		cjpilot710(at)aol.com Guest
				 Posted: Fri Sep 12, 2014 12:01 pm    Post subject: Reverse Rotation Denied!Now Landings. |
				Rico,
  I can ditto much of what Mark points out and only add that where you are  looking during the landing can have BIG effects on when you flare the  airplane.  Looking to far down the runway or to close to the airplane will  not give you the best depth perception for height.  You should  move you vision in too and away from the airplane constantly.  Looking  further down the runway will give you pitch, roll, and yaw cues but height  judgement suffers.  Looking to close to the airplane, you may get height  awareness better but the other parameter lose perception.  Keep your vision  moving.
  Like Mark I have my airplane configured (gear & flaps down) at the  perch.  My power is about 12-1500 rpm IAS about 85kts.  Bank angle is  hardly ever over 30 degrees.  Trimmed.
  Jim "Pappy" Goolsby
   In a message dated 9/12/2014 3:03:27 P.M. Eastern Daylight Time,  rocknpilot(at)hotmail.com writes:
   	  | Quote: | 	 		     Mark,
    Hit you w/ my best shot? On the contrary: I'd salute you if my civilian    salute carried any weight.
    1st of all - and most importantly - THANK YOU for your service to your    country. What I wouldn't give to hear some of the amazing stories you could    easily spill for hours. Also, it's very humbling to me as I try to find my way    amongst those whom have such a rich aviation background. You guys are the    reason I READ much more than I could ever contribute - and why I LEARN much    more than I may ever be able to teach.
    2nd - THANK YOU for this wealth of info. I need to read this a dozen more    times to truly digest it, but suffice to say - when I was still just a    "lurker" in search of a Yak, I had the perils of "coffin corner" burnt into my    brain. I do not lie when I say it resonates within me every time I turn    base-to-final now. Love the idea of a "stabilized, trimmed approach." Makes    much sense that if you want a good landing, that process should not be    complicated by wrestling w/ the airplane to achieve runway center,    longitudinal correction, etc. I think that point hit home the most - as I know    I am guilty of complacency - often trying to find "the pocket" during flair    rather than approach.
    To me, THIS is both the beauty and purpose of "The List." I can't speak    for everyone, but these convo's really are valuable to me. Not only do they    provide great discussion based around a common passion and "a-HA" moments,    they also may confirm GOOD practices, as well as inspire ME to 1) fly, and 2)    fly BETTER. Sadly, there are times these pages turn into a (politically    correct) "Urinating Contest." There are valuable lessons to be learned here -    ones that may be missed if one is too intimidated to ask. So from the official    "weak link" in your midst, I thank you guys for your patience and wisdom. I    have no business being in the Yak business. Therefore you can bet I'm going to    go for broke as I attempt to earn my keep.
    Now I can't wait to fly...but the 400' ceiling is laughing at    me...
 Rico Jaeger
 915 S. 11th Ave.
 Wausau, WI. 54401
 715.529.7426
 1966 Cessna    150F                               ^/---//-X
 N8558G                                                        //
 1992 Yakovlev Yak 52    ^/---//-X
 N21YK                                           //
 To: yak-list(at)matronics.com
 Subject: RE:    Reverse Rotation Denied!
