		Kellym
				 Posted: Sat Aug 30, 2014 7:02 am    Post subject: Shunt - Location |
				Well, I physically mounted mine, along with an ANL current limiter
 yesterday. I placed the shunt above and to the left of the oil and fuel
 pressure sensor block.  I wired it into the Alt line, your option 1.
 Reason is that I am using the VPX box in lieu of a bus. VPX measures the
 current flow from the battery automatically, and my shunt measure flow
 from Alt, and the VPX shows graphically on my Dynon Skyview where the
 electrons come from and where they go. Hooked up shunt last night and
 verified it did exactly as described, by connecting a battery charger in
 front of the shunt, and a second one on the battery.
 Really slick.
 If you only have one location to measure current, I would do your option
 2, because you want to know whether you are charging the battery or
 drawing from it. Amps from the alternator and total load are less
 important than whether you are discharging your battery.
 I don't know with Garmin, but I suspect that like Dynon you can install
 a second shunt if you really want more info.
 On 8/30/2014 7:47 AM, Phillip Perry wrote:
  	  | Quote: | 	 		   Last night I was thinking about shunt locations and it seems like
  there are 3 different electrical locations for it.
  1) Connected in the B-Lead (to measure the output of the ALT).
  2) Connected to the battery (to measure the load on the battery; but
  it misses the contributions of electrons coming from the ALT to the
  main buss.)
  Location 3 seems to be the most logical spot for me.
  3) Immediately before the main buss.  So the ALT and Battery can be
  sending electrons to the buss and I'll be measuring them before they
  enter the buss as they're consumed.  Then I'm getting a measurement of
  true load (minus the start).
  Where have most of you installed yours?  I really like option 3 but
  want to make sure I'm not missing something.  I'm also curious to know
  where yours is installed? I'm thinking of putting it on the aft side
  of the sub panel, so I can yank a G3X screen and access it.
  Phil
KCHD |
				 Posted: Sat Aug 30, 2014 7:21 am    Post subject: Shunt - Location |
				A lot of options.  Some thoughts:
 <![if !supportLists]>·         <![endif]>Most shunts cannot handle starting current, so the shunt cannot be install anywhere between the battery and the starting solenoid.
 <![if !supportLists]>·         <![endif]>While knowing what the non-starting loads are is of value, once measured there is little more to be gained by having them constantly monitored.
 <![if !supportLists]>·         <![endif]>The load on the alternator however provides an indication of battery health (via charge rate compared with buss voltage).  So the shunt on the alternator output does have some value if monitored.
 <![if !supportLists]>·         <![endif]>On my plane I did not install a current shunt.  I find independent voltage monitoring of each battery to be a better indicator of electrical power distribution system health.  No issue however if one wants to add current monitoring as well.
 Carl
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
 Sent: Saturday, August 30, 2014 10:48 AM
 Subject: Shunt - Location
 Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
 2) Connected to the battery (to measure the load on the battery; but it misses the contributions of electrons coming from the ALT to the main buss.)
 3) Immediately before the main buss.  So the ALT and Battery can be sending electrons to the buss and I'll be measuring them before they enter the buss as they're consumed.  Then I'm getting a measurement of true load (minus the start).
 Where have most of you installed yours?  I really like option 3 but want to make sure I'm not missing something.  I'm also curious to know where yours is installed? I'm thinking of putting it on the aft side of the sub panel, so I can yank a G3X screen and access it.
 Phil
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234567
		saylor.dave(at)gmail.com Guest
				Mine is between the B-lead and the main bus.  Assuming the battery is fully charged, it shows how much power the entire plane is drawing and indicates that the alternator is working.  Right after start-up it shows a larger draw as the battery gets topped off.  Then it settles into its normal routine.  I have a low voltage light, and my engine monitor alerts for hi/low volts and amps.
 --Dave
 Single 925, single PP alt, numerous internal batteries
 On Sat, Aug 30, 2014 at 7:47 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
   [quote]Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
 Phil
 tp://forums.matronics.com
  | 	  [b]
				 Posted: Sat Aug 30, 2014 7:22 am    Post subject: Shunt - Location |
				I prefer to know what my battery is doing. If it goes more than a couple of amps negative with the engine running, then you have problems. Also, right after start you will see 25+ amps positive which is a great indication that your alternator is working well enough to recharge your battery while powering the bus. Knowing what the bus is drawing is good for load shedding, but that's all. The one from the alternator is good too, so you will know if it isn't putting out amperage.
