rowedenny
Posted: Tue Aug 19, 2014 2:57 pm Post subject: Radio intercom |
Dave Lewis and myself are having a rough time coming up with a radio intercom set up that works in our Kolbs. His Slingshot is 582 powered and my Mk3 is 670 powered. We both have Icom A4s and I also have an older A21. He uses single place patch cords with PTT, and I have a Rugged Radio intercom. I am very happy with the intercom, but our radio transmissions suck.
What do you guys use that you are happy with?
Also was wondering if anyone has tried the MGL Stratomaster mini radios with a two stroke bird? It seems they work great in the Sonex factory birds.
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
rickofudall
Posted: Tue Aug 19, 2014 3:21 pm Post subject: Radio intercom |
Dennis, What are the sucking symptoms? What are you running for an antenna?
Rick Girard
On Tue, Aug 19, 2014 at 5:56 PM, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
| Quote: | --> Kolb-List message posted by: Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
lcottrell
Posted: Tue Aug 19, 2014 7:09 pm Post subject: Radio intercom |
On Tue, Aug 19, 2014 at 4:56 PM, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
I am using the Sigtronics Transcom II Its an intercom for two stroke engines. It has a side band on it so that you voice comes through in your headphones as well. That keeps you from shouting because it is weird to not hear your own voice. I also has a jack for a recorder and a music jack which works ?pretty good? Although I could not hear music when I was running a 503. It does well with an HKS however. I find that music and coffee are a plus when you are flying. | LarryÂ
| Quote: | Â
lcottrell
Posted: Tue Aug 19, 2014 7:16 pm Post subject: Radio intercom |
I guess I should have read a bit more before I let my fingers do any walking. The best guess is that your antenna is not right or your ground plane is either non existent, or there is electrical interference. Back in my cage,
Larry
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
Richard Pike
Posted: Tue Aug 19, 2014 8:12 pm Post subject: Re: Radio intercom |
Last winter we did a number of tests between two Kolbs, the FSII N582EF and the MKIII N420P and discovered some interesting things. One of the things we did was to use a handheld radio and while the engine was running, and using the handheld radio, move around the airplanes and try and discover where the engine created the most noise and the worse reception, and the least noise and the best reception.
We discovered that the best place for minimum noise and best reception was at the top of the vertical fin.
Based on that, we relocated the antennas for each airplane to the top of the vertical fin.
Here are the pictures of the installations for both the MKIII and the FSII.
The antenna is made by taking a Radio Shack twist-on male BNC connector, part # 278-103 and a length of 1/16" model airplane pushrod steel wire, and combining them like this: take one end of the steel wire, and taper it on a grinder until it will fit into the connector until the end just pokes through the end of the middle terminal connector. Solder it to the connector at that end. Fill the shank up with epoxy, and after it hardens, cut it to about 25 inches total length, and trim it to final length while checking an SWR meter. If you don't have an SWR meter, make it 24 1/4" long total length, base to tip, it will work. Put a little curl on the end, or Murphy's Law says someone will poke it through their eye. Cost? $8. Weight? 2 ounces.
Another factor was the headset. I had been using a Softcom headset for a number of years, but unbeknownst to me, it had gone bad. Got a new Gulf Coast Avionics El Cheapo ANR headset and it helped immensely. Also got an older Lightspeed ANR headset, and it also improved things immensely. Both are very good and quite comfortable, and the price in both cases was very reasonable on ebay. I can call TRI ATC for a comm check and get "5X5, with some background noise." Since both airplanes have a Rotax 582 churning away in the background, that sounds reasonable, and a pretty good deal. Before getting the new headsets, TRI ATC said I was unreadable.
Hope this is helpful.
67.84 KB |
20038 Time(s) |
85.93 KB |
20038 Time(s) |
85.93 KB |
20038 Time(s) |
136.34 KB |
20038 Time(s) |
89.88 KB |
20038 Time(s) |
91.84 KB |
20038 Time(s) |
142.01 KB |
20038 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rowedenny
Posted: Wed Aug 20, 2014 3:27 am Post subject: Radio intercom |
We both use the older, (affordable) LightSpeed QFR headsets, they are sweet and I believe many here use them with good results. We gave factory 45 degree antennas under our nose cones with aluminum sheet metal disks on the inside of the cones for reinforcement. I believe the disks are grounded to the airframe. My tach and kill switch leads are separately shielded.
No capacitors on the buss.
We get garbled reception, a lot of background noise. Part of my issue may be in my patch cords to the intercom.
