kearney
Posted: Mon Jul 07, 2014 6:40 pm Post subject: Access to tire vale stems |
Hi
I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily.
Cheers
Les
Posted: Mon Jul 07, 2014 6:53 pm Post subject: Access to tire vale stems |
Do yourself a favor and convert you wheels to take 90 degree valve
stems. Use a valve stem extender sold in truck tire stores through a
small hole in the wheel pant to air up the tire. To make it easy to
line up the stem/hole paint a white stripe vertically on the inside of
the tire ..... you can see the stripe when you're handling the tow bar.
Linn
On 7/7/2014 10:40 PM, kearney wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=426264#426264
Checked by AVG - www.avg.com
Posted: Mon Jul 07, 2014 6:59 pm Post subject: Access to tire vale stems |
You can drill a 2" hole centered 2-2.5" aft and 1/2" above the axle screw. Cirrus sells a 2" plug that will fit the hole. You have to leave the valve cover off, but you can easily add air.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Jul 7, 2014, at 10:40 PM, "kearney" <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
rleffler
Posted: Mon Jul 07, 2014 7:09 pm Post subject: Access to tire vale stems |
I drilled 3/4" holes then used a metal cover like Cleaveland sells. You can buy the same thing at the local hardware store for about a quarter per wheel. I also painted a mark on the tire when the valve stem is aligned with the hole. The system works well, except its a PITA if you are by yourself. It's impossible to see the marks on the tires while holding the tow bar.
Hi
Cheers
Les
_________________ Bob Leffler
N410BL - Phase I
Bob Turner
Posted: Mon Jul 07, 2014 7:39 pm Post subject: Re: Access to tire vale stems |
Yes, it's a bit of a pain to take off the pants. But, unless your tubes leak badly, you really ought to be looking at brakes, wheels, etc., about as often as your tubes need air.
_________________ Bob Turner
RV-10 QB |
Tim Olson
Posted: Mon Jul 07, 2014 10:09 pm Post subject: Access to tire vale stems |
That's been my standard reply to this for years too. I personally
don't need the added temptation to SKIP taking the fairings off,
because I know I'd succumb. I generally only have to take them
off in spring and fall,with the leak guard tubes, and I think brake
pads deserve inspection more often than that.
| Quote: | On Jul 7, 2014, at 9:39 PM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=426269#426269
charliewaffles
kearney
Posted: Tue Jul 08, 2014 7:42 pm Post subject: Re: Access to tire vale stems |
Linn et al
Thanks for the suggestions. I have the caps for the pants already. I didn't know that 90 degree extensions were available so I will definitely go that route.
I do take Tim's point about not skipping the brake inspections though.
Cheers
Les
Lenny Iszak
Posted: Wed Jul 09, 2014 4:31 am Post subject: Re: Access to tire vale stems |
Les,
The extensions are straight, valve stems are 90 degrees, so they point straight out instead of towards the axle nut.
Lenny
johngoodman
Posted: Thu Jul 10, 2014 3:50 am Post subject: Re: Access to tire vale stems |
Try going pantless, like me....
32.57 KB |
9202 Time(s) |
