frank goodnight
Posted: Fri Aug 01, 2014 5:49 pm Post subject: Mk3 flap speed |
Hi all,
Can someone tell me the max airspeed at wich i can lower full flaps and the max speed
I can go with 1/2 flaps in a MK 3 Clasic .
Thanks Frank Goodnight
Posted: Fri Aug 01, 2014 6:17 pm Post subject: Mk3 flap speed |
max speed I can go with 1/2 flaps in a MK 3 Clasic .
Frank G/Kolbers:
Never seen anything published on flap extension speed.
I usually use 60 to 70 mph for 20 and 40 degrees of flaps.
Have experimented up to 80 mph max flaps, 40 degrees.
Was demonstrating my MKIII at Lakeland some years ago. Had never done this
maneuver before. Had an aviation reporter on board, a friend. Pulled in
full flaps, pulled power back to idle, pushed the nose over straight down.
At 80 to 90 mph I pulled the stick back abruptly. The MKIII continued in
its vertical dive until I retracted the flaps, then pulled the stick back.
Reckon those big flaps took the air off the tail section rendering my
elevators useless in that situation.
Other than the above, never had a problem with elevators and flaps.
_________________ John Hauck
Titus, Alabama |
colin.scott.hudson(at)gma Guest
Posted: Fri Aug 01, 2014 7:32 pm Post subject: Mk3 flap speed |
Frank my research shows VFE for the classic to be 100 km, 52 knts or 62 MPH. Anything above that can cause structure damage.
Scott Hudson
| Quote: | On Aug 1, 2014, at 8:49 PM, Frank Goodnight <frank.goodnight(at)att.net> wrote:
Hi all,
rickofudall
Posted: Sat Aug 02, 2014 3:22 am Post subject: Mk3 flap speed |
Frank, Watch my video on transitioning to the Kolb Mk III for GA pilots here:
https://www.youtube.com/watch?v=mQ-YaW9WgEU
Here's a view from outside the cockpit:
https://www.youtube.com/watch?v=sGMvpQRHS-0
As for your question about flap deployment speed, I use 60 mph then settle on 50 for approach. Hope this helps.
Rick Girard
On Fri, Aug 1, 2014 at 10:31 PM, Colin Hudson <colin.scott.hudson(at)gmail.com (colin.scott.hudson(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: Colin Hudson <colin.scott.hudson(at)gmail.com (colin.scott.hudson(at)gmail.com)>
Scott Hudson
> On Aug 1, 2014, at 8:49 PM, Frank Goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
> --> Kolb-List message posted by: Frank Goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)>
> Hi all,
| Quote: | Can someone tell me the max airspeed at wich i can lower full flaps and the max speed
| Quote: | Sent from my iPad
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
frank goodnight
Posted: Sat Aug 02, 2014 5:18 am Post subject: Mk3 flap speed |
Thanks to all that answered
the flap question.
Frank Goodnight ( new to mk3 )
On Aug 1, 2014, at 10:31 PM, Colin Hudson <colin.scott.hudson(at)gmail.com> wrote:
Scott Hudson
> Hi all,
> Sent from my iPad
