arms I checked by shining a light through the mass balance boxes....not even close to the skin
 MS -
 e -
		| Back to top |  |
		| kingsnjan(at)westnet.com. Guest
				|  Posted: Tue Jun 24, 2014 6:19 pm    Post subject: My ailerons wont go down |   |
				| William,
 I don't pretend to know the solution but another thing that could be a source of the problem is the positioning of the drive stud on the aileron onto which the push rod connects.
 This positioning is critical in order to get enough throw on the ailerons.
 Bud may be able to suggest an easy method to check this if indeed he agrees with my thoughts.
 Cheers
 Kingsley in Oz
		| Back to top |  |
				|  Posted: Tue Jun 24, 2014 11:57 pm    Post subject: My ailerons wont go down |   |
				| William, I don't know that I can really be any help
without looking at the set up directly. But my point about
 the Smart tool is that it is an inclinometer (and there
 are cheaper if slightly less accurate ones available) with
 which you can measure the angle of the top surface in
 neutral, fully up and fully down positions. Subtracting
 one from the other gives you your deflections with no
 scope for confusion. I was not clear whether you are doing
 these measurements with both wings rigged and if so
 whether you are getting full down and limited up on each
 side. Also whether measuring deflections on the unrigged
 isolated wing gives you the full range (which of course
 rules out any question of the mass balance horn
 interfering).
 On Tue, 24 Jun 2014 17:25:15 -0500
  	  | Quote: |  	  | David Yes the thought ocurred to me and it could be that this
 is the root of the
 surface of the wing
 am measuring both
 point.
 Is this correct?
 Will
 >one I would
 >that you can easily
 >to wonder whether
 >surface (i.e. Are
 >the up angle of
 > Joyce, G-XSDJ
 >>underside mindful
 >>such that when the
 >>moved 23.5º up.*
 >>line between both
 >> spar bushes.*
 >>both control
 >>and the CS15
 >>control columns are
 >> vertical.*
 >>be 23.5º up and 20º
 >>guess that they are
 >> about 15-17 down
 >> thanks
 >> Will
 >> William Daniell
 >> LONGPORT
 >> +57 310 295 0744
		| Back to top |  |
				|  Posted: Wed Jun 25, 2014 12:03 am    Post subject: My ailerons wont go down |   |
				| William, As a PS if you do have full range on the unrigged
wings and full down/reduced up on both with both wings
 rigged , then you need to adjust the length of  control
 rods between wingroot and bell crank. Regards, David
 is the root of the
 surface of the wing
 am measuring both
 point.
 Is this correct?
 Will
 >one I would
 >that you can easily
 >to wonder whether
 >surface (i.e. Are
 >the up angle of
 > Joyce, G-XSDJ
 >>underside mindful
 >>such that when the
 >>moved 23.5º up.*
 >>line between both
 >> spar bushes.*
 >>both control
 >>and the CS15
 >>control columns are
 >> vertical.*
 >>be 23.5º up and 20º
 >>guess that they are
 >> about 15-17 down
 >> thanks
 >> Will
 >> William Daniell
 >> LONGPORT
 >> +57 310 295 0744
		| Back to top |  |
				|  Posted: Wed Jun 25, 2014 3:16 am    Post subject: My ailerons wont go down |   |
				| Gentlemen thanks for your contributions
I do have more than the full movement required without the wings rigged leading me to identify the control system as the prime suspect.
 I shall re-start the process from scratch next weekend (very annoying how work interferes with building)
 thanks WillI do actually have a smart tool but it's a long one which is too unwieldy for the ailerons so I will acquire a short one  Reducing the up throw by one degree per bud's instructionsAdjust the wing QD to 90 deglevel everything and check that the fuselage end is all correct control columns vertical and parallelcentre the ailerons and ensure that the QDs are vertical (using my newly acquired short smart tool)
And then if that doesn't solve it start playing around with the fuselage link rods - where  I now suspect the culprit lies. I think on reflection that I haven't followed the process carefully enough so ....I am going to do it again...
 William Daniell
 LONGPORT
 On Wed, Jun 25, 2014 at 3:02 AM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
 William, As a PS if you do have full range on the unrigged wings and full down/reduced up on both with both wings rigged , then you need to adjust the length of  control rods between wingroot and bell crank. Regards, David
  	  | Quote: |  	  | David Yes the thought ocurred to me and it could be that this is the root of the
 Is this correct?
 Will
 ============ 	  | Quote: |  	  | --> Europa-List message posted by: "David Joyce" < davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
 Joyce, G-XSDJ
 spar bushes.*
 vertical.*
 about 15-17 down
 thanks
 Will
 William Daniell
 LONGPORT
 MS -
 e -
		| Back to top |  |
		| Fred Klein
				|  Posted: Wed Jun 25, 2014 6:11 am    Post subject: My ailerons wont go down |   |
				| Will…sorry that I’ve been unable to help, but please do make a posting detailing how this works out for you; I suspect it would be most helpful to others…Fred
On Jun 25, 2014, at 4:15 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
  	  | Quote: |  	  | Gentlemen thanks for your contributions
		| Back to top |  |
				|  Posted: Wed Jun 25, 2014 6:47 am    Post subject: My ailerons wont go down |   |
				| William, If your Smartool is anything like my long
smartool you can unscreww the short smartool from it
 rather than buy another. Regards, David Joyce
 On Wed, 25 Jun 2014 06:15:43 -0500
 the wings rigged
 suspect.