 The battery info is my favorite and most informative one.
 Jesse SaintI-TEC, Inc.
 www.itecusa.org
 www.mavericklsa.com
 C: 352-427-0285
 O: 352-465-4545
 F: 815-377-3694
 On Aug 30, 2014, at 10:47 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
 Phil
 List"">http://www.matronics.com/Navigator?RV10-List
		flying-nut(at)cfl.rr.com Guest
				 Posted: Sat Aug 30, 2014 10:25 am    Post subject: Shunt - Location |
				Mine is in the main battery feed.
        Linn
        On 8/30/2014 10:47 AM, Phillip Perry wrote:
      [quote]       Last night I was thinking about shunt locations and         it seems like there are 3 different electrical locations for it.
          Phil
 No virus         found in this message.
          Checked by AVG - www.avg.com
          08/30/14     [b]
				 Posted: Sat Aug 30, 2014 10:30 am    Post subject: Shunt - Location |
				It is between the starter solenoid (battery side) and my bus. The alternator is also tied to the bus. 8awg wire in and out. The 8awg ties to the same lug as the 2awg going to the battery.
 www.itecusa.org
 www.mavericklsa.com
 C: 352-427-0285
 O: 352-465-4545
 F: 815-377-3694
 On Aug 30, 2014, at 11:33 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
 [quote]Good feedback so far.
 Jessie, on your position, I assume it's inline and handles the start without any issue.  (That's where Garmin suggests)
 What do you actually see on your digital readouts?  Do you see 0 Amps on a charged battery and typically -1 or so inflight?
 I'm just trying to understand the difference between what would be seen monitoring a batteries charge vs monitoring a load at the buss input.
 Very helpful stuff everyone....  Keep the thoughts coming please.
 Phil
 On Sat, Aug 30, 2014 at 10:12 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
   	  | Quote: | 	 		  I prefer to know what my battery is doing. If it goes more than a couple of amps negative with the engine running, then you have problems. Also, right after start you will see 25+ amps positive which is a great indication that your alternator is working well enough to recharge your battery while powering the bus. Knowing what the bus is drawing is good for load shedding, but that's all. The one from the alternator is good too, so you will know if it isn't putting out amperage.
 www.itecusa.org
  www.mavericklsa.com
 C: [url=tel:352-427-0285]352-427-0285[/url]
 O: [url=tel:352-465-4545]352-465-4545[/url]
  F: [url=tel:815-377-3694]815-377-3694[/url]
  	  | Quote: | 	 		  Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
 Phil
		Kellym
				 Posted: Sat Aug 30, 2014 4:14 pm    Post subject: Shunt - Location |
				You really only have two choices. Either between Alternator and buss, or
 between starter relay and buss. The latter tells you what you expect,
 positive charge or discharge. You would have difficulty connecting
 between battery and starter relay because it is #4 wire, requiring
 bigger terminals than the shunt is intended to take, and I don't think
 any shunt is designed for over 100 amps, while starter pulls 2-3 times
 that. So your #2 and #3 necessarily have to be the same place and
 probably will be your choice.
 On 8/30/2014 8:33 AM, Phillip Perry wrote:
  	  | Quote: | 	 		   Good feedback so far.
  Phil
      Jesse Saint
      I-TEC, Inc.
      jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
      www.itecusa.org <http://www.itecusa.org>
      www.mavericklsa.com <http://www.mavericklsa.com>
      C: 352-427-0285 <tel:352-427-0285>
      O: 352-465-4545 <tel:352-465-4545>
      F: 815-377-3694 <tel:815-377-3694>
 >     to the main buss.)
 >     and access it.
 >     Thanks,
 >     Phil
 >     D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
 >     //forums.matronics.com  <http://forums.matronics.com>
KCHD |
		philperry9
				 Posted: Sat Aug 30, 2014 4:32 pm    Post subject: Shunt - Location |
				I'm not sure that's true and it's part of what I'm wrestling with.....  This is a direct quote from the G3X installation manual and from this text, it leads me to believe that it could be placed anywhere in the #2 wire and it would read the charge or discharge rates of that battery.  Am I missing something?
 An alternator ammeter shunt should be installed inline in the alternator output (“B” terminal). A battery ammeter shunt should be installed between the battery positive terminal and the battery contactor.  Depending on the location of the alternator or battery relative to its supported electrical bus, it is typically desirable to install the shunt on the firewall near where the alternator or battery output would normally penetrate the firewall.
