		mvarelasartal(at)yahoo.es Guest
				 Posted: Wed Oct 29, 2014 11:14 pm    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 |
				Hello alla again,
 I need some help as aI have to order parts from aircraft Spruce and I´m in doubt:
 - I want to order the throttle control but I don´t quite  understand the diferences. I have preselect this one: A-790  Spruce Part Number 05-08160. My engine is a Jabirú and I want both push button lock and fine adjust rotating, Is that one? I´m also planning to mount another one on the other side but Is that posible, Is there a way to unlook it to use fron the right or left side on the cockpit?
 - What type of U rubber to seal the canopy on the front? This will fit  T-897 Ref. 05-11202
 - What type of NACA air inlets for the cabin sides. I´ve  preselect 001HE Ref. 05-00862
 And the last question and belive me that I don´t want to abuse of all of your patience.... Where can I  get  the latch system  (XL system)? I saw some pictures about how to Weld it to the frame but  I don´t know if this kind of latch is sold on a hardware store, Is there an special name for it or reference?
 Thanks so much to this fórum in advance. I´m sorry for not attach links and references but Yahoo mail is not so friendly for that. If someone needs for clarify I´ll try to sent from my e-mail.
 Marcos
 CH601HD (modified)
 Spain
      El Martes 28 de octubre de 2014 8:11, Zenith601-List Digest Server <zenith601-list(at)matronics.com> escribió:
 Today's complete Zenith601-List Digest can also be found in either of the
 two Web Links listed below.  The .html file includes the Digest formatted
 and Message Navigation.  The .txt file includes the plain ASCII version
 of the Zenith601-List Digest and can be viewed with a generic text editor
 HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-10-27&Archive=Zenith601
 Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-10-27&Archive=Zenith601
                            Zenith601-List Digest Archive
                      Total Messages Posted Mon 10/27/14: 0
 Today's Message Index:
  nith601-List" target="_blank">http://www.matronics.com/Navigator?Zenith60bsp;         ums.matronics.com/" target="_blank">http://forums.matronics.com/
 _;                   -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		bryanmmartin
				 Posted: Thu Oct 30, 2014 8:28 am    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 |
				-Throttle cable:
 The A-790 does have the fine adjustment feature. I don’t believe the A-790 will work with a two throttle system. The lock on one throttle will prevent the other throttle from moving.
 The A-820 will be better for a two throttle system. It has a friction lock that will allow a second throttle to work also.
 Both the A-790 and A-820 have a wire end and can be cut to any desired length.
 I have only one throttle control in my plane, on the left side of the panel. I have the center Y control stick. I can sit in the right seat and still reach the throttle if I change hands on the stick. I don’t fly from the right seat but I believe the plane could be safely controlled from the right seat in an emergency.
 -Rubber seal: The T-897 looks like the same material used by Zenith in the kit. It should work.
 -Vents: I have NACA vents like these in my plane. The help keep the cabin cool but on a hot summer day they are not enough. I added a Vista Vent to the each side of the canopy and they work very well. Part # 13-03500 or 05-08078.
 Canopy latch: The 601-XL canopy latch is an automotive style door or trunk latch. You might find something usable at a auto parts store or junkyard. Or maybe these would work:  http://www.horton.on.ca/Products/prodpages/hoodtrunklatches.htm
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus re-drive.
 On Oct 30, 2014, at 2:58 AM, Marcos Varela Sartal <mvarelasartal(at)yahoo.es (mvarelasartal(at)yahoo.es)> wrote:
 [quote]Hello alla again,
 Marcos
 CH601HD (modified)
 Spain
  _________________ --
Bryan Martin
do not archive. |
				 Posted: Thu Oct 30, 2014 12:07 pm    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 |
				Thanks a lot Brian for your answer and tips.....Now are everything clear.
 I planning to fly fron the left side (control stick is standard centered) but I prefer to add both controls pedals and throttle to the right side also. I´m flying a Minimax right now but for flight test and so the trainer will fly with me on the first flights....
 I also planning to add Vista Vents, these is what I use on the Minimax and Works great. Any way here in the North of Spain it isn´t too hot even in summer.
 I´ll find the latchs on a scrapping cars store (I had not thought.....).
 Many thanks again......
 Marcos
 CH601HD (modified)
 Spain
      El Jueves 30 de octubre de 2014 17:34, Bryan Martin <bryanmmartin(at)comcast.net> escribió:
  -Throttle cable:
 Bryan Martin
 N61BM, CH 601 XL,
  	  | Quote: | 	 		  Hello alla again,
 Marcos
 CH601HD (modified)
 Spain
 http://=======================
