kearney
Posted: Fri Jul 04, 2014 6:36 pm Post subject: Flap Chafing / Tape |
Hi
I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight.
I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin.
Has anyone faced this problem and if so how did you deal with it.
Is there any preference to putting the tape on the flap or underneath the skin?
Is there any tape that is preferable?
Cheers
Les
rleffler
Posted: Sat Jul 05, 2014 2:12 am Post subject: Flap Chafing / Tape |
I installed tape on the bottom of the upper skin. I installed it during final assembly after painting. I made no adjustments to make the gap wider. No problems or scratches after 1.5 years.
Bob
Sent from my iPad
| Quote: | On Jul 4, 2014, at 10:36 PM, "kearney" <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=426106#426106
_________________ Bob Leffler
N410BL - Phase I
Posted: Sat Jul 05, 2014 4:03 am Post subject: Flap Chafing / Tape |
Vans sells a tape that works great. It is definitely best to put it under the bottom skin, because it discolors and looks bad on the flap. I wouldn't bend the skin. The flap, when up, will bend the top skin ever so slightly, but this gives it a nice tight seal with no extra drag.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Jul 5, 2014, at 6:11 AM, Bob Leffler <rv(at)thelefflers.com> wrote:
Bob
Sent from my iPad
> Hi
> Cheers
> Les
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sat Jul 05, 2014 4:34 am Post subject: Re: Flap Chafing / Tape |
I used the Vans tape and have not had any issues in the last 5 years. Put the tape in the underside of the wing skin after paint. As the others have said you will want the tight seal in reflex to reduce drag.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Posted: Sat Jul 05, 2014 5:26 am Post subject: Flap Chafing / Tape |
I used the UHMW tape from Van's. I put the tape on the flaps after paint,
the bottom of the tape flush with the wing skin with the flap in the up
position. My thought was if the tape is on the bottom of the skin then if
any piece of grit got between the tape and the flap it would scratch the
paint on the flap.
I did the same on the 8A. The tape lasted right at 10 years. When I sold
the plane I replaced the tape by using just a little hot air gun to soften
it the tape but not the paint. The replacement process took just a few
minutes.
I found other places to use the tape as well, like where the inboard rudder
peddle cable links come close to the sides of the tunnel.
Carl
arplnplt(at)gmail.com Guest
Posted: Sat Jul 05, 2014 5:56 am Post subject: Flap Chafing / Tape |
I opened the gap a bit and my painter installed the tape under the skin.
No issues.
Dave Leikam
On Jul 4, 2014, at 9:36 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
Leeverett
Posted: Sat Jul 05, 2014 2:27 pm Post subject: Flap Chafing / Tape |
Timely question for me. After 125 hrs I have a small line (1") of wear. I took it to the paint shop in Tusculoosa yesterday to have it touched up. The painter who did a great job on the plane has recommended the tape under the trailing edge wing skin. Leon Everett
| Quote: | Subject: RV10-List: Flap Chafing / Tape
Date: Fri, 4 Jul 2014 19:36:39 -0700
To: rv10-list@matronics.com
--> RV10-List message posted by: "kearney" <kearney@shaw.ca>
Hi
Cheers
Les
_-============================================================
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= =
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
Gordon Anderson
Posted: Sun Jul 06, 2014 11:19 am Post subject: Flap Chafing / Tape |
Les,
The trailing edge of the upper skin was pretty wavy on my QB wings. In reflex position I measured everything between gaps of 1/8" to interference of almost 1/8" which I considered a bit too much preload on the flap. It is very easy to adjust these by hand to give a more or less uniform snug fit (ie. touching with very light preload) along the length of the flap.
Cheers,
Gordon
41015, Switzerland
On Jul 5, 2014, at 4:36 AM, kearney wrote:
Hi
Cheers
Les
kearney
Posted: Tue Jul 08, 2014 7:38 pm Post subject: Re: Flap Chafing / Tape |
Hi
Thanks to everyone for the chafing suggestion. I'll go with the tape under the wing skin.
Cheers
Les
rv10flyer
Posted: Mon Jul 14, 2014 6:04 pm Post subject: Re: Flap Chafing / Tape |
My tape is under the top skin as many above.
The only things I can add are...
While flaps are down in the hangar, before every flight from home, clean and wax flap top leading edges where they contact tape. Clean tape too.
When landing on a wet grass strip like Triple Tree (SC00), do not retract muddy flaps past halfway until you shut down. Then clean them and the tape.
_________________ Wayne G. |
