		jdriggs49(at)msn.com Guest
				 Posted: Wed Jun 25, 2014 7:28 pm    Post subject: Jae::::RE: Extra fuel |
				What are you using for a rear seat tank?
  	  | Quote: | 	 		   Date: Wed, 25 Jun 2014 12:42:05 -0700
  To: rv10-list@matronics.com
  Subject: Re: RV10-List: Extra fuel
  --> RV10-List message posted by: Jae Chang <jc-matronics_rv10@jline.com>
  I got tired of flying solo and looking at all the empty space. I decided
  to use the extra space and put a 32 gal aux fuel tank secured in a rear
  passenger seat. I can remove or install it empty in about 10 mins. Once
  you fly with the extra fuel, you will never ever want to go back! I was
  able to fly SFO to Kansas to JYO in 15 hours total time or in 13 hours
  of air time. I had some delays on my one planned fuel stop (actually
  ended up being 2 because an FBO was closed), so i know i can do even
  better next time. Even on shorter flights, it is nice not worrying about
  getting fuel all the time.
  My only disappointment is knowing that Van will never consider
  engineering an extra fuel option. I would do that mod in a heartbeat!
  Also, i considered keeping the extra fuel in the baggage compartment,
  but i think the rear seat is better. Access to the baggage area is more
  difficult for installing and removing. Also, it is potentially harder to
  add fuel in the baggage area. I can easily add fuel if i want through
  the big doors without much effort.
  #40533 RV-10
  First flight 10/19/2011
  Phase 1 Done 11/26/2011
  _-============================================================
  _-=          - The RV10-List Email Forum -
  _-= Use the Matronics List Features Navigator to browse
  _-= the many List utilities such as List Un/Subscription,
  _-= Photoshare, and much much more:
  _-=
  _-=   --> http://www.matronics.com/Navigator?RV10-List
  _-=
  _-=               - MATRONICS WEB FORUMS -
  _-= Same great content also available via the Web Forums!
  _-=
  _-=   --> http://forums.matronics.com
  _-=
  _-=             - List Contribution Web Site -
  _-=  Thank you for your generous support!
  _-=                              -Matt Dralle, List Admin.
  _-=   --> http://www.matronics.com/contribution
		jchang10
				 Posted: Thu Jun 26, 2014 8:19 am    Post subject: Jae::::RE: Extra fuel |
				On 6/25/2014 8:27 PM, Danny Riggs wrote:
 This is the fuel cell. KISS principle applies here.
 http://www.vansairforce.com/community/showthread.php?t=96010
 I don't have any good photos actually but nothing special. I started
 with the thread above but bent my own tubing. I built a frame out of
 wood (for now) for the tank to sit on and to secure it to. It's secured
 into the airframe reusing the rear seat hinge and a couple of the
 existing #8 screws around the seat area. Plumbed into the extra port on
 stock vans valve. I used quick disconnects for all connections including
 the external vent which is a must. I used extra plastic tubing to vent
 to the wing root area similar to the main vent.
 There are certainly many variations. However, even this simplest of
 methods has worked out well. The one change i am contemplating is
 converting the tank to a bottom outlet to minimize potential vapor
 issues with the top draw.
 #40533 RV-10
  _________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
				 Posted: Thu Jun 26, 2014 11:28 am    Post subject: Jae::::RE: Extra fuel |
				Thanks Jae!
 I'm the RV10 builder you met on the shuttle bus from KAVX to Avalon harbor a couple of years ago. Dan Riggs
  	  | Quote: | 	 		   Date: Thu, 26 Jun 2014 09:18:26 -0700
  Subject: Re: Jae::::RE: RV10-List: Extra fuel
  http://www.jegs.com/i/JEGS-Performance-Products/555/15505/10002/-1?parentProductId=837886
  #40533 RV-10
  _-=
  _-=
  _-=
  _-=
