fasilpereira
Posted: Tue Aug 26, 2014 4:47 pm Post subject: STA 30 Bulkhead |
Hello guys!
My TR-4 kit came the STA 30 bulkhead (the one that holds the control stick) highly modified because the previous builder had installed automotive seats and control wheel on it.
Now I'm trying to reconfigure the original bulkhead.
Does anybody knows what is the WL of the top of this bulkhead?
I could find on the manual that the stick hinge point is located on WL -11.5, but buld not find the WL of the top of the bulkhead.
Fabricio
_________________ Fabricio Pereira
Engineer / Pilot |
mjpienaar(at)shaw.ca Guest
Posted: Thu Aug 28, 2014 11:48 am Post subject: STA 30 Bulkhead |
I will measure mine when I get to the hangar
fasilpereira
Posted: Thu Aug 28, 2014 7:52 pm Post subject: Re: STA 30 Bulkhead |
Thanks Mike!
Fabricio
Engineer / Pilot |
Posted: Fri Aug 29, 2014 4:15 pm Post subject: STA 30 Bulkhead |
I cannot remenber what is where on the WL but the top of the front bulkhead
on my instalation is 3.5 inches higher than the top of the Main Spar. I
think you should be able to sort it using the Main Spar as a reference
point.
Hope this helps,
fasilpereira
Posted: Sat Aug 30, 2014 4:40 am Post subject: Re: STA 30 Bulkhead |
Mike, from the builders manual:
"The lower fuselage trim line is 1.25 inch above the "joggle". The longitudinal factory "joggle" is located at Waterline -1.25. The trimmed edge 1.25 inch above this is Waterline 0.0."
But that 3.5" reference that you gave me will be work just fine!
Fabricio
Engineer / Pilot |