 Date: Fri, 12 Sep 2014 11:21:32    -0600
 I’ll    be the first to bite at this apple.  As an old LSO, the key to consistent    landings is a stabilized, trimmed up approach.  I would suggest lowering    your flaps and trimming the aircraft for your approach speed before you begin    your turn off the perch.  It may require a LITTLE tighter pattern or a    LITTLE shorter final because of the additional drag of the flaps.  But I    strongly recommend a pattern that doesn’t exceed 25-27 degrees angle of bank    and a wings level final not less than eight to ten seconds.   The    turn of less than 30 AOB allows for a little margin for overshooting    crosswinds without wrapping it up too tight and the 8-10 second wings level    final gives you a little cushion to handle an overshoot and still safely work    back to centerline and be stabilized before you begin your flare.  Turns    off the perch requiring up to 45 degrees AOB require excess airspeed to handle    the slight load factor and you end up having to fix a higher than desired    airspeed on final.  Again not stabilized and may result in issues eating    up you interval in a formation recovery or the urge to get it on the deck    sooner than desired.  I know there are those out there that want to be    very tight in the pattern due to the POSSIBLITY of an engine failure.  At    my home field at 3,320’ with a 3,000’ runway that I normally land on, unless    the engine quits abeam the intended point of landing I’m not going to be in a    position to land on the remaining runway.  It’s a different story for    those of you with much longer runways.  I’m not advocating a pattern that    would look comfortable to a 747 captain.   But, I know of two RPA    aircraft that have gone down in the pattern due to wrapped up turns to final,    but am not aware of any who have perished from losing an engine in the    pattern, so I’m a strong advocate of a NOTSO tight pattern particularly in    multi ship formations with overshooting crosswinds where everyone rolls out    downwind with their interval on their nose and by the time Dash 4 is at the    perch, he’s not abeam the intended point of landing, he’s NEARLY OVER the    intended point landing.  We have vastly differing levels of experience in    our RPA community and the desire to hack it by some FNG’s has likely made for    some exciting landings and probably a few lost comrades.  Every time I go    the southern route to our cabin in Colorado I pass the airport at Walsenburg,    CO and am saddened by the memory of the father and son that perished there    several years ago in their new Nanchang on the way to OSH flying what was, for    the density altitude and/or winds that day, too tight of a pattern.  So,    maybe when we start losing  more aircraft in the pattern from engine    failures than from wrapped up approach turn stalls I’ll be more inclined to    advocate the very tight pattern, until then I’ll stand by a 25-27 degree AOB,    trimmed up, stabilized turn that yields consistent and safe results.
 Sorry    to diverge beyond landings themselves, but the pattern is where it all    begins.
 As    not just an old LSO, but also a Naval Aviator, I can take it just as well as I    can dish it out.  Hit me with your best shot!
 Mark    Davis
 N44YK
 Former    Garuda and Guntrain Paddles
 P.S.     Before I completed this I saw Richard Hess’s comments on    airspeeds.  They’re the same I use.  Bleeding off excess airspeed on    short final is easy with the paddle blade prop.
 From:    owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Rico    Jaeger
 Sent: Friday, September 12, 2014 9:22 AM
 Subject: Reverse Rotation    Denied!
 Well    guys...the throttle-up technique worked 2 for 2 last night. But I also noticed    that I was (probably) shutting down w/ my cylinder temp running a little on    the hot side. So...more Yak lessons added to an already thick course    folder.
 NEW    TOPIC: May I take a poll regarding approaches? I believe the 52 is a pooch to    fly.  But my landings are truly erratic.  I know most pilots would    never admit these quirks (Above ALL else - LOOK SMOOTH) but I range from    greasing it in, to 2.5G drops pretty routinely. 'Went up Tuesday and walked    away going "Wow. I think I've got this." 'Went up last night and went "Wow. No    I don't." In my limited experience, the Yak has spanked me hard enough to    humble me completely on numerous occasions. Now, I realize landings are a very    personal aspect of flying. Some go full-stall while others maintain a little    power and fly down to the runway. Then it seems - no matter what your    technique or experience - there are just "those" days. Watching AirVenture    arrivals leaps to mind. I'm sure some very capable pilots leave more rubber on    27 than they would've ever predicted. But I cannot and WILL not chime in w/    the runway-side "quarterbacks" critiquing all, while their bacon is planted    squarely in a lawn chair. It's not my style to pump up my ego by delighting in    the deflation of others'. That said...I want to learn. And since I believe in    wisdom and safety over pride - I ask.
