rmhou(at)yahoo.com Guest
Posted: Fri Jul 25, 2014 10:18 am Post subject: Brass Insert F63-PT3-25 |
Hi List,
The brass inserts that come with my kit seem small. It went into my tube and won't stay in the brass elbow for the b-nut to secure it in place.
Advise?
Robin
2.49 MB |
20068 Time(s) |
Posted: Fri Jul 25, 2014 11:04 am Post subject: Brass Insert F63-PT3-25 |
Well, hard to tell from the picture ..... but the ferrule should fit a little snug in the tube .... if it falls out of the tube when you hold the tube upside down .... either the ferrule is too small or the tube too large. The sleeve should just fit over the tube. Ace has the ferrule .... and more tube .... in the aircraft isle, of course!!!
Linn
On 7/25/2014 2:12 PM, Robin Hou wrote:
[quote] Hi List,
Advise?
Robin
Checked by AVG - www.avg.com
07/25/14 [b]
Posted: Fri Jul 25, 2014 12:13 pm Post subject: Brass Insert F63-PT3-25 |
That is the wrong tube. Look for the ¼” tubing.
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Hou
Sent: Friday, July 25, 2014 2:13 PM
To: Rv-list
Subject: Brass Insert F63-PT3-25
Hi List,
Advise?
Robin
Hopperdhh(at)aol.com Guest
Posted: Mon Jul 28, 2014 6:25 am Post subject: Brass Insert F63-PT3-25 |
Hi Robin,
If you get the tubing from Vans, it will be .060" wall thickness and the inserts will fit it. The tubing you get locally is usually thinner wall.
Dan Hopper
RV7A N766DH
In a message dated 7/25/2014 4:13:55 P.M. Eastern Daylight Time, carl.froehlich(at)verizon.net writes:
That is the wrong tube. Look for the ¼� tubing.
Carl
To: Rv-list
Hi List,
Advise?
Robin
rolif6 Guest
Posted: Fri Aug 09, 2024 8:59 am Post subject: Re: Brass Insert F63-PT3-25 |
Brass inserts are versatile components commonly used in various applications to provide reinforcement, improve durability, and facilitate easy assembly. These small yet robust pieces are typically embedded into materials like wood or plastic, offering a secure anchoring point for screws or bolts. Their resistance to corrosion and wear makes them ideal for both functional and aesthetic purposes. In a different but related context, brass knuckles exemplify another application of brass, where the metal is used for its strength and impact resistance. While brass inserts enhance the integrity of numerous products, brass knuckles highlight the material's durability in more specialized uses. Understanding the diverse applications of brass can help in selecting the right type for your specific needs, ensuring both functionality and longevity.
