fasilpereira
Posted: Mon Sep 22, 2014 12:44 pm Post subject: KIS TR-4 Spinner |
Does anybody knows what is the correct Spinner diameter to fit on a Kis tr-4 cowling with rectangular air intake?
I'm thinking on buying a Vans RV standard fiberglass Spinner, but don't know if it will fit.
Fabricio
_________________ Fabricio Pereira
Engineer / Pilot |
ftyoder(at)yoderbuilt.com Guest
Posted: Mon Sep 22, 2014 3:53 pm Post subject: KIS TR-4 Spinner |
I have a TR-1 and it is a little over 10" I think. You can start by
measuring the cowl face width and height to get an idea. Is the engine
mounted, if so, with new mounts? They sag with age, 7 to 10 years is usually
the max life. If the engine is in, measure from the center of the prop
flange to the top of the cowl. That is where you probably want the spinner
to be flush or 1/8" high with new motor mounts. Once you know the diameter
you can look at the options in Aircraft Spruce for a stile you like. It will
take some work, you need to have a prop so you know the its thickness to get
the proper front bulkhead.
galinhdz(at)gmail.com Guest
Posted: Tue Sep 23, 2014 3:35 am Post subject: KIS TR-4 Spinner |
FWIW I have a 12" spinner on my KIS TR-4.
On Mon, Sep 22, 2014 at 7:54 PM, Tim Yoder <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
[quote]--> KIS-List message posted by: "Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)>
mjpienaar(at)shaw.ca Guest
Posted: Tue Sep 23, 2014 6:55 am Post subject: KIS TR-4 Spinner |
Fabricio
I have the spinner that came with my kit that I am not using so you can have
that if you need it
fasilpereira
Posted: Tue Sep 23, 2014 12:14 pm Post subject: Re: KIS TR-4 Spinner |
Hi guys,
first please apologize for the duplicate message. I've sent it via Mobile Phone and don't know why that happened.
Galin,
thanks for sending your spinner dimensions. I'll measure my cowling and check it 12" will make a nice fit.
Mike,
I'll send an email to you about your KIS spinner.
Best regards,
Fabricio
Engineer / Pilot |
hansoncp(at)netnitco.net Guest
Posted: Tue Sep 23, 2014 4:33 pm Post subject: KIS TR-4 Spinner |
I purchased an aluminum spinner from Spruce. 12-1/16" diameter BN-3 part
#0060, Forward facing flange #05-00585, 1/16" Prop spacer #10055-1,ACS
machine fee 05-04904, High polish finish. Total amount was $396. The Spruce
vendor's phone is 928-855-8613. Talk to Valerie. I would buy it again.
Happy building.