 On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
  [quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
  You really only have two choices. Either between Alternator and buss, or between starter relay and buss. The latter tells you what you expect, positive charge or discharge. You would have difficulty connecting between battery and starter relay because it is #4 wire, requiring bigger terminals than the shunt is intended to take, and I don't think any shunt is designed for over 100 amps, while starter pulls 2-3 times that. So your #2 and #3 necessarily have to be the same place and probably will be your choice.
  Phil
  On Sat, Aug 30, 2014 at 10:12 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com) <mailto:jesse(at)saintaviation.com (jesse(at)saintaviation.com)>> wrote:
      Jesse Saint
      I-TEC, Inc.
      jesse(at)itecusa.org (jesse(at)itecusa.org) <mailto:jesse(at)itecusa.org (jesse(at)itecusa.org)>
      C: [url=tel:352-427-0285]352-427-0285[/url] <tel:[url=tel:352-427-0285]352-427-0285[/url]>
      O: [url=tel:352-465-4545]352-465-4545[/url] <tel:[url=tel:352-465-4545]352-465-4545[/url]>
      F: [url=tel:815-377-3694]815-377-3694[/url] <tel:[url=tel:815-377-3694]815-377-3694[/url]>
      to the main buss.)
      and access it.
      Phil
  -List" target="_blank">http://www.matronics.com/Navigator?RV10-List
   FORUMS -
  b Site -
            -Matt Dralle, List Admin.
		Kellym
				 Posted: Sat Aug 30, 2014 5:05 pm    Post subject: Shunt - Location |
				I suppose there might be some aircraft with battery on the firewall
 where you might do that, but it makes no sense.
 What information are you going to get by having the shunt at the
 battery? So you have a shunt that can handle the current, it will have
 less resolution of low current movement. (all shunts are designed for
 0-50mv, where 50 mv equals full scale). The only current you see at the
 battery besides what goes to the buss is the starter and anything else
 that you bypass the buss for some reason.
 You really don't want to be splicing #2 or #4 wire to install a shunt.
 #8 from starter relay to the buss will tell you all the information you
 want.
 I don't have a clue why Garmin wrote that. I'm not aware of any
 certified aircraft that do it that way.
 On 8/30/2014 5:32 PM, Phillip Perry wrote:
  	  | Quote: | 	 		   I'm not sure that's true and it's part of what I'm wrestling with.....
      alternator output (“B” terminal). */A battery ammeter shunt should
      contactor./*  Depending on the location of the alternator or
  <mailto:kellym(at)aviating.com>> wrote:
      <kellym(at)aviating.com <mailto:kellym(at)aviating.com>>
      choice.
          Phil
          <jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
          than a
          positive
          working well
          Knowing
          that's all.
          if it
              Jesse Saint
              I-TEC, Inc.
          <mailto:jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>>
          www.itecusa.org <http://www.itecusa.org> <http://www.itecusa.org>
              C: 352-427-0285 <tel:352-427-0285> <tel:352-427-0285
          <tel:352-427-0285>>
              O: 352-465-4545 <tel:352-465-4545> <tel:352-465-4545
          <tel:352-465-4545>>
              F: 815-377-3694 <tel:815-377-3694> <tel:815-377-3694
          <tel:815-377-3694>>
          <philperry9(at)gmail.com <mailto:philperry9(at)gmail.com>
              seems like
              the ALT).
              the battery;
              from the ALT
                  to the main buss.)
              Battery can
              them
              I'm getting
              option 3
              of putting
              G3X screen
                  and access it.
                  Phil
              tp://forums.matronics.com <http://forums.matronics.com>
      FORUMS -
      b Site -
KCHD |
				 Posted: Sat Aug 30, 2014 5:35 pm    Post subject: Shunt - Location |
				If the #2 wire goes to the starter       solenoid and the buss is connected to that same point with #8 then       the shunt can be placed in the #8 line and not carry starter       current.  Then the shunt will read the charge current minus the       load current.  It all depends on what data you're interested in.
        I want to know the health of my alternator and my battery ..... I       don't care what the 'load' is.  Putting the shunt in the buss to       battery link gives me what I am looking for.  Also, a voltmeter       .... seems like every accessory has one in it .... will tell you       the other half of the data you should have.
        I agree with Kelly .... you don't want anything in that #2 cable       between the battery and the starter .... except the starter       solenoid and master solenoid. Anyway a 300+A shunt is pricey.
