		nickc(at)mtaonline.net Guest
				 Posted: Sat Aug 16, 2014 7:38 am    Post subject: ELSA...? |
				Hello All,
 In my case I bought a kit to recreate a prototype aircraft that no longer exists. It will not be an exact copy of the prototype plane that no longer exists, and the design was and will remain significantly deferent from the production model. Do you think I will be able to get an ELSA?
 Nick Cassara
 Palmer,  Alaska
		byoungplumbing(at)gmail.c Guest
				 Posted: Sat Aug 16, 2014 9:29 am    Post subject: ELSA...? |
				If the kit was an approved as an esla kit you should be ok.   Even if the prototype no longer exist.  The inspector will only be able to compare your finished project to the esla approved plans.   If you don't have esla plans.  Imho in my humble opinion,,   your only option is eab.    And if you have esla plans and have made any modifications while building your plane does not fit esla rules.   You would be left with eab
 Boyd young On Aug 16, 2014 9:40 AM, "Nick Cassara" <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:[quote]
 Hello All,
 Nick Cassara
 Palmer,  Alaska
 tp://forums.matronics.com
		rickofudall
				 Posted: Sun Aug 17, 2014 1:43 pm    Post subject: ELSA...? |
				Nick, Here are the applicable FAR's on Light Sport Aircraft. For your
 Kolbra, Kolb would have to build a qualifying aircraft per the ASTM
 standard, document that it meets the standard, and get the FAA to certify
 their production and supply system. The manufacturer would then sell you a
 kit EXACTLY like their prototype.  If you were to make ANY changes to the
 kit, the manufacturer would have to issue a letter of authorization (LOA)
 for EACH change. Part of the kit package would be a certificate of
 conformity that would be presented to the FAA or the DAR, along with any
 LOA's at the time your aircraft is presented for inspection for the
 experimental certificate, mistakenly called the airworthiness certificate
 by most people.
 So, the simple answer is that for you to get an ELSA designation, Kolb
 would have to have built an SLSA prototype of the Kolbra.
 Rick Girard
 21.190   Issue of a special airworthiness certificate for a light-sport
 category aircraft.
 (a) Purpose. The FAA issues a special airworthiness certificate in the
 light-sport category to operate a light-sport aircraft, other than a
 gyroplane.
 (b) Eligibility. To be eligible for a special airworthiness certificate in
 the light-sport category:
 (1) An applicant must provide the FAA with—
 (i) The aircraft's operating instructions;
 (ii) The aircraft's maintenance and inspection procedures;
 (iii) The manufacturer's statement of compliance as described in paragraph
 (c) of this section; and
 (iv) The aircraft's flight training supplement.
 (2) The aircraft must not have been previously issued a standard, primary,
 restricted, limited, or provisional airworthiness certificate, or an
 equivalent airworthiness certificate issued by a foreign civil aviation
 authority.
 (3) The aircraft must be inspected by the FAA and found to be in a
 condition for safe operation.
 (c) Manufacturer's statement of compliance for light-sport category
 aircraft. The manufacturer's statement of compliance required in paragraph
 (b)(1)(iii) of this section must—
 (1) Identify the aircraft by make and model, serial number, class, date of
 manufacture, and consensus standard used;
 (2) State that the aircraft meets the provisions of the identified
 consensus standard;
 (3) State that the aircraft conforms to the manufacturer's design data,
 using the manufacturer's quality assurance system that meets the identified
 consensus standard;
 (4) State that the manufacturer will make available to any interested
 person the following documents that meet the identified consensus standard:
 (i) The aircraft's operating instructions.
 (ii) The aircraft's maintenance and inspection procedures.
 (iii) The aircraft's flight training supplement.
 (5) State that the manufacturer will monitor and correct safety-of-flight
 issues through the issuance of safety directives and a continued
 airworthiness system that meets the identified consensus standard;
 (6) State that at the request of the FAA, the manufacturer will provide
 unrestricted access to its facilities; and
 (7) State that the manufacturer, in accordance with a production acceptance
 test procedure that meets an applicable consensus standard has—
 (i) Ground and flight tested the aircraft;
 (ii) Found the aircraft performance acceptable; and
 (iii) Determined that the aircraft is in a condition for safe operation.
 (d) Light-sport aircraft manufactured outside the United States. For
 aircraft manufactured outside of the United States to be eligible for a
 special airworthiness certificate in the light-sport category, an applicant
 must meet the requirements of paragraph (b) of this section and provide to
 the FAA evidence that—
 (1) The aircraft was manufactured in a country with which the United States
 has a Bilateral Airworthiness Agreement concerning airplanes or Bilateral
 Aviation Safety Agreement with associated Implementation Procedures for
 Airworthiness concerning airplanes, or an equivalent airworthiness
 agreement; and
 (2) The aircraft is eligible for an airworthiness certificate, flight
 authorization, or other similar certification in its country of manufacture