Dennis "Skid" RoweMk3, Rotax 670,
Leechburg, PA
[quote]Dennis, What are the sucking symptoms? What are you running for an antenna?
Rick Girard
| Quote: | Dave Lewis and myself are having a rough time coming up with a radio intercom set up that works in our Kolbs. His Slingshot is 582 powered and my Mk3 is 670 powered. We both have Icom A4s and I also have an older A21. He uses single place patch cords with PTT, and I have a Rugged Radio intercom. I am very happy with the intercom, but our radio transmissions suck.
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg,
rowedenny
Posted: Wed Aug 20, 2014 3:29 am Post subject: Radio intercom |
I'll check to see if my aluminum plate is grounded to the airframe
Leechburg, PA
On Aug 19, 2014, at 11:16 PM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
[quote]I guess I should have read a bit more before I let my fingers do any walking. The best guess is that your antenna is not right or your ground plane is either non existent, or there is electrical interference. Back in my cage,
Larry
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
rowedenny
Posted: Wed Aug 20, 2014 3:30 am Post subject: Radio intercom |
Pics please, and capacitor specs if possible?
Leechburg, PA
On Aug 20, 2014, at 12:41 AM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
[quote]My antenna is made the same way as the one that Richard was talking about, but mine is mounted under the nose pod and the base is grounded to the floor pan for a "ground plane". My plane had a commercial aircraft antenna mounted just ahead of it in the nose cone without a ground plane and would not transmit more than 8 miles. Mounted and grounded to the floor pan my homemade transmits 29 miles with an icom A4 radio. It was a bit scratchy, so I installed a large capacitor (per John Hauck) and it now transmits loud and clear. The only noise that I hear in it is the quiet click of the strobes. Larry
On Tue, Aug 19, 2014 at 10:12 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
| Quote: | --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
Kingsport, TN 3TN0
My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9
http://forums.matronics.com/viewtopic.php?p=428825#428825
http://forums.matronics.com//files/p1030798_medium_120.jpg
http://forums.matronics.com//files/p1030797_medium_503.jpg
http://forums.matronics.com//files/p1030797_medium_782.jpg
http://forums.matronics.com//files/p1030796_medium_476.jpg
http://forums.matronics.com//files/p1030794_medium_765.jpg
http://forums.matronics.com//files/p1030793_medium_229.jpg
http://forums.matronics.com//files/p1030792_medium_175.jpg
List"">http://www.matronics.com/Navigator?Kolb-List
Posted: Wed Aug 20, 2014 5:06 am Post subject: Radio intercom |
Dennis/Kolbers,
Use a 25v 22000 mf capacitor, more or less.
Install at or near the reg/rec on the positive wire with neg contact grounded to airframe.
The capacitor soaks up noise.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Dennis Rowe
Sent: Wednesday, August 20, 2014 6:30 AM
Subject: Re: Re: Radio intercom
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
[quote] [b]
_________________ John Hauck
Titus, Alabama |
rowedenny
Posted: Wed Aug 20, 2014 5:48 am Post subject: Radio intercom |
Will give it a try,
Leechburg, PA
On Aug 20, 2014, at 9:05 AM, "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] 1024x768 <![endif]--> Clean false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
Dennis/Kolbers,
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Dennis Rowe
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
t41pilot
Joined: 05 Sep 2011 Posts: 38 Location: Howard City, Michigan
Posted: Wed Aug 20, 2014 5:49 am Post subject: Re: Radio intercom |
Here's a link to an MGL document that looks like it would apply to most installs that addresses radio/antenna/intercom issues. Since I don't trailer my Airplane and keep it hangared, I opted for a different install that works well for me. It is homemade as well and is dirt cheap to make. Made in a similar fashion as previously described and uses a 23.5 inch steel wire. The BNC inside the boom tube is a right angle variety and is kept as close to the top of the tube as possible to keep the antenna wire out of my control cables. I have been told I'm noise free on my transmissions and I occasionally receive transmissions from 150 miles away. I don't hear any engine noise in the radio. I use a vertex handheld on a ram mount. I use a radioshack 2,200uf 35volt capacitor mounted right across my regulator terminals. Bigger is better if you want to install it differently. 25 volt or greater is the important part.
http://www.mglavionics.co.za/Docs/AIRCRAFT%20RADIO%20INSTALLATION%20-%20rev1-1.pdf
176.27 KB |
20008 Time(s) |
_________________ Gregg Kaat
2011 Firefly |
frank goodnight
Posted: Wed Aug 20, 2014 12:33 pm Post subject: Radio intercom |
John & 141 one says to use a 22000
Mf capacitor the other says a 2200.
