source for Torx screws?
carlossa52(at)gmail.com
PostPosted: Sun Jun 29, 2014 8:47 am    Post subject: source for Torx screws? Reply with quote
Hello,
I'm looking for a source of 10-32 x 1/2" 100 Degree Flat Head Torx Machine Screws. Microfasteners.com has them 3/4" but I 1/2" is long enough.
I've searched for a long while, but could not find exactly what I want. Does anyone have a source for this that I could try?
Note: McMaster-Carr does *not* ship to Canada - and a quick search did not produce an exact hit.
Thanks in advance
Carlos
jaybannist(at)cs.com
PostPosted: Sun Jun 29, 2014 10:49 am    Post subject: source for Torx screws? Reply with quote
Carlos, Try Fastenal.
Terry Phillips
PostPosted: Mon Jun 30, 2014 11:20 am    Post subject: source for Torx screws? Reply with quote
Hey, Carlos
The  microfasteners screws are stainless, so why not just cut them to size (the cut end will not corrode):
http://grathio.com/2013/06/quick-tip-cutting-bolts-to-length/
I've cut many steel bolts with cheap Harbor Freight cutting disks similar to the one illustrated. Bevel the edges a bit and you're good to go.
Terry
[quote] [img]cid:part1.00030906.00040100(at)gmail.com[/img]
Carlos Sa (carlossa52(at)gmail.com)
Sunday, June 29, 2014 10:46 AM
Hello,
Thanks in advance
Carlos
Terry Phillips, KE7ZZZ
Corvallis MT
 Filesize:  770 Bytes
 Viewed:  6015 Time(s)
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
