rnbraud
Posted: Tue Aug 05, 2014 11:23 am Post subject: Half wave copper foil dipole transponder antenna |
I hope this isn't a duplicate, but I was unable to find sufficient info on this topic in the archives.
I have successfully built and tested several copper foil/tape comm antennas for my Cozy MkIV and would like to build a transponder antenna the same way.
Will the following work for a Mode S transponder:
1. Vertically oriented 1/2 wave dipole.
2. 1/2" copper tape with ferrites
3. Each leg 6.25" long
Thanks.
kjashton(at)vnet.net Guest
Posted: Tue Aug 05, 2014 12:46 pm Post subject: Half wave copper foil dipole transponder antenna |
See. http://www.cozybuilders.org/ref_info/RST_82704.pdf
The transponder is a little different than the other antennae. The reference discusses it. Keep the coax run short and put it on the bottom of the airplane. Mine is under removable front seats. You can make the antenna from an AN bolt but they are very cheap on ebay.
-kent
Thanks.
http://forums.matronics.com/viewtopic.php?p=428048#428048
rnbraud
Posted: Tue Aug 05, 2014 12:56 pm Post subject: Re: Half wave copper foil dipole transponder antenna |
Hello Kent,
I am trying to avoid the antenna sticking out of the airplane. I see where Advanced Aircraft Electronics makes an "L2" transponder antenna which looks a lot like my other foil tape antennas.
I was hoping maybe I could make my own "L2" type of antenna with my leftover RST antenna kit.
Just want to confirm if it is feasible and if the leg lengths and vertical orientation is correct.
If this does not work, I will make my transponder antenna as you mentioned and place it either out at the end of the strake or right under the pilot seat protruding out of the fuselage.
Thanks.
kjashton(at)vnet.net wrote: | See. http://www.cozybuilders.org/ref_info/RST_82704.pdf
-kent
Posted: Tue Aug 05, 2014 1:41 pm Post subject: Half wave copper foil dipole transponder antenna |
As I understand it, a ground plane made of copper foils will work as well as the solid ground plane. And vertical orientation sounds right. As for where to put it, just consider that folks who try to put them in the nose of a canard airplane or up front on the airplane often run into problems climbing out away from the radar station because the bodies of the crew (bags of salt-water) and the engine blank off line-of sight with the radar.
Quick: When you are 30 miles from a station at 5000', the angle to the station from the horizon is ___.
ANS: 1.57 degrees. I doesn't take much nose up deck angle to hide the antenna. Ask me how I know.
-Kent
On Aug 5, 2014, at 4:56 PM, rnbraud wrote:
Quote: |
Hello Kent,
Thanks.
> -kent
http://forums.matronics.com/viewtopic.php?p=428053#428053
