ChangDriver
Posted: Sat Oct 10, 2009 12:08 pm Post subject: New Digital Tach from Flight Data Systems |
If you like the idea of the Horizon tach, but don't like the price (it is TSOed) or the fact that it only fits a 3 1/8 hole....the new tach from Flight Data Systems might be your answer.
http://www.fdatasystems.com/T_30.htm
I contacted the company and asked if it would work on a 9-cyl radial. They have a person with a Wilga testing it now and he told me they are committed to making a model that will work for radials.
At $169, this is a nice replacement for the tachs in our planes and it fits the existing hole.
Craig W.
keithmckinley
Posted: Sat Oct 10, 2009 3:02 pm Post subject: Re: New Digital Tach from Flight Data Systems |
Thanks for that post Craig.
I really like their G-meter (thanks again!) the display is large and really easy to read. The tach looks like a great deal.
keithmckinley
Posted: Sat Oct 10, 2009 3:05 pm Post subject: Re: New Digital Tach from Flight Data Systems |
dougsappllc(at)gmail.com Guest
Posted: Sun Oct 11, 2009 4:39 am Post subject: New Digital Tach from Flight Data Systems |
Craig and all,I am a dealer for these FD data (EI) tach's and also the FT-60 fuel flows. Savings is not big as they only give a dealer a 10% break. I am about to order three of them let me know if you have an interest. For those of us who cannot afford a JPI system they are far less expensive, very light weight, and seem to work well.
Doug
On Sat, Oct 10, 2009 at 1:08 PM, Craig Winkelmann <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com (capav8r(at)gmail.com)>
Craig W.
http://forums.matronics.com/viewtopic.php?p=267370#267370
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
ronwasson
Posted: Sun Oct 11, 2009 9:35 am Post subject: Re: New Digital Tach from Flight Data Systems |
Work this work with dual setup front and back
ronwasson
Posted: Sun Oct 11, 2009 4:06 pm Post subject: Re: New Digital Tach from Flight Data Systems |
doug
What's the g meter price from you. I would like 2 g meters and 1 tach maybe 2 if they will work together.
ChangDriver
Posted: Mon Oct 12, 2009 5:42 pm Post subject: Re: New Digital Tach from Flight Data Systems |
As these tachs are driven by the p-lead (not by a signal from our tach gens), I see no reason why you'd have a problem with two (one front, one back). Use shielded wire and make sure you have shield continuity with the p-lead shield and keep any exposure of the unshielded wire (when making connections) as short as possible. The p-lead signal is full of high frequency components which will cause noise unless shielded.
Also, note the company spokesperson I talked to said one was in TEST on a Wilga (M-14P, or as he said...."one of those Russian engines."). He was not sure if the current model will work with a radial. He did say the company was committed to making a model that would work for radials.
It is usually a programming issue to resolve the number of pulses per revolution. Most manufacturers only plan on engines with an even number of cylinders (how dare they!).
Craig W.
Posted: Thu Oct 15, 2009 9:11 am Post subject: New Digital Tach from Flight Data Systems |
Guys,Update to those of you waiting for, or are interested in the new FD digital tachs or g meters-----The new digital tachs are actually not quite ready to ship yet per Chuck at FD, the tech guys are doing a software modification to allow the digital tach to be used with the 9 cly radial engine. He guessed that he could ship in 2-3 weeks. There were also questions as to rather these tachs could be installed in both cockpits, Chuck indicated that he could see no reason why this could not be done.
I have the first shipping position on the first 6 tachs off the line.
Yesterday I ordered the last 4 of the G meters they had in stock, thought that best to grab this stock as another production run is not scheduled for 6 weeks. Those 4 units should arrive here in about a week.
Doug
On Sat, Oct 10, 2009 at 4:05 PM, keithmckinley <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)> wrote:
| Quote: | --> Yak-List message posted by: "keithmckinley" <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)>
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=267394#267394
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
ChangDriver
Posted: Wed Oct 28, 2009 1:51 pm Post subject: Re: New Digital Tach from Flight Data Systems |
As of 28 October 2009
We have tested and confirmed that two T-30 Tachometers can be driven
simultaneously from a single magneto. This will allow installation of
a second tachometer in the rear instrument panel if desired. We have
also completed the software upgrade to allow a user setting for 9
cylinder engines.
We will have production units available to ship next week.
Thanks for your patience,
Charles Newman
Flight Data Systems
346 Keokuk Street
Petaluma, CA 94952
Posted: Wed Oct 28, 2009 2:00 pm Post subject: New Digital Tach from Flight Data Systems |
Craig and all,I have also asked him to modify his enclosed install instructions to reflect the installation of a second T-30 in the rear pit.
Always Yakin,
doug
On Wed, Oct 28, 2009 at 2:51 PM, Craig Winkelmann <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
cylinder engines.
Charles Newman
Flight Data Systems
346 Keokuk Street
Petaluma, CA 94952
http://forums.matronics.com/viewtopic.php?p=269905#269905
le, List Admin.
Maybe life is not the party that we were expecting,
but in the mean time, we're here and we can still dance....."
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
lucyreddy
Posted: Sun Nov 08, 2009 9:27 pm Post subject: Re: New Digital Tach from Flight Data Systems |
Hi Craig,
This is Lucy Reddy.Nice to see such a big deal.Thanks for informing about great replacement.I liked Flight Timer that Automatically Records Flight Time.Brightness is good and it is light weight also.
_________________ nikon kameratasche |
Ttail
Posted: Sat Nov 01, 2014 12:41 am Post subject: Re: New Digital Tach from Flight Data Systems |
Can this Tach display RPM as a % ?
Fly4fude
Posted: Sat Nov 01, 2014 5:40 am Post subject: Re: New Digital Tach from Flight Data Systems |
Hi all,
I've been using these T-30 tacs for the last several months. The ones I have I bought three years ago and they have worked perfectly. I have them wired together off the p-lead from the back of the mag switch. Make sure you wire in the included resistore between the mag switch and the gage.
As far as I can tell they only read RPM and not percentage.
_________________ Scott "Gabby" Wallace |
