Posted: Fri Jun 27, 2014 7:34 am Post subject: Extra fuel |
On 6/27/2014 9:40 AM, johngoodman wrote:
Strangely enough, up until recently my fuel gauges always show slightly
more fuel than I actually have and the totalizer slightly less.
Splitting the difference gave me the right number. Running with the
totalizer number gave me a safety factor.
The totalizer issue was due to placing the GRT unit in the Van's plans
location. It ran high when the boost pumps was on and who knows what
else. Relocating it to between the controller and spider makes it
amazingly accurate now.
My fuel gauges never show completely full tanks but they will show even
the slightest amount of remaining fuel sloshing about. I assume some of
this is a calibration issue with the GRT EIS but it works fine as is.
With 10 gallons left my approach is to have most of those in one tank
and to run off the other (and hard VFR with airports underneath). If
there's even a hiccup, tanks get switched and we are landing NOW. Not
my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry
even for testing but did spend a year measuring things very carefully.
OK, I've got to ask...
When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left?
http://forums.matronics.com/viewtopic.php?p=425579#425579
Checked by AVG - www.avg.com
Posted: Fri Jun 27, 2014 7:51 am Post subject: Extra fuel |
The floats hit the top of the tank around 24-26 gallons because if the dihedral. If installed and calibrated correctly, they will read accurately down to very close to empty.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Jun 27, 2014, at 11:34 AM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor.
The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now.
My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is.
With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully.
> John
> #40572 Phase One complete in 2011
> No virus found in this message.
Deems Davis
Posted: Fri Jun 27, 2014 9:12 am Post subject: Extra fuel |
I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly!
Give yourselves a hand of applause, You've come a long way!
Deems
On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: [url=tel:352-427-0285]352-427-0285[/url]
O: [url=tel:352-465-4545]352-465-4545[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
> On Jun 27, 2014, at 11:34 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
> --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
> Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Â Splitting the difference gave me the right number. Â Running with the totalizer number gave me a safety factor.
> The totalizer issue was due to placing the GRT unit in the Van's plans location. Â It ran high when the boost pumps was on and who knows what else. Â Relocating it to between the controller and spider makes it amazingly accurate now.
> My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. Â I assume some of this is a calibration issue with the GRT EIS but it works fine as is.
> With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). Â If there's even a hiccup, tanks get switched and we are landing NOW. Â Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully.
>> --> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
>> John
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Posted: Fri Jun 27, 2014 9:37 am Post subject: Extra fuel |
I agree with Deems. I got started on the list with no pilot or mechanic license. Now I have both. I've learned a lot from this group and have enjoyed the journey.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jun 27, 2014, at 1:11 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
[quote]I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly!
Deems
| Quote: | --> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
>> John
MS -
e -
List"">http://www.matronics.com/Navigator?RV10-List
Tim Olson
Posted: Fri Jun 27, 2014 10:09 am Post subject: Extra fuel |
It really has been a great learning experience for everyone,
me too. Some of the people I've met became like family.
The aircraft itself has been truly amazing and now I don't
know what I'd do without it. Coming from spam cans, there
really is no way I'd want to go back. I think many people
these days don't know what they're missing by NOT trying to
do things like build your own airplane. Do they really
think it's beyond them? Look at how many of us found out
that it really isn't.
It's also been really great that people like Deems and many
others have tried new things and shared their experiences
along the way. It's helped everyone to improve their
own plane.
It's really easy to see that those who've actually
completed their RV-10 can meet the spirit of the intent
of the Experimental Amateur Built category...recreation
and education....because it's that's what it's been
for me in a big way.
On 6/27/2014 12:11 PM, Deems Davis wrote:
| Quote: | I've been reading the threads on fuel and performance lately, and have
Deems
bruce1hwjohnson(at)yahoo. Guest
Posted: Fri Jun 27, 2014 10:36 am Post subject: Extra fuel |
Not sure on his how it would be, but on mine I adjusted the floats to the lower end. So when full they only read 23 or 24 gallons but are pretty accurate at the bottom.
God Bless America
(please)
Bruce
On Friday, June 27, 2014 11:24 AM, Tim Olson <Tim(at)MyRV10.com> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
own plane.
Give yourselves a hand of applause, You've /www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matron http://forums.msp; - List Contribution Web Site -
_; &nb://www.matronics.com/contribution" target="_blank">http://www.matronics.c===================
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Fri Jun 27, 2014 10:41 am Post subject: Extra fuel |
I want to say that you guys are my source of inspiration. Every time I look at the project and get discouraged by the amount of work still to go, I read some of your logs and stories and am inspired. I also find Jesse dad’s stories very encouraging having worked in overseas mission.
Bill Greenley
Starting to put the top on the fuselage, fiberglass here I come
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Friday, June 27, 2014 1:36 PM
Subject: Re: Re: Extra fuel
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Deems
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
| Quote: | On Jun 27, 2014, at 11:34 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
> John
MS -
e -
| Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3DList"">http://www.matronics.com/Navigator?RV10-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D//forums.matronics.comD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dot;">http://www.matronics.com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
| 0123456789 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7
Bob Turner
Posted: Fri Jun 27, 2014 10:51 am Post subject: Re: Extra fuel |
When landing in a strong crosswind I try to draw fuel from the raised wing in the side slip. If you run one tank dry there's a fifty-fifty chance you won't be able to do that. Personally, I don't transition to a slip until well into the flare, so it's not a big deal, but something to keep in mind. Especially if a go around is needed.
_________________ Bob Turner
RV-10 QB |
rv10free2fly(at)yahoo.com Guest
Posted: Fri Jun 27, 2014 2:37 pm Post subject: Extra fuel |
Us guys from the big island to the Deep South also thank you all for sharing your experiences and knowledge. I could not have built this aircraft with such confidence without you all. Thank you ever so much.
I'm hoping to catch up with as many of you as possible next year at Oshkosh.
Warm regards
Patrick Pulis
Adelaide, South Australia
#40299
On 28 Jun 2014, at 3:06, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]I agree with Deems. I got started on the list with no pilot or mechanic license. Now I have both. I've learned a lot from this group and have enjoyed the journey.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly!
Deems
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
>> John
MS -
e -
