nickc(at)mtaonline.net Guest
Posted: Sun Oct 19, 2014 5:00 pm Post subject: Droop tip |
Kolb builders,
Here are a couple pictures showing the droop tip protruding ahead of the wing leading edge, in reference to yesterdays post.
Nick Cassara
Palmer, Alaska
58.54 KB |
3007 Time(s) |
53.94 KB |
3007 Time(s) |
Posted: Sun Oct 19, 2014 5:29 pm Post subject: Droop tip |
Nick- Where did you get the tips? Not even a close fit.
Bill Sullivan
On Sun, 10/19/14, Nick Cassara <nickc(at)mtaonline.net> wrote:
Subject: Droop tip
Date: Sunday, October 19, 2014, 8:59 PM
Kolb builders, Here are a couple pictures
edge, in reference to yesterdays post. Thanks, Nick CassaraPalmer,
Alaska
smlplanet(at)msn.com Guest
Posted: Sun Oct 19, 2014 7:18 pm Post subject: Droop tip |
There has to be something wrong to fit like that. I have worked with F/G for years and as thin as that has to be you'll have problems. They may have set you the wrong ones or have a bad mold.
As I said I had put a set on my Challenger with out any problems which fit a lot better than the photos show.
[quote] Date: Sun, 19 Oct 2014 18:29:35 -0700
Subject: Re: Droop tip
--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net>
Bill Sullivan
Subject: Droop tip
Alaska