 (very annoying how
 - I do actually have a smart tool but it's a long one
 which is too
 one
 - Reducing the up throw by one degree per bud's
 instructions
 - Adjust the wing QD to 90 deg
 - level everything and check that the fuselage end is
 all correct
 - control columns vertical and parallel
 - centre the ailerons and ensure that the QDs are
 vertical (using my
 - And then if that doesn't solve it start playing
 around with the
 lies.
 - I think on reflection that I haven't followed the
 process carefully
 thanks Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 >you need to adjust
 >> David
 >>is the root of the
 >>surface of the wing
 >>am measuring both
 >>point.
 >> Is this correct?
 >> Will
 >>>one I would
 >>>that you can easily
 >>>to wonder whether
 >>>surface (i.e. Are
 >>>the up angle of
 >>> Joyce, G-XSDJ
 >>>>underside
 >>>> mindful
 >>>>such that when the
 >>>>moved 23.5º up.*
 >>>>the lateral
 >>>> push-rod
 >>>>line between
 >>>> both
 >>>> spar bushes.*
 >>>>both control
 >>>>and the CS15
 >>>>control columns
 >>>> are
 >>>> vertical.*
 >>>>be 23.5º up and
 >>>> 20º
 >>>>both ailerons
 >>>> should
 >>>>stops but they
 >>>> don't
 >>>>guess that they are
 >>>> about 15-17 down
 >>>>around but Im
 >>>> stumped.
 >>>>parallell in this
 >>>> case
 >>>> thanks
 >>>> Will
 >>>> William Daniell
 >>>> LONGPORT
 >>>> +57 310 295 0744
		| Back to top |  |
				|  Posted: Wed Jun 25, 2014 12:18 pm    Post subject: My ailerons wont go down |   |
				| <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Will,
You've got the right attitude.
 Setting the belcrank on the wing to 90 degrees is only one part of the  rig.  Your fuselage QDs may be the culprit as well.  You can adjust  the aileron as suggested many ways.  Check that your flaps and  wingtips are not drooping.  Use your incidence board and check the flaps on  both sides are dead level with the board.  If your board is lost, you have  only the lower wing to set level across the flaps with the lower first six  inches of the wing skin.
 Big thing to remember is the outer short push rod sets the up limit at  nominally 23.5 to 24.5 (25.5 max). The up limit on one aileron sets  the down limit on the other.  If you have full required travel of the  aileron (roughly 42-46 degrees) your problem is normally your QDs are not set  vertical to the ground with the fuselage level and plumb.
 Measuring with a Smart digital level is made easier by some manufacturers  by removing the center portion.  Now you have a short smart level.   The smart tool is a bit cumbersome to use but essential for the flap/stab  measurements.  For the ailerons, I use a simple protractor made by General  (#29) for inside and outside measurements.  It is about $5.  (A  carpenters bevel gauge works outstanding also.)
 Set the protractor/bevel gauge at the desired angle and put it just to  the outboard of either wing hinge (I use the inboard) and take a quick  look and adjust down to about 24.5 degrees or so by just holding the gauge to  the wing and looking at the gap.  With the aileron up (outside postion  on the protractor) I set the pushrod to give me 23.5 to 24.5 as set on my  protractor/bevel gauge.  I do the same on the other wing.  I check  that with the aileron down I get full down plus some before the wt.  hits the closeout.  Then set the fuselage and wing QD to vertical.   That should work, but doesn't always as you found out!
 Some adjustment of the fuselage QD belcrank is necessary to get the  ailerons to be level with the flaps and outboard wing tip.  Use your now  shortened smart tool to get the fuselage QD vertical with the outer skin as best  you can, or put the pins in and set a T square on them to set the QDs.   Yes, I know the T square is too big, so put the long section in the fuselage and  use a piece of 6 inch 3/4 lumber on the QD and align it with the square.   Make sure both sides are the same.  Set the wing lateral push rod to get  the wing QD parallel to the pins.  Don't get excited about setting the  phenolic pads right now.  Look hard at your bolt head alignment on the  QDs.  They are probably off a bit.  By adjusting slightly the angle of  the QD you can adjust for some misalignment.  Then put in the final  pad.  (If too far apart, tack some phenolic in place with a drop of super  glue to help get things close to final.)  Repeat on the other wing.   Note the ailerons for droop or reflex (up) with both wings rigged and  pinned.  The ailerons should be even (both slightly up or down).   Now, degrig, adjust the lateral pushrod a turn in the appropriate direction  on each side, and rerig.  Continue until you have them both even and the  throw correct.
 To be honest, sometimes the wingtip is a bit off, so if your flaps are dead  on, use them.  If the tips are off, I use a smart level and my T  squares to measure if there is twist between wings.  That's another fix we  won't get into right now. See my trimming notes if the incidence or flaps  are not exactly the same.