        Linn
        On 8/30/2014 8:32 PM, Phillip Perry wrote:
      [quote]       I'm not sure that's true and it's part of what I'm         wrestling with.....  This is a direct quote from the G3X         installation manual and from this text, it leads me to believe         that it could be placed anywhere in the #2 wire and it would         read the charge or discharge rates of that battery.  Am I         missing something?
             	  | Quote: | 	 		               --> RV10-List message posted by: Kelly               McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
                  Phil
                      Jesse Saint
                      I-TEC, Inc.
                        to the main buss.)
                        and access it.
                        Phil
                  FORUMS -
                  b Site -
          08/30/14     [b]
				 Posted: Sat Aug 30, 2014 5:42 pm    Post subject: Shunt - Location |
				I agree. From your earlier email, though, there are actually all 3 choices. You could see how much the bus is using by connecting the alternator to the battery side of the shunt and the bus to the other side. As I mentioned earlier, though, this doesn't give valuable information compared to the other two options.
 Jesse Saint
 Saint Aviation, Inc.
 352-427-0285
 Sent from my iPad
  	  | Quote: | 	 		   On Aug 30, 2014, at 9:04 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  I suppose there might be some aircraft with battery on the firewall where you might do that, but it makes no sense.
  What information are you going to get by having the shunt at the battery? So you have a shunt that can handle the current, it will have less resolution of low current movement. (all shunts are designed for 0-50mv, where 50 mv equals full scale). The only current you see at the battery besides what goes to the buss is the starter and anything else that you bypass the buss for some reason.
  You really don't want to be splicing #2 or #4 wire to install a shunt. #8 from starter relay to the buss will tell you all the information you want.
  I don't have a clue why Garmin wrote that. I'm not aware of any certified aircraft that do it that way.
 > On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com <mailto:kellym(at)aviating.com>> wrote:
 >    choice.
 >        Phil
 >        than a
 >        positive
 >        working well
 >        Knowing
 >        that's all.
 >        if it
 >            Jesse Saint
 >            I-TEC, Inc.
 >        <tel:352-427-0285>>
 >        <tel:352-465-4545>>
 >        <tel:815-377-3694>>
 >            Sent from my iPhone
 >            seems like
 >            the ALT).
 >            the battery;
 >            from the ALT
 >                to the main buss.)
 >            Battery can
 >            them
 >            I'm getting
 >            option 3
 >            of putting
 >            G3X screen
 >                and access it.
 >                Thanks,
 >                Phil
 >            _blank">http://www.matronics.com/contribution
 >    FORUMS -
 >    _blank">http://forums.matronics.com
 >    b Site -
 >    target="_blank">http://www.matronics.com/contribution
		philperry9
				I dug my Aeroelectric book out of one of our moving boxes and I'll try to
 read it with a cup of coffee in the morning.
 I'm mostly interested in understanding charge or discharge rates.  I can
 build a reference load chart (by running on battery only during a test
 session) to determine exactly what each piece of equipment pulls and how I
 might be able to shed load if needed.
 Phil
 On Sat, Aug 30, 2014 at 8:04 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
				 Posted: Sat Aug 30, 2014 6:11 pm    Post subject: Shunt - Location |
				Knowing which piece draws X amps is a       good exercise, but what do you do with the data?  With modern       equipment the load is comparatively small and with the transponder       and strobes off a good battery should outlast your fuel supply.
        Alternator states are typically good charge (depending on battery       level) or no charge.  A slipping belt will be in-between.        Batteries are more insidious .... they fail slowly at first and       then gather steam towards useless.  A good battery health       indicator is the battery voltage just before start ..... how much       did it lose since you last flew?  I have a desulfator trickle       charger that I hook up after each flight so my 'settling time' is       rather short.
        IMHO, of course!
        Linn
        On 8/30/2014 9:42 PM, Phillip Perry wrote:
      [quote]       I dug my Aeroelectric book out of one of our moving         boxes and I'll try to read it with a cup of coffee in the         morning.
          I'm mostly interested in understanding charge or discharge           rates.  I can build a reference load chart (by running on           battery only during a test session) to determine exactly what           each piece of equipment pulls and how I might be able to shed           load if needed.
          Phil
          On Sat, Aug 30, 2014 at 8:04 PM, Kelly           McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>           wrote:
               	  | Quote: | 	 		                                  I'm not sure that's true and it's part of what I'm                 wrestling with.....  This is a direct quote from the G3X                 installation manual and from this text, it leads me to                 believe that it could be placed anywhere in the #2 wire                 and it would read the charge or discharge rates of that                 battery.  Am I missing something?
