bob88
Posted: Wed Oct 08, 2014 10:29 am Post subject: Connector for shielded wire |
What is best way to connect a shielded wire (shielded part)? Can I use a regular Molex connector and just treat the shield like one of the other wires? Is there a better way? I need to connect shielded wiring from my position LED lights at the wing roots.
voltar(at)vx-aviation.com Guest
Posted: Wed Oct 08, 2014 10:57 am Post subject: Connector for shielded wire |
Works just fine, that's what I did in my HR-II and RV-9A.
Vern
kenryan
Posted: Wed Oct 08, 2014 11:29 am Post subject: Connector for shielded wire |
Is shielding necessary for LED lights? I have two Aveo beacons (Red Baron XP and Red Baron Mini) and they told me that shielded wire is not necessary.
On Wed, Oct 8, 2014 at 10:29 AM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> AeroElectric-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=431659#431659
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
bob88
Posted: Wed Oct 08, 2014 11:55 am Post subject: Re: Connector for shielded wire |
AeroLED installation instruction for NS90 lights specifies shielded wire...
bmwr606
Posted: Thu Oct 09, 2014 7:34 am Post subject: Re: Connector for shielded wire |
unless you need to remove the wings on a regular basis, leave a "service loop" at the wing root ...
no chance of a connector failure or corrosion but if a future need for wing removal arises you can cut the service loop and add a connector at that time
i usually leave about a 4 inch diameter service loop