 I've    been tutored by some of the best, but their methods were often conflicting.    The following is an "average" account of what I do for an approach - albeit    based on limited experience and still a fairly steep learning    curve:
 I fly    a typical retractable pattern. On downwind I have been going to 80% power,    prop fine, carb heat on at the top of downwind, gear down abeam. By the time    I'm ready to turn base I'm at about 85 knots. On base I have been bringing    power back to 70% and maintaining 80 - 85 knots w/ my descent. As soon as I    roll wings level on final - probably 1/4 mile from the numbers, I dump flaps.     As I push the nose down this has me at about 75 - 80 knots, reduce power    to 60% and as I flair airspeed drops to about 70 and bleeds off. Anything    slower - to me - feels very mushy.
 Now...if I have "ballast" in back,    I've found that I can plant it at just about any airspeed. But if I'm solo, it    needs to be as slow and gentle as possible or I have bounced back up - and    more than once - gotten into some majorly-ugly oscillations that left me in a    go-around situation w/ my vitals uncomfortably elevated.
 Please    talk to me. Guide me, experienced Yakkers...and as always - THANK    YOU!
 Rico Jaeger
 915 S. 11th    Ave.
 Wausau,    WI. 54401
 715.529.7426
 N8558G                                                        //
 N21YK                                           //
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Yak-List  | 	  01234567
 8
 9 |
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dale
				 Posted: Fri Sep 12, 2014 6:58 pm    Post subject: Re: Reverse Rotation Denied!Now Landings. |
				200 k downwind 70 to 75% leave prop alone rest of landing.
 170 k base flaps down trim for hands off
 150 k final trim again hands off flight
 Hold 150 k use power to hold touchdown point in windshield all
 Start flair by rounding out and slowly reduce power
 Perfect smooth greaser landing every time.
 Need a go round grab a handful of handles and push them forward
 Yak has the power and will go. Not like a Stock Cj
		thedicepilot(at)gmail.com Guest
				 Posted: Sat Sep 13, 2014 10:39 am    Post subject: Reverse Rotation Denied!Now Landings. |
				I agree with Dale's landing list except I use 82% on the prop setting throughout.  It gives you additional power if needed in a go around situation and also provides prop air braking to get the airspeeds down for gear and flap extension if you are in a standard pattern (not an overhead break).  160 clicks on base works great. 150 on final to 140 holding the flair.  I tend to pull the power a bit sooner for short field practice.
 Weeds On Sep 12, 2014 8:01 PM, "Dale" <dale(at)frii.com (dale(at)frii.com)> wrote:[quote]--> Yak-List message posted by: "Dale" <dale(at)frii.com (dale(at)frii.com)>
  http://forums.matronics.com/viewtopic.php?p=430467#430467
  List" target="_blank">http://www.matronics.com/Navigator?Yak-List
		Dale
				 Posted: Sat Sep 13, 2014 11:22 am    Post subject: Re: Reverse Rotation Denied!Now Landings. |
				The higher the % the closer the pattern the shorter the glide/drag. Do it at any power setting. I use whatever I enter the pattern at. If cruise setting I just leave it there. I don't load up the prop using it as a speed brake. Just my suggested for a smoother landing.  A little more time and a flatter glide angle.
		Viperdoc
				 Posted: Sat Sep 13, 2014 6:21 pm    Post subject: Reverse Rotation Denied!Now Landings. |
				As Dale said. the translated RU pilot's handbook calls for 70% and 40 mm manifold pressure.
 As he said anything higher will result in increased drag as you get into the 50 m range  on final. Aero braking will shorten your landing roll on touchdown. If you have a "balked" landing grab a hand full go leavers and push them smoothly to the firewall.
 Doc
  	  | Quote: | 	 		   On Sep 13, 2014, at 2:22 PM, Dale <dale(at)frii.com> wrote:
  http://forums.matronics.com/viewtopic.php?p=430495#430495
  _________________ Viperdoc |
