cjhukill(at)cox.net Guest
Posted: Fri Sep 19, 2014 5:42 am Post subject: other nose gear issue |
Is there anything that we as group can do to put pressure on Vans to determine if this was a faulty weld or design? Even if they won't admit fault, we could get someone to design a fix. I have already had an expert welder look at mine, without the paint removed. He says that the penetration SEEMS ok, however you can't really tell without further tests. He has come up with a reinforcing strap that would increase it's strength, and I may have it done when I remove the assembly for the SB. Danny, can I get copies of the photos that you took of the failed welds to see exactly where they broke?
Chris Hukill