? Is there a typo? My radio shack
Only has up to 10000 mf. I bought a
2200 dc ,has no positive or neg
Terminal marking. Only 3 bucks.
I'll try it If i don't hear from you guys.
Frank G
MK 3 classic
Rotax uls--- lots of radio noise, good radio , garmin sl40
On Aug 20, 2014, at 8:05 AM, "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
Dennis/Kolbers,
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
cs.com
frank goodnight
Posted: Wed Aug 20, 2014 12:46 pm Post subject: Radio intercom |
Is your capacitor mounted before the
Reg or after?
Thanks Frank
Dennis/Kolbers,
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
cs.com
rlaird
Posted: Wed Aug 20, 2014 12:48 pm Post subject: Radio intercom |
mouser.com  has the capacitors you'll need....
On Wed, Aug 20, 2014 at 3:32 PM, Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
[quote]John & 141 one says to use a 22000
? Is there a typo? My radio shackÂ
Only has up to 10000 mf. I bought aÂ
Frank G
MK 3 classic
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
rlaird
Posted: Wed Aug 20, 2014 12:50 pm Post subject: Radio intercom |
[img]cid:ii_147f52ef79a54793[/img]
On Wed, Aug 20, 2014 at 3:48 PM, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote:
| Quote: | mouser.com  has the capacitors you'll need....
| Quote: | John & 141 one says to use a 22000
Frank G
MK 3 classic
63.78 KB |
19996 Time(s) |
Robert Laird
Houston, TX area
frank goodnight
Posted: Wed Aug 20, 2014 12:55 pm Post subject: Radio intercom |
Thanks Robert
Looks like it's 20000 +
Frank
On Aug 20, 2014, at 3:50 PM, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote:
<image.png>
Frank G
MK 3 classic
Posted: Wed Aug 20, 2014 12:57 pm Post subject: Radio intercom |
On the 12VDC side of the reg/rec.
I discovered capacitors way back in my FS days. I wanted 12VDC power for the 447 without a battery. JC Whitney had a dirt bike battery eliminator kit that included a small capacitor. After flying with it for a while I decided that capacitor was extra cargo and removed it. Handheld radio was unusable. Replaced the capacitor and all was fine again.
---- Frank <frank.goodnight(at)att.net> wrote:
| Quote: | John
Reg or after?
Thanks Frank
On Aug 20, 2014, at 8:05 AM, "John Hauck" <jhauck(at)elmore.rr.com> wrote:
> Dennis/Kolbers,
> john h
> mkIII
> Titus, Alabama
> To: kolb-list(at)matronics.com
> Dennis "Skid" Rowe
> Mk3, Rotax 670,
> Leechburg, PA
Titus, Alabama |
frank goodnight
Posted: Wed Aug 20, 2014 1:02 pm Post subject: Radio intercom |
Thanks John
Frank
Do no archive
On Aug 20, 2014, at 3:57 PM, <jhauck(at)elmore.rr.com> wrote:
> John
> Reg or after?
> Thanks Frank
> Sent from my iPhone
>> Dennis/Kolbers,
>> john h
>> mkIII
>> Titus, Alabama
>> Dennis "Skid" Rowe
>> Mk3, Rotax 670,
>> Leechburg, PA
Posted: Wed Aug 20, 2014 1:05 pm Post subject: Radio intercom |
22,000.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Frank
Sent: Wednesday, August 20, 2014 3:32 PM
Frank G
MK 3 classic
234567890123456789012345
Titus, Alabama |
t41pilot
Posted: Wed Aug 20, 2014 2:36 pm Post subject: Re: Radio intercom |
Frank
My Rotax 447 install manual calls for a capacitor across the regulator a minimum of 2000 uf. A greater value is certainly better but the greater the value the larger the physical size. The much larger capacitors were too big to mount directly to my regulator which is where I wanted to install it so I opted for the RadioShack part# 272-1048 2200uf. It's working fine for me and mounts directly across the regulator terminals. You don't have to make a separate ground that way either. The negative side of the regulator should already be hooked to ground. I have no noise issues with my radio. Radioshack also has a 4700uf part# 272-1022 which would be even better. Both capacitors should be available at the store. If you want to mount the capacitor somewhere else then certainly opt for the larger capacitors like 20,000uf.
2011 Firefly |