                                 On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)                 <mailto:kellym(at)aviating.com (kellym(at)aviating.com)>>                 wrote:
                      choice.
                          Phil
                          <mailto:jesse(at)saintaviation.com (jesse(at)saintaviation.com)>>>                 wrote:
                          than a
                          positive
                          working well
                          Knowing
                          that's all.
                          if it
                              Jesse Saint
                              I-TEC, Inc.
                        <mailto:jesse(at)itecusa.org (jesse(at)itecusa.org)               <mailto:jesse(at)itecusa.org (jesse(at)itecusa.org)>>
                            C: [url=tel:352-427-0285]352-427-0285[/url] <tel:[url=tel:352-427-0285]352-427-0285[/url]>               <tel:[url=tel:352-427-0285]352-427-0285[/url]
                        <tel:[url=tel:352-427-0285]352-427-0285[/url]>>
                            O: [url=tel:352-465-4545]352-465-4545[/url] <tel:[url=tel:352-465-4545]352-465-4545[/url]>               <tel:[url=tel:352-465-4545]352-465-4545[/url]
                        <tel:[url=tel:352-465-4545]352-465-4545[/url]>>
                            F: [url=tel:815-377-3694]815-377-3694[/url] <tel:[url=tel:815-377-3694]815-377-3694[/url]>               <tel:[url=tel:815-377-3694]815-377-3694[/url]
                          <tel:[url=tel:815-377-3694]815-377-3694[/url]>>
                          <philperry9(at)gmail.com (philperry9(at)gmail.com)                 <mailto:philperry9(at)gmail.com (philperry9(at)gmail.com)>
                            <mailto:philperry9(at)gmail.com (philperry9(at)gmail.com)>>>                   wrote:
                                seems like
                                the ALT).
                                the battery;
                                from the ALT
                                    to the main buss.)
                                Battery can
                                them
                                I'm getting
                                option 3
                                of putting
                                G3X screen
                                    and access it.
                                    Phil
                    FORUMS -
                    b Site -
                  FORUMS -
                  b Site -
          08/30/14     [b]
		philperry9
				 Posted: Sat Aug 30, 2014 6:21 pm    Post subject: Shunt - Location |
				I think I just sorted it out in my head.  I was thinking that the #8 B-Lead, #2 Battery, and #8 Buss feed wires would all bind at the battery-side post of the starter solenoid.   This would mean I have a single feed to the 'real' buss bar.
 I'm now 99% sure that's not the case.  I need to look at it closer, but I believe I've got a connection for the B-Lead on one end of the buss and on the other end of the buss I have a battery connection.  That makes perfect sense when someone says to put it "in the battery lead".
 I won't be back at the hangar until Tuesday, but I'm pretty sure I just figured it out.  Sometimes I'm dense!
 Phil
 On Sat, Aug 30, 2014 at 9:10 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
 [quote]                    Knowing which piece draws X amps is a       good exercise, but what do you do with the data?  With modern       equipment the load is comparatively small and with the transponder       and strobes off a good battery should outlast your fuel supply.
        IMHO, of course!
        Linn
       	  | Quote: | 	 		         I dug my Aeroelectric book out of one of our moving         boxes and I'll try to read it with a cup of coffee in the         morning.
 Phil
                      choice.
                          Phil
                          than a
                          positive
                          working well
                          Knowing
                          that's all.
                          if it
                              Jesse Saint
                              I-TEC, Inc.
                                seems like
                                the ALT).
                                the battery;
                                from the ALT
                                    to the main buss.)
                                Battery can
                                them
                                I'm getting
                                option 3
                                of putting
                                G3X screen
                                    and access it.
                                    Phil
                    FORUMS -
                    b Site -
                  FORUMS -
                  b Site -
          08/30/14
		Kellym
				 Posted: Sat Aug 30, 2014 7:40 pm    Post subject: Shunt - Location |
				Yes, that is what you want. One more failure state to an alternator     that wasn't mentioned, is the failure of one or two diodes. That     will result in an alternator that will produce 10-20 amps, but no     more. You would see it as a small discharge on your battery, and not     going to 25+ amps right after start as it should. (similar to loose     and slipping belt results) Otherwise, you will have full alt output     or no output in most cases.