 Good luck this weekend.  You have all the tools and frankly it sounds  like you have the total throw so you're almost there.
 Remember, if you haven't taken it apart and put it together at  least five times (per wing), you're doing it wrong.
 Bud Yerly
 [quote]   ---
		| Back to top |  |
				|  Posted: Thu Jun 26, 2014 1:23 pm    Post subject: My ailerons wont go down |   |
				| thanks I will let y'all know how it goes.  I'm warming up for round two this weekend.
Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Wed, Jun 25, 2014 at 3:17 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
 [quote]          Will,
 Â
 Â
 Â
 Measuring with a Smart digital level is made easier by some manufacturers  by removing the center portion.  Now you have a short smart level.   The smart tool is a bit cumbersome to use but essential for the flap/stab  measurements.  For the ailerons, I use a simple protractor made by General  (#29) for inside and outside measurements.  It is about $5.  (A  carpenters bevel gauge works outstanding also.)Â
 Â
 Set the protractor/bevel gauge at the desired angle and put it just to  the outboard of either wing hinge (I use the inboard) and take a quick  look and adjust down to about 24.5 degrees or so by just holding the gauge to  the wing and looking at the gap.  With the aileron up (outside postion  on the protractor) I set the pushrod to give me 23.5 to 24.5 as set on my  protractor/bevel gauge.  I do the same on the other wing.  I check  that with the aileron down I get full down plus some before the wt.  hits the closeout.  Then set the fuselage and wing QD to vertical.   That should work, but doesn't always as you found out!Â
 Â
 Â
 To be honest, sometimes the wingtip is a bit off, so if your flaps are dead  on, use them.  If the tips are off, I use a smart level and my T  squares to measure if there is twist between wings.  That's another fix we  won't get into right now. See my trimming notes if the incidence or flaps  are not exactly the same.Â
 Â
 Â
 Remember, if you haven't taken it apart and put it together at  least five times (per wing), you're doing it wrong. Â
 Â
 Bud Yerly
 Â
 Â
 [quote]   ---
		| Back to top |  |
				|  Posted: Tue Jul 01, 2014 6:34 pm    Post subject: My ailerons wont go down |   |
				| the take aways from this are:Firstly thanks to Howard Brooks who gave me the idea of downloading a clinometer from google play to my phone.  I built a sort of stand so that the phone can stand on its edge out of a piece of hardware aluminium angle.  Thus I could clip the phone to the trailing edge of the aileron.  I checked the download against my smart tool - it turned out to be as good as my smart tool.  Next I fitted the flaps and ailerons lined them up and and marked the neutral position on the wing tip to avoid having to take the wings on and off with the flaps on. incidentally using my newly acquired clinometer I found that my left flap as lower by 1 deg than the right flap.  So i used Buds flap trimming advice and epoxied 4 plies of lay up on the top of the flap drive hole.  Now the flaps are identical.  Next I took everything apart checked the aileron throw with my new phone clinometer.  The left aileron was close to ok but i reset that to 22.5 up and set the wing QD to 90 deg to the bushes.    The right wing was waaay out.  I sounded like the front edge of the aileron was contacting the channel in which it sits not allowing it to go full up.  I checked this out by using a pencil scribble in the channel and masking tape on the LE of the aileron.  It was contacting the channel right at the tip.  At the same time the lower surface of the aileron was about 1/8 below the lower surface of the wing.  So i taped a 3/16 washer as a spacer between the hinge and the wing.  The lower surface was level with the wing and i got 24 deg up.  I put 5 lay ups (over and above the reinforcement plies as a spacer on the hinge contact point.  I set the left aileron to 22.5 up and made the QD 90deg to spar pins  I next went after the fuselage end.  I had some aileron control tube left over which I cut in half and inserted into the control columns to check that the sticks are parallel - I used a couple of lazer levels but as bud says the eye was just as accurate.  I then centered the sticks by using a spirit level on the top of the aluminium stick socket  - I figured if the top of the socket was level then the stick would be vertical.  Using a long 1/4 bolt I marked the center point on the seat front - drilled a 1/4 in hole and now i have the sticks centered and held.    Next I turned my attention the fuze QD.  Using a cut down spirit level which I had previously checked for accuracy i checked that the QDs were vertical with the sticks vertical.  ( I had previously leveled the fuze both ways).  they were.  I put is all together and hey presto very close to perfect.Ive still got some fiddling around to do but buds instructions were spot on.
 thanks for all help and suggestions I hope this is the last bleat (on this subject)measuring tools are not tools they are "instruments" and require checking.     Only some of the levels i had were accurate I had previously used a old style clinometer - like a protractor with a dial- it simply wasn't accurate enough  check all your instruments coincide before you startthe free download clinometer is the absolute business as accurate as the smart level and a lot cheaper
You get better at this as you go along.  I was pretty much sure I had done the process right the first time a couple of years back.There was a wrinkle which as the right wing aileron movement which I would have picked up if I had had the right kit.
 yours
 Will
 William Daniell
 LONGPORT
		| Back to top |  |
