Gear shock absorber YAK 50
gord(at)thedampub.ca
PostPosted: Tue Aug 19, 2014 4:59 am    Post subject: Gear shock absorber YAK 50 Reply with quote
Dennis.. or anyone. Is there a quick & easy supply for the retainer clip that holds the seal in place on the gear strut? One of mine must have snapped because it is gone and the seal needs to be pushed up after every flight. SN 01 is running great! Thanks, Gord
 Filesize:  26.93 KB
 Viewed:  3090 Time(s)
dsavarese0812(at)bellsout
PostPosted: Tue Aug 19, 2014 5:11 am    Post subject: Gear shock absorber YAK 50 Reply with quote
Gord,
Did you try Jill at M14P? In case she does not check the Yak list, I will forward your email to her directly.
BR
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
PostPosted: Tue Aug 19, 2014 5:25 am    Post subject: Gear shock absorber YAK 50 Reply with quote
I can do that no problem . I just thought that maybe it was an item that may be available somehow locally. Takes a while to get here from Jill.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: August-19-14 9:10 AM
To: yak-list(at)matronics.com
Subject: Re: Gear shock absorber YAK 50
Gord,
BR
Dennis
A. Dennis Savarese334-285-6263334-546-8182 (mobile)www.yak-52.comSkype - Yakguy1
5
6
7
8
9
PostPosted: Tue Aug 19, 2014 5:31 am    Post subject: Gear shock absorber YAK 50 Reply with quote
It is definitely a unique part.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 8/19/2014 8:23 AM, gord wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of A. Dennis Savarese
Gord,
BR
Dennis
A. Dennis Savarese
A. Dennis Savarese
A. Dennis Savarese
A. Dennis Savarese
A. Dennis Savarese
A. Dennis Savarese
5
A. Dennis Savarese
6
A. Dennis Savarese
7
A. Dennis Savarese
8 [b]
