Wiring a 2 dash 7 Two pole Switch for my flaps
AZFlyer
PostPosted: Mon Jul 28, 2014 8:35 am    Post subject: Wiring a 2 dash 7 Two pole Switch for my flaps Reply with quote
I've read your explanation on wiring various switches several times now and am still not certain what I should be using in my plane.
I recently flew a few hours in a Remos G3. The flap switch installed as standard used a "bump down, or hold down" to deploy the flaps and a single "bump up" to retract fully.
(Spring loaded both directions.) The flap switch in my Zenith 601XL requires bumping both directions (or holding) to extend or retract. I would like to duplicate the Remos switch.
My flap motor has limit switches in both directions if that makes any difference.
Do I need a different two pole switch or need to wire my 2-7 differently?
Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"!