      On 8/30/2014 7:20 PM, Phillip Perry       wrote:
       	  | Quote: | 	 		         I think I just sorted it out in my head.  I was         thinking that the #8 B-Lead, #2 Battery, *and #8 Buss feed         wires* would all bind at the battery-side post of the starter         solenoid.   This would mean I have a single feed to the 'real'         buss bar.
       | 	       It also means you are are seeing the entire system except for the     starter draw, and will know whether the battery is being charged or     discharged.
          Phil
             	  | Quote: | 	 		                              Knowing which piece draws X amps is a good exercise,                 but what do you do with the data?  With modern equipment                 the load is comparatively small and with the transponder                 and strobes off a good battery should outlast your fuel                 supply.
                  IMHO, of course!
                  Linn
                    Phil
                                    choice.
                                        Phil
                                        than a
                                        positive
                                        working well
                                        Knowing
                                        that's all.
                                        if it
                                            Jesse Saint
                                            I-TEC, Inc.
                                              seems like
                                              the ALT).
                                              the battery;
                                              from the ALT
                                                  to the main buss.)
                                              Battery can
                                              them
                                              I'm getting
                                              option 3
                                              of putting
                                              G3X screen
                                                  and access it.
                                                  Phil
                                  FORUMS -
                                  b Site -
                                FORUMS -
                                b Site -
                      08/30/14
  | 	       [b]
KCHD |
		rv10flyer
				 Posted: Sat Aug 30, 2014 8:32 pm    Post subject: Re: Shunt - Location |
				I have three hall effect current sensors on my GRT. Main Bat feed , Aux Bat feed and Alt feed.  A toggle can be switched between the Bat and Alt sensors. Does Garmin not work with the hall effect type sensors?
  _________________ Wayne G. |
		philperry9
				 Posted: Sun Aug 31, 2014 3:49 am    Post subject: Shunt - Location |
				The toggle switch on a pair of hall effect sensors is a good idea
 The Garmin does work with them but I already own a pair of shunts.  And at this point in the project, I'll take advantage of the stuff I own and try to keep from spending any more money than I have to.
 Phil
 On Sat, Aug 30, 2014 at 11:32 PM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
  [quote]--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
  Wayne G.
  http://forums.matronics.com/viewtopic.php?p=429669#429669
   FORUMS -
  b Site -
		Kelly McMullen
				 Posted: Sun Aug 31, 2014 6:37 am    Post subject: Shunt - Location |
				So put one shunt on the alternator B+ line and one one the starter relay to buss line and you will know both what the battery is providing and what the alternator is providing.
 On Sun, Aug 31, 2014 at 4:48 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
 [quote] The toggle switch on a pair of hall effect sensors is a good idea
 Phil
A&P/IA, EAA Tech Counselor
KCHD |
		bill.peyton
  Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
				 Posted: Sun Aug 31, 2014 6:48 am    Post subject: Re: Shunt - Location |
				You are over thing it.  The shunt should always be place on the output lead of the alternator.  The aircraft does not run on the battery, it derives it's power from the alternator.  The only time the battery is used in the aircraft, or an automobile for that manner, is when you start the engine, or if the alternator fails.  The bus voltage can be used to trigger the g3x to provide you a warning and also a status if the alternator fails.  I. Addition, the plane power alternators have a separate lead that you can hook up to an indicator light on the panel to indicate an alternator failure.
 In summary, you should be monitoring the current being drawn from the alternator, and set up the G3x to alarm you during overcurrent and under current situations.  You should also set up a voltage level alarm for over voltage and under voltage on both your primary and secondary battery.  In addition, you should have a load shed plan in case of the alternator failure.  Use this plane to de-power the high current unnecessary items on the bus.
  _________________ Bill
WA0SYV
Aviation Partners, LLC |
		woxofswa
				 Posted: Sun Aug 31, 2014 11:00 am    Post subject: Re: Shunt - Location |
				Wiring the traditional way of consumptive drain on the battery still gives a lot of info options.
 With everything running, the meter will still spike with new items energized as a back up indication that the wizzie is getting power.
 You can also get the draw of individual items by checking them with the ALT off. That is nice to be able to check and note during construction or adding new items. (I used a ground power plug during construction).
 Obviously that is usually done on the ground with the engine not running, but it doesn't have to be. I know there is controversy about turning the alt off with the engine running, but Socata used to have just such a check as part of the run up.  If you need to know the total draw on the ALT, turning it off will tell you. (after batt has been start replenished).
  _________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
