		clivesutton
		Philipgeorge347(at)hotmai Guest
		graeme bird
				 Posted: Fri Sep 12, 2014 11:05 am    Post subject: Re: Loading/unloading a mono without wings attached? |
				I made a pair of stabilisers that bolt to the wheel hanging arm on a U frame, there were some pictures of a similar contraption on the builder photo pages. My son also made, as a collage project, a pair of wheels on axels that poke in the wheel hub with a support 'A' frame that bolted to the top of the hanging wheel arm. I ll see if I can find some pictures.
  _________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
		clivesutton
				 Posted: Fri Sep 12, 2014 11:31 am    Post subject: Re: Loading/unloading a mono without wings attached? |
				Because there is not much room in my single garage and IF it both trailer and fuselage will go in, there will not be enough room to work on/under it as well.
		clivesutton
				 Posted: Fri Sep 12, 2014 11:32 am    Post subject: Re: Loading/unloading a mono without wings attached? |
				Graeme - thanks, that would be great
		Fred Klein
				 Posted: Fri Sep 12, 2014 12:33 pm    Post subject: Loading/unloading a mono without wings attached? |
				Although I have EXTREMELY LIMITED experience of loading / unloading the mono from the Europa trailer, I share your concerns. I believe that with future operations I will be stabilizing the fuselage w/ a ratcheting tension strap on both sides of the cockpit secured to the door sill with a custom slip-on bracket, thence down to the trailer frame.
 BTW, best of luck w/ your STOL experiments…sounds like you’ve designed a reasonable plan, though personally, I would want to have very high confidence in the mechanics of any moveable leading edge slats in order to avoid the obvious problems w/ assymetry.
 F.
 On Sep 12, 2014, at 11:21 AM, Clive Sutton <clive.maf(at)googlemail.com> wrote:
  I'm considering a mono but wondering how the a/c fuselage is loaded and unloaded on/off of the traditional mono trailer.  I don't have much drive space at home and would really like to be able to load and unload without using the wings to prevent the fuselage from 'rolling over' when the main wheel is out of the 'scoop' platform.  What is the considered view about this - can it be done and if so what solutions have people developed please?  Clive
  http://forums.matronics.com/viewtopic.php?p=430440#430440
		roddyeuropa(at)aol.com Guest
				 Posted: Sat Sep 13, 2014 10:31 am    Post subject: Loading/unloading a mono without wings attached? |
				Something I have done many times to  take my mono off its trailer is to take off the top cowl and hoist it up (engine hoist or hoist from a beam in the garage). Useful to check uc retraction, adjust bungee , or work on engine. Just make sure it's secure!
 Roddy kesterton g-KRK
  	  | Quote: | 	 		   On 12 Sep 2014, at 20:31, "Clive Sutton" <clive.maf(at)googlemail.com> wrote:
  http://forums.matronics.com/viewtopic.php?p=430444#430444
