FLYaDIVE(at)aol.com Guest
Posted: Fri Jun 23, 2006 8:50 pm Post subject: CB Size requirements? |
Hello Group:
I have searched the web without any luck ... I'm looking for the CB requirements for a King KX 125, would anyone have info on this?
Thank you for your assistance,
Barry
khorton01(at)rogers.com Guest
Posted: Sat Jun 24, 2006 1:34 am Post subject: CB Size requirements? |
On 24 Jun 2006, at 24:43, FLYaDIVE(at)aol.com wrote:
| Quote: | Hello Group:
The purpose of the CB is to protect the wire from overheating if
there is a short. The purpose is not to protect the radio. The only
thing the wiring can do that can hurt the radio is provide high
voltage if the alternator's voltage regulator fails. You need an
overvoltage protection system to prevent this. A CB cannot stop high
voltage, as a CB is triggered based on excessive current, not
excessive voltage.
The size of CB depends you need depends on the size of the wire.
What size wire provides power to the radio?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
wjoke(at)shaw.ca Guest
Posted: Sat Jun 24, 2006 8:37 am Post subject: CB Size requirements? |
Kevin has described the rationale for the "maximum size" circuit breaker
in a circuit powering a radio (or other electrical device) which is to
protect the power feed wire in the event of a short. There is also a
"minimum size" CB required to pass enough electrical power to the device
(avionics engineers that I know like the term "appliance"). Since
voltage is generally fixed at close to 12 -14 volts, this really means
getting enough current to power the device. Typically a VHF radio will
use something like 200-400 milliamps on receive (depending on the audio
volume and squelch settings) and 3-5 amps on transmit. Too small a CB
means a nuisance trip of the CB every time you attempt to transmit -
nothing is wrong just the CB is too small to pass enough power to the
radio when it is transmitting. Typically a 50% extra capacity is added
to deal with power surges as the transmit cycle begins so if 5 amps
needed - use 7.5 amps, etc.
The manufacturers are reluctant to widely advertise the installation
details of their equipment perhaps to encourage buyers to hire the
dealers who sell the stuff to do the installation as well thus sending a
bit of business their way. So that's why the power supply specs are less
than readily available. The KX-125 specs seem to suggest a 5 watt
transmitter (RF) power output. Most radios in this range will do fine
with a 10 amp CB so, failing anything else, try that size of CB. This
means sizing the wiring so that it is big enough to pass that amount of
current continuously without harm in the event of a short. A bit of
oversize on the wiring does no harm and helps reduce voltage drop at the
radio which is a separate issue but related issue when powering a
device. No harm is done if the wiring will take more current than the CB
will pass as the wire is quite adequately protected by the CB.
Jim Oke
Wpg., MB
RV-6A C-GKGZ
Kevin Horton wrote:
<khorton01(at)rogers.com>
> Hello Group:
excessive voltage.
Ottawa, Canada
http://wiki.matronics.com
Posted: Sat Jun 24, 2006 12:08 pm Post subject: CB Size requirements? |
In a message dated 6/24/06 12:42:13 PM Eastern Daylight Time, wjoke(at)shaw.ca
writes:
| Quote: | Typically a 50% extra capacity is added
Jim Oke
Wpg., MB
RV-6A C-GKGZ
Jim:
Thank you for a very realistic answer. I should have phrased my question
better ... "What is the current draw of a King KX 125?"
I found that the current draw on a Garmin GNC 250 XL is rated at 5.5 Amps
during transmit. Of course that also has a moving map and its additional current
draw. If I subtract 0.5 Amps for the GPS and moving map that leaves me with
5.0 Amps. Taking that with a 50% safety margin that puts me right at 7.5 Amps
.. Good size for a CB.
GOOD SUGGESTION Jim.
I wired the feed to the Radio Buss with 12 AWG and the Buss itself with 14
AWG so I have ample capacity.
Now here is a follow up question. I don't have much experience with radar,
but the Xponder only requires a 5 AMP CB; yet the power output of the unit is
250 Watts. How come such a low CB?
I'm taking a WAG here, does it have to do with the Duty Cycle of the
transmission?
Thanks again Jim,
Barry
"Chop'd Liver"
jcorner(at)shaw.ca Guest
Posted: Sat Jun 24, 2006 3:19 pm Post subject: CB Size requirements? |
I too will soon be installing a KX 125 and was able to purchase an
installation manual
from AC Spruce.
The manual recommends a 10 amp fuse as deduced below, and shows a max
transmit
power consumption of 6 amps.
It also recommends power wiring to be 2 #18 AWG wires to the circuit
breaker
and also 2 #18 wires to ground. What would be the advantage of this
over the 12 and 14 AWG
being installed by Barry? More resistance to breakage or is there
another reason?
Jim Corner
Kitfox 5 under construction.
Kitfox 2 flying
On Jun 24, 2006, at 2:04 PM, FLYaDIVE(at)aol.com wrote:
wjoke(at)shaw.ca
writes:
> sending a
> are less
> fine
> This
> amount of
> at the
> the CB
> Jim Oke
> Wpg., MB
> RV-6A C-GKGZ
Jim:
question
5.5 Amps
additional current
leaves me with
at 7.5 Amps
... Good size for a CB.
with 14
with radar,
the unit is
transmission?
Thanks again Jim,
Barry
"Chop'd Liver"
Posted: Sun Jun 25, 2006 3:52 am Post subject: CB Size requirements? |
In a message dated 6/24/06 7:21:48 PM Eastern Daylight Time, jcorner(at)shaw.ca
writes:
| Quote: | I too will soon be installing a KX 125 and was able to purchase an
installation manual from AC Spruce.
transmit power consumption of 6 amps.
breaker and also 2 #18 wires to ground. What would be the advantage of
this
| Quote: | over the 12 and 14 AWG being installed by Barry? More resistance to
breakage or is there another reason?
