Zenith601-List Digest: 0 Msgs - 08/30/14
mvarelasartal(at)yahoo.es
PostPosted: Fri Sep 05, 2014 12:46 am    Post subject: Zenith601-List Digest: 0 Msgs - 08/30/14 Reply with quote
Hi to all,
I´m going to start to Weld the 4130 parts (brakes, engine jig, etc...) What you recommend for tig Weld, ER70 or ER80 and which size?
Thanks to all in advance.....
Marcos Varela
CH601 HD
Spain
El Domingo 31 de agosto de 2014 9:13, Zenith601-List Digest Server <zenith601-list(at)matronics.com> escribió:
Today's complete Zenith601-List Digest can also be found in either of the
of the Zenith601-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-08-30&Archive=Zenith601
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-08-30&Archive=Zenith601
  Zenith601-List Digest Archive
  Total Messages Posted Sat 08/30/14: 0
Today's Message Index:
nith601-List" target="_blank">http://www.matronics.com/Navigator?Zenith60bsp; ums.matronics.com/" target="_blank">http://forums.matronics.com/
_; -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
psm(at)att.net
PostPosted: Fri Sep 05, 2014 4:07 am    Post subject: Zenith601-List Digest: 0 Msgs - 08/30/14 Reply with quote
Hi Marcos,
I built a Buttercup fuselage using 4130 and ER70S2 filler rods. It was a while ago so I am not sure of the filler rod sizes I used but I think I used 1/16 for most of the work. The filler rod should be selected for the thickness of the pieces being joined.
Paul
Camas, WA, USA
On 9/5/2014 1:42 AM, Marcos Varela Sartal wrote:
[quote] Hi to all,
Marcos Varela
CH601 HD
Spain
larrycmcfarland(at)gmail.
PostPosted: Fri Sep 05, 2014 5:31 am    Post subject: Zenith601-List Digest: 0 Msgs - 08/30/14 Reply with quote
Marcos,
I’d recommend ER70 and .050 diameter weld rod
Less the chance of cold welds.  ER 70 will alloy with 4130 and give a better weld.
Larry McFarland
www.macsmachine.com
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Marcos Varela Sartal
Sent: Friday, September 05, 2014 3:42 AM
Subject: Re: Zenith601-List Digest: 0 Msgs - 08/30/14
Hi to all,
Marcos Varela
CH601 HD
Spain
El Domingo 31 de agosto de 2014 9:13, Zenith601-List Digest Server <zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)> escribió:
HTML Version:
Text Version:
PostPosted: Fri Sep 05, 2014 2:39 pm    Post subject: Zenith601-List Digest: 0 Msgs - 08/30/14 Reply with quote
Thanks a lot for the information. I´ll order ER70 to start welding brake pedals and control bar.
Here some pictures of my progress....
My Best Regards
El Viernes 5 de septiembre de 2014 15:36, Larry McFarland <larrycmcfarland(at)gmail.com> escribió:
Marcos,
Larry McFarland
http://www.macsmachine.com/
Hi to all,
Marcos Varela
CH601 HD
Spain
HTML Version:
Text Version:
 Filesize:  150.03 KB
 Viewed:  7023 Time(s)
 Filesize:  142.69 KB
PostPosted: Sat Sep 06, 2014 5:33 am    Post subject: Zenith601-List Digest: 0 Msgs - 08/30/14 Reply with quote
Beautiful work Marcos,
The 601 is a great project that satisfies during the build process.
If my website can be of any assist in your fabrication process,
do visit and send questions if needed.
Best regards,
Larry McFarland
Sent: Friday, September 05, 2014 5:35 PM
Subject: Re: Re: Zenith601-List Digest: 0 Msgs - 08/30/14
My Best Regards
Marcos,
Larry McFarland
Hi to all,
Marcos Varela
CH601 HD
Spain
HTML Version:
Text Version:
[quote] http://www.matronics.com/Navigator?Zenith601-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution http://www.matronics.com/========================forums.matronics.com/" target="_blank" rel="nofollow">http://forums.mat=   --> [b]