Jim Corner
JIm:
Thanks for the post.
This install manual, is it by King or ACS? I would have to really question
that manual. I do not see ANY advantage of using two 18 AWG wires running in
parallel. Maybe it was done for ease of routing and soldering to connectors?
Yes, there is the current carrying capacity but there is also the extra work,
extra weight, extra points to fail ... Now when talking failure points, what
are the possibilities of wire harness failure? Pretty low even on GA aircraft.
Maybe the double runs are for future use? I tend to do double runs for
further expansion. I also will go up one size for expansion or where a voltage
drop might be a problem; such as in alternator and ACU systems.
18 AWG = 10 Amps
16 AWG = 15 Amps
14 AWG = 20 Amps
12 AWG = 30 Amps
This circuit/PROBLEM I'm working on was built by someone else. They used
POP-RIVITS to attach wires to CB'ers. They also tied ALL radios [Xponder, 2 Coms
and Audio Panel] to one 10 AMP CB-Switch. I'm just breaking each item out
with their own wiring and CB.
Barry
"Chop'd Liver"
klehman(at)albedo.net Guest
Posted: Sun Jun 25, 2006 6:03 am Post subject: CB Size requirements? |
My icomm also has two pins for power (and two for ground) and calls for
those two #18 wires. I assume it is for two reasons. An attempt to
provide some tolerance for bad pins or dirty connections with a separate
wire for each pin... Not more failure points but rather a bit of
redundancy since either wire will carry the load. The first thing that
an avionics tech seems to do is to remove and then reseat the unit to
see if anything changes. So why aren't all pins doubled - my guess is
that the dual power wires help distribute the current between the pins
also for an increase in reliability. With one wire to two pins, the
current would tend to mostly go through the pin with the lowest resistance.
Ken
writes:
this
> Jim Corner
JIm:
18 AWG = 10 Amps
16 AWG = 15 Amps
14 AWG = 20 Amps
12 AWG = 30 Amps
Barry
"Chop'd Liver"
Posted: Sun Jun 25, 2006 7:23 am Post subject: CB Size requirements? |
The manual is by Allied Signal Bendix/King
The drawing shows 13.75 volts to pin 1 and pin A which are tied
together.
Also ground pins 4,5,19 and Z are tied together.
Jim
On Jun 25, 2006, at 5:44 AM, FLYaDIVE(at)aol.com wrote:
jcorner(at)shaw.ca
writes:
> max
> advantage of
this
> Jim Corner
JIm:
question
running in
connectors?
extra work,
points, what
GA aircraft.
runs for
where a voltage
18 AWG = 10 Amps
16 AWG = 15 Amps
14 AWG = 20 Amps
12 AWG = 30 Amps
They used
[Xponder, 2 Coms
item out
Barry
"Chop'd Liver"
Posted: Sun Jun 25, 2006 7:38 am Post subject: CB Size requirements? |
In a message dated 6/25/06 10:07:48 AM Eastern Daylight Time,
klehman(at)albedo.net writes:
| Quote: | My icomm also has two pins for power (and two for ground) and calls for
One of the questions that has to be addressed is: What kind of connector does
the radio have? Many of the OLD NARCO style radios used edge-card
connectors. The pin size was quite large compared to the size of the pins on the DB-9,
DB-25, DB-26 or larger computer type connectors of today. So, it does make
better sense to run two wires to two pins sets.
Barry
"Chop'd Liver"
Posted: Sun Jun 25, 2006 1:55 pm Post subject: CB Size requirements? |
I cannot say for sure for a KX125, but some members of the King
equipment line use an edge connector which slides onto a main circuit
board. I have been told the thin copper foil on a typical circuit board
is marginal to take the full supply current at a single point of contact
and so provision is made to transfer the power through two pins of the
edge connector. This is to enhance reliability over the long term by
avoiding "burning" the PC land.
The circuit diagrams will show two pins "bridged" together for this
purpose. Same thing applies for the ground as the same amount of current
has to "return" though the ground eventually. Whether a single large
conductor (connected to two pins) or a pair of small wires (each going
to one pin) is used is as much a matter of manufacturing and
installation convenience as anything else.
Jim Oke
Wpg., MB
RV-6A C-GKGZ
Jim Corner wrote:
installation manual
from AC Spruce.
transmit
breaker
another reason?
Jim Corner
Kitfox 2 flying
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Sun Jun 25, 2006 5:29 pm Post subject: Re: CB Size requirements? |
| FLYaDIVE(at)aol.com wrote: | Now here is a follow up question. I don't have much experience with radar, but the Xponder only requires a 5 AMP CB; yet the power output of the unit is 250 Watts. How come such a low CB?
I'm taking a WAG here, does it have to do with the Duty Cycle of the transmission? |
Yes, the duty cycle of the 21 microsecond pulse train, which depends upon the number of on bits sent. And then figure the number of pulse trains in our reply, a function of distance and parameters of ATC's ATCRBS interrogator, like sweep speed, interrogation rate, and antenna design. Finally, the average number of interrogations we reply to, so the number of ATC sites within range, and volume of TCAS planes lately talking to us. I reckon a mere 100mA worst case might come out of all the math. Can't be much, as the capacitor which stores the typical 1500V so we can put out peak power of 250W+ when an on bit is sent isn't very big. The do have a warning sticker saying don't touch the wire part of that puppy so you don't have a Homer Simpson moment.
Fred F.
